Question about KitchenAid Washing Machines
Starts washing gets to 22 min goes to f-22 back blew drain put on drain and spin worked fine next load did the same thing again
  • ladydalmatio May 05, 2010
    why if i back blow the drain why dose it start working?
  • ladydalmatio May 06, 2010
    Will try it tomorrow
  • 4,059 Answers
This error occurs if the touchpad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touchpad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touchpad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touchpad/LED assembly and Central Control Unit (CCU).
Replace failed component.
Posted on May 05, 2010
  • Charles T Nevin
    Charles T Nevin May 05, 2010
    Have you tried to just unplug it to reset the control and see if it works to finish that cycle and what it does in the next wash.
Washing machine goes thru the wash cycle then it stops, if I lift the door it starts again ,than stops. lift the door it starts than stops
It could be your out of balance switch is getting tripped before you try it again put in the spin cyc and see if it spins and drains the water if it does a odd sized load could be causing the failure.
Apr 09, 2011 | Speed Queen AWN542 Washer
Put in load with which must have been to heavy, washer didn't spin out clothes, tried to put through another spin cycle, won't do it. unplugged washer, tried restarting cycle after removing clothes, will...
You can try to reset control board///unplug washer for one min/plug unit back in within 5 seconds open and close lid 5 times after you do that wait a min then unplug wait a min plug back in and lets hope she works..hope this helps good luck need more help contact me.. thanks for voting
Mar 21, 2011 | GE Profile WPRE6100G Top Load Washer
Beko wma510w only spins when it feels like it
I have the same model and problem. I suspect the problem is due to the machines sensor which detects when it is off balance. The problem is most likely to occur when doing something like a single large towel. You can see it thinking about spinning but as soon as the drum starts to wobble it slows back down again.
Any ideas on how to stop this happening (sensor replacement) would be useful.
Jun 21, 2009 | Washing Machines
Frigidaire washing machine gets stuck on cycles
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Frigidaire Washing Machines
The washing mashine will not drain and does not spin
GO TO A APPLIANCE SHOP GET A MOTOR THEIR ABOUT20 TO 30 DOLLARS THEIR REAL EASYTAKE ABOUT10 MIN TO DOIT TO PUT IN IF ANY THING WRITE ME BACK
May 04, 2008 | Washing Machines
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Clicking Sound between agitation and drain cycle
Is it a front loading or top loading washing machine?
Oct 08, 2007 | Washing Machines
Washing Machines Logo
Top KitchenAid Washing Machines Experts
Sal DeAngelo
thinksewfast
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
