Got a new VSX-1020 and can't get it to output anything (audio or video). Even when connecting the 'monitor' output to the TV, I can't see the GUI. Any ideas?
  • 21 Answers
Is the unit still under warranty? Have you contacted Yamaha Support? They are usually useful and will guide you through diagnostics.
Posted on May 07, 2010
How solve in my POLYCOM VSX 6000 showing error "unsupported signal adjust your PC output"
Try using the S-Video output and then try using the VGA output from the VSX 6000 unit. The unit can be fixed to output from either as the first monitor output (you may have the dual monitor option enabled). If this does not work the resolution of the TV might be HD, the output of your VSX 6000 is Standard Definition. You will need a monitor that accepts standard definition. If this does not work, I would reboot your VSX 6000 and try again. David
May 17, 2014 | Polycom VSX 6000 (220022222001) Video...
I got a new tv and dvd player and all the wires were pulled out and now i do not know how to reconnect it...
Basically all analog audio inputs and outputs are complementary of each other, such as audio output mates with audio input or viceversa. Video output mates with video input. You typically should have a composite video connector on your both DVD and TV set. Reconnect them directly. As you can imagine, DVD audio and video outputs should go to audio and video inputs of your TV receiver. Good luck.
Mar 15, 2014 | Pioneer VSX-455 Receiver
How do I connect my pioneer vsx prologic receiver to my hdmi plasma tv?
If the tv has normal stereo outputs, you will use those. if it only has a digital output, your best option will be to buy a new receiver.
Feb 20, 2011 | Pioneer VSX-454 Receiver
How do i conect my tv to this receiver
That would depend on the capabilities of the TV.
The VSX-D509 manual is avalailable for free at retrevo.com.
http://www.retrevo.com/s/Pioneer-VSX-D509S-Receivers-review-manual/id/385ci970/t/1-2/
The receiver only needs a simple composite monitor output using a standard RCA cable so you can use the TV to operate it through its menus.
My TV has many video inputs of the various technologies, so I connect each Hi-Def video source's video directly to the TV and run the audio from them to the appropriate inputs on the Receiver.
If you feel the need to have the TV's minimalist audio run into the receiver just run an RCA pair from its audio output to any available analog input, but the sound will be limited to analog stereo. In the TV's setup find a setting for the audio output and select whatever closely resembles a 'fixed' level so you can mute or turn its volume down without affecting the audio out to the receiver.
Jul 16, 2010 | Pioneer VSX-D509S Receiver
Connected the wires-red, white and yellow into every possible place I could think of on the tv and vcr and nothing happened. What could I possibly be doing wrong.
  1. connect from the VCR a/v output to the yellow red and white to the receiver Video 1 input.
  2. connect Video Monitor Out on the receiver to a yellow video input on the TV. (if there are several note which input you are using 1,2,3...)
  3. select video 1 on the receiver
  4. select the proper input on the tv
  5. play a video on the VCR.
  6. If still no video on tv connect the yellow dircetly to the TV from the vcr.
Dec 07, 2009 | Pioneer VSX-406 Receiver
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Sep 18, 2009 | Pioneer VSX-1019AHK A/V receiver
Get ''not supported ''message on vx-1018-ah
Verify this is a Pioneer VSX-1018AH.
The manual explains it all... The problem is probably an incompatible setting on your source.
Search for "not support" in the manual...
http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
I think this may do it... From Page 86...
No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
If they are not, please connect them using the component or composite video jacks.
• Depending on the connected source component, it’s possible that it will not work with this receiver
(even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
between source and receiver.
• If the problem still persists when connecting your HDMI component directly to your monitor,
please consult the component or monitor manual or contact the manufacturer for support.
• If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
or other setting for your component.
If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
• While analog video signals are being output over HDMI, use a separate connection for audio
output.
• When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
audio connection.
• To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
receiver to a component or TV with the DeepColor feature.
Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
No image is output when an
input is selected.
• Check the video connections of the source component (see page 18).
For high-definition video (using component video connections), or when digital video conversion
is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
using the same type of video cable as you used to connect your video component.
• Make sure the input assignment is correct for components connected using component or HDMI
cables (see The Input Setup menu on page 67).
• Check the video output settings of the source component.
• Check that the video input you selected on your TV is correct.
Some components (such as video game units) have resolutions that may not be converted. If
adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
resolution settings on your component or display doesn’t work, try switching Digital Video
Conversion (in Setting the Video options on page 72) OFF
Apr 05, 2009 | Pioneer Audio Players & Recorders
I'd like to know where the vcr cable & cable wire from wall
(I own 2 VSX-D903S Units.)
There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
Dec 26, 2008 | Pioneer VSX-D903S Receiver
How to connect pionier VSX-918V-K receiver with blu-ray dvd and high definition tv box
The audio OUTPUT of blu-ray dvd is to INPUT to the VSX-918V-K receiver.There are three RCA jack red and white is the audio,the yellow or blue sometimes for the video connect to your TV...
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 23, 2008 | Pioneer Audio Players & Recorders
87 people viewed this question
 Grubhead
Grubhead
