Question about Troy Bilt 5.5hp Self Propelled Mower
Where is the oil drain plug for the 5.5hp 21"self-propelled mower
Want to change the oil where is the drain plug for the oil
  • 284 Answers
Under mower,remove blade,remove plastic or metal shield,remove blade adaptor that the belt goes around,by now you see the bottom of the engine,look for a square headed plug that a 3/8 inch ratchet with a short extension fits into and remove conterclockwise and have a container to catch the oil )or you may see a plastic plug that a standard wrench would fit or possibly still a ratchet item.( Note : always have your mowers spark plug up,usually in the front and support the front while you are doing the above)
If you dont want to get dirty then buy a vacuum oil extractor and remove the oil through the dipstick hole
Posted on May 06, 2010
How to change the oil
remove spark plug wire or whole thing
theres a plug in the bottom under the deck
remove plug drain into pan
Apr 30, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How to change the oil in my MTD 6.5h Honda yardman
Many mower engines no longer have a drain plug, or the plug is covered by the deck or other components, the best way is to suck the oil out via the oil filler, there are plenty of inexpensive vacume pumps availble that makes the job easy, check out the dealers or e bay.
Mar 14, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How to change oil for briggs and stratton lawnmower
There a plug on right side of engine close to bottom. Remove it
to drain old oil.
Nov 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
How to change the oil in my 550 self propelled push mower. Where is the oil plug? How often does the spark plug need to be changed. We've had ours nearly 2 years with lite use, and no maintenance.
There is no drain plug on that model , one has to lift up the entire machine ,tilt and drain the oil out of the filler spout. Change plug once a year - Champion# J19LM
Sep 10, 2011 | Poulan Pro " Pro" Self Propelled Mower
I need to change oil in my yard man lawn mower. Where is the drain plug? I need to change the oil
Hi, you drain it out of the dipstick filler hole by tipping the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
May 17, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Tool for oil change/plug
no special tool needed.Just use a 3/8 ratchet extension. Fits perfect
Apr 28, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
Where is the oil drain plug? I have a Poulan 600 pro self-propelled lawn mower and cannot find the oil drain plug to change the oil.
It is on the bottom of the engine. Lift up the deck and look under it. Make sure there's no grass covering it up.
Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
Oil change
Most push mowers, you just take out the filler plug and turn it on it's side to drain.Set the mower up on blocks so it rests 6-8" off the ground, place a large catch pan underneath for the oil.
Apr 09, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Troy Bilt 5.5hp Self Propelled Mower Logo
356 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
