Question about Sharp EL-2630P Calculator
Sharp EL-2630GII Error on display
How do I clear an E on the bottom right corner of the display on a Sharp EL-2630GII calculator?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Unable to locate a manual for this specific model, but if you go to http://www.sharp.ca/manuals/, you will find one for an EL2630-P, PII, and PIII. The functions are very similar and should give you the detail that you need. Generally there will be a reset button (likely on the bottom of the machine), which often must be pushed in using a ballpoint pen or similar implement, if no other routine clear or reset procedure (such as turning off and back on) is working.
Please post back if you need more help, otherwise thank you for using and rating FixYa!
Posted on Jun 08, 2008
  • Jennifer Smith
    Jennifer Smith Nov 20, 2013
    This did not change the light display. Still really light and almost unable to view.
Need user manual for Sharp EL2630G adding machine
Sorry Ed Duskin,
The other question I answered was clearly marked
Sharp EL2630G adding machine... when I answered it.
I was able to trace your machine nomenclature back to
Sharp-USA as an EL-2630GII
I posted the phone number there because No such adding machine was recognized by the Sharp-USA site
Sharp EL2630G... You must telephone
1-800-BE-SHARP will get you real people...
1-800-237-4277 ...
Nov 07, 2016 | Sharp Office Equipment & Supplies
CE button doesn't clear on my SHARP EL-2630PIII
CE stands for Clear Entry. It clears the number that one just entered. To clear the results of a previous calculation use the key AC, if calculator has one. Otherwise try pressing the CE key twice or enter 0, because that is what the clear button will do.
Sep 30, 2013 | Sharp EL-2630P Calculator
EL 531X Sharp - Help with calculations
You need a SHARP with Write-View display capabilities. The EL-531X is unable to show that. The Write-View calculators from Shard have a W, example EL-W516 followed by Write-View. Not to be confused with the W in EL-520W
Feb 21, 2013 | Sharp el-531x scientific calculator
Have a sharp EL-506w calculator i have ten zeros on the screen it will do problems but it s a bunch of zeros behind it it aiso says x10 in small context at the far right side bottom of the screen.
Your calculator is set to display in scientific notation. To change it, press SETUP 1 then choose the desired mode. For most purposes you'll probably want Floating Point. For more details see the third column of the first page of the manual.
Oct 22, 2012 | Sharp Office Equipment & Supplies
I inserted a new battery to Sharp EL 6092 ,it tell me Data problem,please reset.After reset tell me reset ok?Then i press any button it tell me again Data problem. I dont understand
First press the reset button then when the display says "RESET OK ?" press the CAPS button then the button marked "2nd" (bottom left hand corner) then press Enter. Display will then say "BUSY". Reset is then complete.
Feb 21, 2011 | Sharp Office Equipment & Supplies
My calculator will show fractions instead of decimals when doing division. How do I change that? There is a N1 displayed in the lower left corner also...I think that may be the problem
Getting Decimal Answers by Disabling WriteViewelw516.gif on the Sharp EL-W516 Calculator
The Sharp EL-W516's WriteView display uses multiple lines to display mathematics as it is seen on a page. Fractions are shown as fractions, exponents as exponents, integrals as integrals, and so on. This makes entering calculations easier, and reduces the chance of errors.
At the same time, calculation results are displayed as fractions (or with roots or pi) whenever possible. Pressing the CHANGE button repeatedly will change these to decimal answers.
If you prefer to always get decimal results you need to disable the WriteView display mode. Doing this will make the calculator display like the Sharp EL-546W when in NORMAL mode. Answers will be given as decimals, but fractions will no longer look like fractions. In general, you will still need to follow the EL-W516 instructions.
Disabling WriteView
Press 2ndF and MATH to enter SET UP. Now press 2 for EDITOR.
There are now two options: 0: W-VIEW, and 1: LINE
Press 1 for Linear display mode to disable the WriteView display, and to get decimals as your answers.
To return to the WriteView display, go through the steps above but press 0 for W-VIEW.
NOTE: It is not possible to have decimals as the default answer form when in WriteView mode.
Feb 07, 2011 | Sharp ELW516 Scientific Calculator
The calculator is intermittent: Most of the time
Not knowing what to do, I tried anything that could possibly help:
I installed fresh batteries and I pushed the reset button on the back of the calculator (Sharp EL-546L) and finally, it work all right after more than 5 years I own the calculator and where it did work correctly for 5 minutes. I tried the reset button in the past (long time ago) and it didn't work. This time it worked because, maybe, I've used fresh batteries.
Marcello
Jun 03, 2009 | Sharp EL-738 Scientific Calculator
Need new ribbon
The ribbon code is BR80C. Nu-Kote has a version with a part number of NUKBR80C. You should be able to order it on line at Staples.
Mar 27, 2009 | Sharp EL-2630P Calculator
Sharp EL-2630P Calculator Logo
1,543 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
