Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Water filter I have a older kitchenAid no-frost refrigerator-freezer model KSRS22Q. Where is the water filter located? My user guide does not show the location.
  • Anonymous Mar 12, 2014
    older no frost model
I don't think this model has a filter, I checked under the kickplate, no filter there.
Posted on Apr 05, 2008
    President:
  • 1,314 Answers
I beleive its in the lower kickplate mike at the bottom
Posted on Mar 30, 2008
6ya staff
SOURCE:
KFFS20EYMS00
KitchenAid Refrigerator Not Defrosting - Model ...
www.repairclinic.com/...-/KitchenAid-Refrigerator-not-defrosting-KFFS...
Show all parts for model KFFS20EYMS00 ... If the defrost heater assembly has burned out, the frost will build up on the coils and eventually no air will be able to ...
Jul 28, 2015 | Freezers
Tfx25zr where is water filter
If your model has a filter The water filter cartridge is located in the
upper right-hand corner of the fresh food
compartment, right below the temperature
controls.
The filter cartridge should be replaced
every
six months or earlier if the flow of
water to the water dispenser or icemaker
decreases.
Download User Manuals HERE
Sea Breeze
Older Model
TFX25ZRY
Use and Care Manual for above model(s)
TFX25ZRBAA
Series 25.2 Cu. Ft. Side-By-Side Refrigerator with Dispenser
Quick Specs
Energy Guide
Use and Care Manual
TFX25ZRBWW
Quick Specs
Energy Guide
Use and Care Manual
TFX25ZRBBB
Quick Specs
Use and Care Manual
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchen Aid bottom freezer KBRS22KK is frosting up
Replace the "defrost thermostat" located on the coils in the freezer. Here is the part to order.
Dec 01, 2012 | KitchenAid KBRP20EMSS Bottom Freezer...
Is there a water fiter in Kitchenaid model KSRS22Q refrigerator
Not that I could see on the diagrams.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 03, 2011 | KitchenAid Refrigerators
My freezer compartment is full of ice and frost on kitchenaid ktra22emss
if a no frost frig is frosted then the defrost system has failed . look at the heater / and defrost terminator . and the aditive defrost control as any one of these will cause the problem. . on some models the drain in the freezer is pluged and needs cleaning . this will cause ice build up on bottom of freezer .. ( clean drain with hot water & turkey baster ....hope this helps mm
Oct 09, 2010 | KitchenAid KTRA22EMSS Top Freezer...
I have a ktra22el kitchenaid top freezer refridgerator and I can not locate the filter...please help
If you have a filter on this model it would be in the fresh food section near the top right corner. Here is a link to the manual and page 11 shows the removal process.
If your unit does not have this built in filter the filter would be located behind the refrigerator or under the kitchen sink in most cases.
I hope this helps.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202225409.pdf
Apr 19, 2010 | KitchenAid KTRC22EM Top Freezer...
KitchenAid KBRS22KG black bottom freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 13, 2009 | KitchenAid KBRS22KG
Refrigerator side not cold
if you have frost build up on rear wall of freezer section then your unit is not going through defrost. its either defrost heater, defrost thermostat (which are both located on evaporator) or defrost timer
Jun 24, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
Kitchen aid refrigerator model KSRS22Q
it should be on the bottom where the kick plate is and will be a round piece that you turn and remove
Mar 03, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
325 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
