Question about Samsung Digimax 4010 Digital Camera
Blinking green light
What does a blinking green light mean? Camera will not take pictures.
    Guru:
  • 1,049 Answers
I believe it does that when there is insufficient light to take the picture, but if it's doing it everywhere then your light sensor in the camera may be malfunctioning. Try pointing the camera at something and then hold the button down light your taking a picture for 15 sec. - Some cameras this overrides the light sensor.
Posted on May 05, 2010
4 Suggested Answers
pishta68
  • 593 Answers
SOURCE: Green and Yellow Light blinks when I turn on my camera
HA, I got the exact same symptoms on my C5050!!! First the yellow light flashes for 10 seconds then the green one flashes. I believe the internal fuses are blown, there are 2 and they are surface mount so they are like 2x2mm so they are SMALL. Im going to have to jump them with a blob of solder on top. It is useless in its present state
Posted on Feb 25, 2008
SOURCE: Camera does not respond when turned on or when plugged in to recharge.
I followed the advice of my Fixya adviser--remove the battery for 3 minutes then plug the USB cable into a different port on my computer and plus in the camera. I did that and turned the camera on as advised but the green light still did not blink. The adviser did not respond when I asked what to do next so I disconnected the camera from the computer and plugged it into the charger. This time the first blue light started blinking (nothing happened when I tried it before following the Fixya advice). I left the camera to charge all night and eventually, after about 12 hours, it did.
Seems O.K. now.
Posted on Aug 22, 2008
bunnydawg
  • 5158 Answers
SOURCE: Vivitar ViviCam 7340 green light
it generally means the batteries need to be replaced or recharged.
Robert
Posted on Dec 17, 2008
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
Mar 10, 2011 | Kodak Cameras
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
Mar 05, 2011 | Olympus Camedia C-50 Zoom Digital Camera
Sony Cyber-shot takes lots of blurry pictures in
first thing you can do is to try reverting cam back to factory settings.to do that initialize the camera.it's under menu>setup settings>main settings1>initialize. after initializing,set cam to auto adjustment mode (green camera icon in mode dial). what to avoid when taking pictures:
1.subject too close (use macro if needed)
2.insufficient light
3.subject movement
4.camera movement (that's caused by you)
5.incorrect camera setting
5.incorrect camera operation
btw, before you take a picture,press the shutter button halfway down first to give the cam ample time to focus.you'll see a flashing green indicator on the screen that means cam is focusing.when the indicator stops blinking cam is ready for the shot.press shutter button all the way.review your picture.if still blurry, you may try changing iso (for dark or fast moving subject, note:the greater value the noisier the picture gets), metering mode and focus settings by going to the shooting menu (press menu when your in P or program mode). hope this helps.tnx:)
Apr 16, 2010 | Sony Cyber-shot DSC-S980 Digital Camera
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Robert
Dec 12, 2008 | Vivitar ViviCam 35 Digital Camera
Seems O.K. now.
Aug 20, 2008 | Kodak EasyShare V1003 Digital Camera
Blinking red timer light
The blinking red timer means that the date isn't set on your camera. Go to the set up screen and set the date. I'm not sure why you wouldn't be able to take pictures, though...
Dec 25, 2007 | Nikon Coolpix 5200 Digital Camera
Two green LEDs are blinking?
The two green LEDs on the back of the camera indicate a number of camera conditions. If they are both blinking, the camera's memory is full and the camera will not take any more pictures.
Sep 21, 2005 | Polaroid PhotoMax Fun Flash 640 Digital...
Why doesn't the shutter button on my EasyShare digital camera work?
The cause and solution may include one of the following: The camera is not turned on. Turn on the camera. The camera is processing a picture; the camera Power ring light (on the Mode dial) blinks green. Wait until the light stops blinking before taking another picture. The card or internal memory is full. Transfer pictures to the computer, delete pictures from the camera, switch storage locations, or insert a memory card with available memory. The shutter button was not pressed. Depress the shutter button completely down. There was a failure in the focus and/or exposure. Press the shutter button halfway to set the Auto Focus (AF) and Auto Exposure (AE). When the AF/AE indicator turns green, press the shutter button completely down. The battery is exhausted. Replace or recharge the battery
Aug 29, 2005 | Kodak EasyShare C360 Digital Camera
Samsung Digimax 4010 Digital Camera Logo
276 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
