Question about Slendertone Fortex
My slendertone keeps cutting out after five minutes...what's wrong?
Slendertone will not switch on
The replacement batteries could be defective or installed incorrectly. Also, the switch may have failed.
Apr 01, 2014 | Slendertone System Abs
Slendertone keeps beeping
the beeping its becouse there is no contact between the pads and the skin (1), or the cables and the pads (2), or the cables and the controller (3).
what the manufacturer says:
try to change the pads by new ones
i did that, but still not working.
what i do:
i had the second problem, but i fix it, i cut the cloth in the back part of the pin (not in the front of the pin), and i discover that the cable that is attached to the pin was cut, i remove the the pin, then i replaced with a bolt, i attch the cable to the bolt and thats all.
i'm using it right now and its works great.
i answer on another post similar to this one, a put a link to my google account where you can see pictures of what i did.
thums up! thank you!
Dec 28, 2013 | Slendertone Fortex
Error e002 slendertone flex belt
Dear Karen! I have the same problem white my slendertone e002 error,if you deal whit it,please helm me!
Oct 24, 2012 | Slendertone Abdominal Muscle Toner
Bought Slendertone Start but lost instructions so dont how to use.Would like the instructions for slendertone start
Manuals for the various Slendertone products can be found here:
https://www.slendertoneusa.com/t-manuals.aspx
There does not seem to be a manual specifically designated for 'Slendertone Start'; is that a specific product or a program for using one or more of the Sendertone products?
May 21, 2011 | Health & Beauty
My slendertone belt keeps beeping with a triangle next to it. I can't turn up the intensity and it won't vibrate but I'm not sure why. What's the problem?
I just replaced new pads but that triangle still appear. Can't really do anything with the belt right now. Really frustrating.
Feb 18, 2011 | Slendertone Fortex
How do you work the Slendertone Belt? I lost the
hold it in front of you comfortably and pull outward (its pretty straight forward)
Jan 13, 2010 | Slendertone Fortex
Cutting out after five minutes use
sounds like not good air flow check for blockage new filter
Aug 11, 2009 | Vacuums
Citroen picasso keeps cutting out twice a week on acceleration
Sounds like an air leak or the tank pump cannot keep up with demand (the supply pump in tanks do give trouble (a pressure gauge between tank and engine would tell, make sure it is visable when driving, I used to tape it to the bonnet with masking tape.
Jun 23, 2009 | 1987 Peugeot Liberte
Slendertone Fortex Logo
104 people viewed this question
Top Slendertone Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Slendertone Exercise and Fitnes Expert? Answer questions, earn points and help others
