Question about AOpen FM56 EXV (91.AC001.216) Modem
What is the Power supply AC 9VAV or 12VAC
I have an Aopen FM56EXV P/N ACC001 216
What is the power supply used with this unit 9VAC or 12VAC
the one We had is lost.
4 Suggested Answers
dauphine
  • 207 Answers
SOURCE: dvd cd combo not working
You can download firmware, drivers, instructions etc. for your combo from here: http://download.aopen.com.tw/Default.aspx
Just select your product, model and download what you need. Make sure to allow your firewall the ftp access to these files.
Posted on Apr 27, 2008
KingDWS
  • 1606 Answers
SOURCE: I am using AOpen 200-Watt Power Supply, suddenly,
200 watt would mean it is a few years old so it could eb a few things. Power supplies can be prone to heat damage if never cleaned out. It's cooling fan gets plugged up just like your cpu fan. The ehat will kill off weak parts.
Generally what fails on these are the big power transistors (mosfets) and sometimes the power capacitors. Easy to replace if you can solder. There is also a fuse on the board that sometimes goes out.
If you can't solder then its not really worth trying to fix as a new power supply is so cheap. You can find a 350 or 400 watt for about $20 brand new.
Posted on Apr 21, 2010
  • 163 Answers
SOURCE: whats the main fuse in Aopen power supply FSP250-60gtw?
They should be 5 amps
Posted on Jul 19, 2010
Testimonial: "Answered my question within minutes :)"
Dell PC not switching to on, if we press switch on/off button it shows orange light and then it switched to off.
First possiblility is too much load on the power supply. Unplug the power connections to everything except the HDD you boot from. If it powers up buy a larger power supply.
If it still doesn't power up, it's a bad power supply. Check the output. You should have -5vac, +5vac, -12vac and +12vac output. If any are missing replace the power supply.
Aug 22, 2013 | Intel Pentium 4 2.40GHz 512/400/1.5V...
My Rocktron Utopia G200 displays DSP RESETTING, no sound, no controlls possible... What can I do?
The symptoms indicate either the WRONG power adapter is being used or the adapter is failing. This unit uses a 9VAC (not DC adapter like many pedals) adpater. If you are trying to use a DC adapter or a multiple pedal power supply that is your problem. Use ONLY the correct power supply with this unit.
Jun 17, 2011 | Rocktron Utopia G200 Guitar Multi Effects...
I had used a lower Ac Apadter, it was about 300 Millwalts,But the SP uses about 1000 Millawalts. Would The Roland Sp 606 Still Burn Out if i use a lower Ac adapter?
the unit will only draw the amps it needs, at that low of amps it should not even turn on.
However the voltage is the question YOU CAN NOT USE A POWER SUPPLY THAT HAS MOVE VOLTAGE.
THINGS TO CONSIDER;
is the unit AC or DC
are you applying the right voltage (9VDC 1000MA) (9VAC 1000MA)
if it's AC you can not use DC and vice versa
Feb 22, 2011 | Roland Sp-606 Sampling Workstation System
Not working@ full pwr.I just got a new power supply I plugged it in the wall , in a short time the pwr supply got hot.. is there a way to reset it?
Sounds like you got an incorrect power supply OR the SR16 has a failure creating too much load.
The power supply should be a 9VAC at 1 amp (1000 ma)
The power supply MAY get warm to the touch but should not get real hot.
Without the SR16 pluged onto the power supply it should barely get warm. If the SR16 doesn't work, then it probably has an internal failure... LIKELY the internal rectifier filter combination.
Oct 09, 2009 | Alesis Sr 16 Stereo Drum Machine
No power to my subwoffer
Boston Acoustics Model DM12-3A0-1AN (Power Supply Adapter) 12VAC 3000mA (3A) Only Dealer is BA Direct in NJ Phone: 978/538-5000 Just received one on 7/14/09: $54.00 (Incl. S&H). Meow! Florida
Feb 09, 2009 | Boston Acoustics BA7500 Computer Speakers
I need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Dec 11, 2008 | Music
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
AOpen FM56 EXV (91.AC001.216) Modem Logo
101 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
