Question about Uniden BC350C Base Scanner
How to program it - Uniden BC350C Base Scanner
    President:
  • 2,761 Answers
Oddly, the BC350C does not have a direct-entry (keyboard) programming function. Frequencies can only be entered into the "PRIVATE" bank by transferring them from the SCAN or SEARCH functions. This sounds confusing, but the programming steps are detailed in the scanner operating manual, which you can download/print here:
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
Posted on May 07, 2010
I am having trouble programming a key less entry remote for a 2002 grand am
How are you doing it ?
Transmitter Programming
Important: All transmitters that are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode, all previously programmed transmitters will be erased upon receipt of the programming signal from the first transmitter.
Up to 4 transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle. The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed.
Install a scan tool.
Turn ON the ignition with the engine OFF.
With the scan tool, select Body, go to Remote Function Actuation.
Select Special Functions.
Select Program Key Fobs.
Select the number of key fobs to be programmed.
Press and hold the LOCK and the UNLOCK buttons simultaneously on the first transmitter for approximately 15 seconds. The power locks should cycle to confirm programming of the first fob is complete.
If you are programming more than one transmitter, repeat the previous step to program up to 4 transmitters.
Remove the scan tool.
Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
Operate the transmitter functions in order to verify correct system operation.
DEALER !
Apr 19, 2018 | 2002 Pontiac Grand Am
How to solve the problem"*.exe
This error is generally an indication that the written program isn't designed to be run in the 32 bit windows environment, the program is corrupted, or an error occured while trying to run the program. It is generally due to an older program being run within windows.
The newer windows versions are mostly 32 bit platforms. Some of the old programs from windows 95 and 98 eras won't work because they are 16 bit programs. Examples may include older programs with a .com extension (which will bring up this error message), or old versions of .exe's written for 16 bit environments.
If the program you are attempting to run is a recent program (came with your version of windows XP or later) then it could be an error at execution or the program is corrupted. If the program is written by a major brand and is relatively new, contact the program's technical support number for help.
If you suspect a program error, try and obtain another copy of the program. Uninstall the current copy of the program, restart your computer, then install a fresh copy. If the error continues after doing this, then contact the program manufacturer's technical support number.
If the program you are using is one of the programs from within windows, (from the system 32 folder for example, and include notepad.exe, msconfig.exe, or other programs that can be selected and run from within this folder) do NOT remove or copy over the program. Some of the programs within the windows sub-directories are older 16bit programs, not designed to run within the 32bit platform. It is recommended to NOT remove any of these programs from the windows sub directories.
Jan 12, 2011 | Computers & Internet
Software for Sharp XE-A201 Cash Register
You need the PC Link software for your model.
All of these manuals can be downloaded at:
http://the-checkout-tech.com/
sharp ER-1017 Service
sharp ER-1072 Service
sharp ER-1073 Service
sharp ER-1074 Service
sharp ER-1075 Service
sharp ER-1076 User Service
sharp ER-1077 Service Programming
sharp ER-1077
sharp ER-1077
sharp ER-1772 Service
sharp ER-1772s Service
sharp ER-1871 Service
sharp ER-1872 Service
sharp ER-1873 User Service
sharp ER-1875 User Service
sharp ER-1910 User Service
sharp ER-1911 User Service Programming
sharp ER-1911s User Programming
sharp ER-1920 User Service
sharp ER-1921 User(R) Service Programming
sharp ER-1921s Programming
sharp ER-1970 User Service Programming
sharp ER-2000U Service
sharp ER-2100 User Service
sharp ER-2370 Service
sharp ER-2371 User(R) Service Programming(R)
sharp ER-2385 Service
sharp ER-2386 Service
sharp ER-2386s User
sharp ER-2395 Service
sharp ER-2396 Service
sharp ER-2720 Service
sharp ER-2722 Service
sharp ER-2722A User Service
sharp ER-2742 Service
sharp ER-2742A Service
sharp ER-2770 Service
sharp ER-2782 Service
sharp ER-2782A Service
sharp ER-2905 Service
sharp ER-2908 Service
sharp ER-2910 Service Programming
sharp ER-2970 User Service
sharp ER-2975 Service
sharp ER-2980 User Service
sharp ER-2980S Service
sharp ER-3100 User Service Programming
sharp ER-3110 User Service Programming
sharp ER-3115 Service Programming
sharp ER-3120 User Service Programming
sharp ER-3550 Service
sharp ER-3600 User Service
sharp ER-3630 User Service
sharp ER-3712 User Service
sharp ER-3721 Service
sharp ER-3731 Service
sharp ER-3732 User Service
sharp ER-4100 User Service Programming(R)
sharp ER-4110 User Service Programming(R)
sharp ER-4100S Service
sharp ER-4110S Service
sharp ER-4550 Service
sharp ER-4630 User Service
sharp ER-4633 Service
sharp ER-4700 User
sharp ER-6740 Service
sharp ER-8700 Not Available, do you want to swap?
sharp ER-A150 User Service Programming
sharp ER-A160 User Service Programming
sharp ER-A170 User(R) Service Programming
sharp ER-A180 User Service Programming
sharp ER-A220 User Service Programming
sharp ER-A227G Programming
sharp ER-A250 User Service Programming
sharp ER-A310 User Service Programming
sharp ER-A320 User Programming
sharp ER-A330 User Service Programming
sharp ER-A410 User Service Programming
sharp ER-A420 User Service Programming
sharp ER-A430 User Service Programming
sharp ER-A440 User Service Programming
sharp ER-A440S Programming
sharp ER-A450 User Programming
sharp ER-A450S User Service Programming
sharp ER-A450T User Service Programming
sharp ER-A460 User Service Programming
sharp ER-A470 User Service Programming
sharp ER-A490 User(R) Service Programming
sharp ER-A510 User Service Programming
sharp ER-A510s Service
sharp ER-A520 User Service Programming
sharp ER-A530 User Service Programming
sharp ER-A550 User Service Programming
sharp ER-A550s User(R) Service
sharp ER-A570 User Service Programming
sharp ER-A610 User Service Programming
sharp ER-A650 User Service Programming
sharp ER-A650S Programming
sharp ER-A670 Not Available, do you want to swap?
sharp ER-A670S Programming
sharp ER-A750 User Service Programming
sharp ER-A770 User Service Programming
sharp ER-A770II User
sharp ER-A770M User Service
sharp ER-A771 User Service Programming
sharp ER-A850 User
sharp ER-A880 Not Available, do you want to swap?
sharp UP-3300 User Service Programming
sharp UP-3300M Service
sharp UP-3301 User Service Programming
sharp UP-600 User Service Programming
sharp UP-700 User Service Programming
sharp UP-800F User
sharp UP-810F User
sharp UP-820N User Service
sharp UP-X300 User
sharp UP-X500 User Service
sharp XE-A101 User Service Programming
sharp XE-A102 User Programming
sharp XE-A106 User
sharp XE-A110 User Service Programming
sharp XE-A120 User Service Programming
sharp XE-A130 User Service Programming
sharp XE-A201 User Service Programming
sharp XE-A202 User Service Programming
sharp XE-A203 User Programming
sharp XE-A206 User
sharp XE-A20S User Programming
sharp XE-A212 User Service Programming
sharp XE-A213 User Programming
sharp XE-A301 User Service Programming
sharp XE-A302 User Programming
sharp XE-A303 ? Programming
sharp XE-A401 User Programming
sharp XE-A402 User
sharp XE-A406 User
sharp XE-A40S User Programming
sharp XE-A505 User Programming
Dec 30, 2009 | Sharp XE-A402 Electronic Cash Register
How do I uninstall a program from my computer?
follow these easy steps:
1)open my computer
2)click on Add and Remove Programs ,wait till is loaded then select your program that you want to uninstal and click Remove.
Dec 22, 2009 | Dell Dimension 2400 PC Desktop
Roxio Media Manager program installation will not complete. How do I uninstall.
Posted all operatings systems...
In Windows, how do I uninstall programs? Using the Add/Remove Programs control panel The Add/Remove Programs control panel in Windows makes it easier to uninstall programs. Follow the appropriate instructions below to use this control panel.
Windows 7
  1. From the Start menu, select Control Panel.
  2. In Large or Small icon view, click Programs and Features. If you're using Category view, under "Programs", click Uninstall a program.
  3. Select the program you want to remove, and click Uninstall. Alternatively, right-click the program and select Uninstall.
Windows Vista
  2. In Classic View, double-click Programs and Features. If using the Control Panel Home view, under "Programs", click Uninstall a program.
Windows XP in the default XP view
  1. From the Start Menu, select Control Panel.
  2. Click the Add or Remove Programs icon.
  3. Select the program you wish to remove and click Remove.
Windows XP in Classic View and 2000
  1. From the Start menu, select Settings, and then Control Panel.
  2. Double-click the Add/Remove Programs icon.
  3. Select the program you wish to remove and click Add/Remove.
Using the Uninstall program from the Start menu If the program you wish to uninstall is not listed among the installed programs, an uninstall program for that item might be available on the Start menu. To look for such an option:
  1. From the Start menu, select Programs or All Programs.
  2. Find the folder for the program you wish to uninstall and highlight it.
  3. In many cases, on the menu that appears, you will see an uninstall option.
Please let me know how this works out for you...
Thank you
Jon
Aug 12, 2009 | Computers & Internet
Casio 4200 cash register
For the real manual, visit the checkout tech.
casio 103ER User
casio 110CR User Service
casio 116ER User
casio 117ER User(R) Programming(R)
casio 120CR User Service
casio 120ER User Programming
casio 130CR User
casio 140CR User
casio 150CR User Service Programming
casio 160CR Service
casio 200CR User Service
casio 204SR User(R) Programming(R)
casio 208SR User(R) Programming(R)
casio 210ER User Programming
casio 2122ER User(R) Programming(R)
casio 2124ER User(R) Programming(R)
casio 2128ER User(R) Programming(R)
casio 230ER Technical Trouble Shooting
casio 240CR User Service
casio 3420ER User(R) Programming(R)
casio 3430ER User(R) Programming(R)
casio 3612ER User(R) Programming(R)
casio 3620ER User(R) Programming(R)
casio 3630ER User(R) Programming(R)
casio 3812ER User(R) Programming(R)
casio 3820ER User(R) Programming(R)
casio 3830ER User(R) Programming(R)
casio 3904ER Programming(R)
casio 3908ER Programming(R)
casio 4420ER User(R) Programming(R)
casio 4430ER User(R) Programming(R)
casio 4612ER User(R) Programming(R)
casio 4620ER User(R) Programming(R)
casio 4630ER User(R) Programming(R)
casio 4812ER User(R) Programming(R)
casio 4820ER User(R) Programming(R)
casio 4830ER User(R) Programming(R)
casio 4912ER Programming(R)
casio 4920ER Programming(R)
casio 4930ER Programming(R)
casio 6118ER Mac +date(R)
casio 6130ER Mac +date(R)
casio 7100SR User(R) Programming(R)
casio 7200SR User(R) Programming(R)
casio 7300SR User(R) Programming(R)
casio CE-160 User Programming
casio CE-200 Service
casio CE-2104 User(R) Programming(R)
casio CE-2108 User Programming
casio CE-2300 User
casio CE-2350 User Service Programming
casio CE-2400 User Service Programming
casio CE-250 User Service
casio CE-280 User
casio CE-285 User Programming
casio CE-300 Service
casio CE-310 User
casio CE-3700 Service
casio CE-3750 Service
casio CE-3700 User Programming
casio CE-4000 User Service Programming
casio CE-4050 User Service Programming
casio CE-4200 User(R) Programming
casio CE-4250 User(R) Programming
casio CE-4500 Euro User(R) Programming(R)
casio CE-4500 Programming(R)
casio CE-4600 Programming(R)
casio CE-4700 User Programming
casio CE-6000 User Service Programming
casio CE-6100 User Service
casio CE-6800 Service
casio CE-7000 User Service
casio CE-T100 User Service Programming
casio CE-T300 User Service
casio FE-3000 Service
casio FE-4000 Service
casio FE-810 Service
casio MP-2000 Service
casio PCR-1000 User Service Programming
casio PCR-204 User Programming
casio PCR-208 User Programming
casio PCR-210 User Programming
casio PCR-250 User Programming
casio PCR-255 User Service Programming
casio PCR-255P User Service
casio PCR-260 User Service Programming
casio PCR-260B User Programming
casio PCR-262 User Programming
casio PCR-265P User Service
casio PCR-275 User Service
casio PCR-330 User Programming
casio PCR-355 User Programming
casio PCR-360 User Service Programming
casio PCR-365 Service
casio PCR-365A User
casio PCR-365P Service
casio PCR-408 User Programming
casio PCR-450 User Programming
casio PCR-460 User Programming
casio PCR-465 Service
casio PCR-T2000 User Service Programming
casio PCR-T2100 User Programming
casio PCR-T265 User Service
casio PCR-T275 User Service
casio PCR-T465 User Service Programming
casio PCR-T470 User Programming
casio QT-2000 User Service Programming
casio QT-2100 User Service Programming
casio QT-6000 User Service Programming
casio QT-6100 User Programming
casio QT-7000 Service
casio QT-7100 Service
casio QT-7000B Service
casio QT-7100B Service
casio QT-7300 User Service
casio QT-8000 Service
casio SA-1000 Programming(R)
casio SA-3000 Service
casio SA-5000 Service
casio SA-5100 Service
casio SE-C2000 User Programming
casio SE-C300 User Programming
casio SE-S2000 User Programming
casio SE-S300 User Programming
casio Sigma 61ER User
casio Sigma 62ER User
casio Sigma 63ER User
casio TE-100 User Service Programming
casio TE-2000 User Service Programming
casio TE-2200 User Service
casio TE-2400 User Service
casio TE-3000S User Service
casio TE-4000F User Service
casio TE-4500F Service
casio TE-7000S User Service Programming
casio TE-8000F User Service Programming
casio TE-8500F User Service Programming
casio TE-M80 User Service Programming
casio TK-1000 User(R) Programming(R)
casio TK-1100 User(R) Programming(R)
casio TK-1200 Programming
casio TK-1300 Programming
casio TK-2000 User(R) Programming(R)
casio TK-2100 Euro User(R) Programming(R)
casio TK-2100 User(R) Programming(R)
casio TK-2200 User Programming
casio TK-2300 User Programming
casio TK-2700 User Programming
casio TK-3200 User Dealer
casio TK-4200 User
casio TK-4300 User
casio TK-5100 User Programming(R)
casio TK-6000 User Service
casio TK-6500 User Service
casio TK-7000 User Service
casio TK-710 User Programming
casio TK-7500 User Service
casio TK-800 User Service Programming
casio TK-810 User Service Programming
casio TK-T200 User Service Programming
casio TK-T500 User Service
Jul 26, 2009 | Office Equipment & Supplies
How to lower taxes down on a casio cash register?
Here is a link to the many different Casio Cash Registers User Guide, Owner Manual, Operating Instruction And Service Handbook
http://www.devicemanuals.com/guide/Cash%20Registers/Casio-manuals.html
Apr 17, 2009 | Computers & Internet
T3 sync with PC- Windows XP
Need to reload software in pc. Dropping stuff. If you found this helpful, please post as so. If you need to knwo how, live chat
Sep 14, 2008 | Palm Tungsten T3 Handheld
Olivetti ecr 350 cash register problem starting up
There is an ECR350 manual here that might help:
olivetti CMS-140B User Programming
olivetti ECR-2100 User
olivetti ECR-2150 User
olivetti ECR-2200 User
olivetti ECR-2250 User
olivetti ECR-2300 User Programming
olivetti ECR-2350 User Programming
olivetti ECR-2400 User Programming
olivetti ECR-2450 User Programming
olivetti ECR-2500 User Programming
olivetti ECR-2550 User Programming
olivetti ECR-300 User Programming
olivetti ECR-350 User Programming
olivetti ECR-3550T
olivetti ECR-5000 User Programming
olivetti ECR-5100 User Programming
olivetti ECR-5700 User Programming
olivetti ECR-5800 User Programming
olivetti ECR-5900 User Programming
olivetti ECR-5920F User Programming
olivetti ECR-6100 User Programming
olivetti ECR-6700 User Programming
olivetti ECR-6800 User Programming
olivetti ECR-6900 User Programming
olivetti ECR-6920F User Programming
Jun 20, 2008 | Olivetti Office Equipment & Supplies
Uniden BC350C Base Scanner Logo
151 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
