Question about Sony Playstation 3 (PS3) Console
Error code 80028eo6 ps3 im wired straight to modem it has just started to do this i aint been able to get on for the last 2 days
  • 51 Answers
Is it a dialup modem?
Posted on May 05, 2010
I have no internetconnection with my ps3. I have error 80028ea6 Who can help me?
Good day. If your ps3 is not connecting to the internet. Try to do this steps:
1. Check all of the wire and cable from modem to router.
2. Make sure all cables are tight
3. Try to reboot your equipment on this sequence, modem - router - ps3
If these didn't resolve your issue you need to contact your Internet Service Provider to check your connection. Possible the modem is not getting any signal. If your modem is working good then contact the router support to check the settings with your router. But usually your Internet Service Provider will be able to resolve this issues. Hope this information will help you in resolving your connection problem. Have a great day and thanks for using Fixya.
Jun 23, 2011 | Computers & Internet
Im getting error 80130182 when trying to sign in
1st off you need to do a full reset on you modem and router, check you internet connection and make sure that your ISP isn't down, if you are running wireless try hard wiring the PS3 and see if you get the same error code and if those don't work try doing a simple system restore not a full restore.
Feb 09, 2011 | Sony Playstation 3 (PS3) Console
8002ad23 error code with no router
8002AD23 Found to be related to a connection issue Check to make sure firewall is off to see if that helps. (possibly network/update error) .
Jul 12, 2010 | Sony Playstation 3 (PS3) Console
My ps3 will start up my modern warfare 2 game but right before the part to press start to select what mode i want to play in it will pop up a system error code. Also when i try to just sign in outside of...
There is a worldwide issue with PSN at the moment:
We're aware that many of you are having problems connecting to PSN, and , we're looking into it. Stay tuned for updates. about 1 hours ago via web SonyPlayStation
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
How do i connect my ps3 to the internet if i dont have wifi?
Your PS3 supports both wired and wireless. Heres how I have mine set up, Ive been running wired since day 1. 1st- hook your ps3 up to your modem or router with an ethernet cable. {im assuming ps3 is plugged into the tv, if not hook it up}
2- go in to your network setting on ps3.. If you start at the far left go over click and all the way down. You will see network settings. click on it and go down to the 3rd option there.. Internet connection settings. You will get a pop up that says your ps3 will be disconnected from the internet if you proceed, just hit ok. It usually automatically detects if you have the ethernet cable plugged in but just in case it doesnt go ahead and select wired. after that, just select auto for everything else. You will go through about 5 questions and it will be ready to do an internet connection test. All should be well.
If that doesnt work, make sure all the cables are plugged in and try again.If you are able to connect to the internet after that but get booted off, go back into network settings again and disable the media server. Hope that helps.. Happy Gaming
Oct 24, 2009 | Sony Playstation 3 (PS3) Console
Can get to playstating network
you have to restart the modem and or router. then turn it back on then turn the ps3 on and check connection settings it should start working
Oct 05, 2009 | Sony Playstation 3 (PS3) Console
Dns error for ps3
O.K. I had just had that little problem out of nowhere 2 days ago! First off Reboot the Modem, then the Router. When they are done turn on the PS3. In the PS3 Menu go to the 2nd Row from the Left and Down to Network Settings. Choose your setup Wired or Wireless. Choose DHCP and AUTO all the way through. If you are Wireless you will need your CODE! When done wait a minute then run the Network test right below in the Menu. You should be Good! This should reset your Network Automatically!
May 04, 2009 | Sony Playstation 3 (PS3) Console
Unable to download system upgrade version 2.60
SETTINGS > NETWORK SETTINGS > INERNET CONNECTION SETTINGS > WIRED CONNECTION OR WIRELESS > WIRED CONNECTION > CUSTOM > MANUAL SETTINGS > AUTO DETECT > AUTOMATIC > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X WIRELESS > ENTER MANUALLY > ( ENTER SSID OR CONTINUE ) > ( CHOOSE SECURITY OR CONTINUE ) > CUSTOM > AUTO > DO NOT SET > MANUAL ( DNS1 : 208.67.222.222 , DNS2 : 208.67.220.220 ) > AUTO > DO NOT USE > ENABLE > X > X I thought I should clarify my experience one last time in hopes that it may help someone. I was able to connect fine for a month before the 1.50 update and then things got really wierd. I have gone through entire days unable to connect to the network and entire days able to connect. Meanwhile I had full use of the PS3 internet browser and no other computer or internet issues. I can currently confirm that if I return my PS3 internet settings the original "automatic" settings I will not be able to connect, with these DNS settings in the PS3 I have no problems. I have cable internet access through Adelphia with a Linksys WRT54GS router communicating wirelessly with my PS3... GOOD LUCK!
The information I used to create this fix contained a link that has provided us with router specific DNS information to be used if the numbers provided do not work. http://www.opendns.com/start/at_home.php
Now, a day later, I am able to connect with the original automatic settings for everything including DNS. I must also point out that the network performance is much faster using the automatic settings and recommend using alternate DNS settings only when neccessary.
All I can say for those still having problems is reboot EVERYTHING. Your router, modem, PS3 and any other device that may be connected to your network.
If you still have problems try connecting the ps3 directly to your modem not through the router...
Jan 23, 2009 | Sony Playstation 3 (PS3) Console
Disc read error
Hey, i bought a ps3 almost 2 years ago now, its been more reliable for me than my old ps2. i would try and phone them again if you aint recieved the case soon,
it does sometimes take a while for them to repair it and send it back ie if its the same console, they might just swap it for another ie once u get it sent away :-).
sounds like a problem with the laser, im sure you will see the case soon, and touch wood have no problems with the replacement ps3.
Jul 26, 2008 | Sony Playstation 3 (PS3) Console
Trying to get internet connection on my ps3
I once had the same problem. What i did is that i booted the modem and the Ps3 (turned both off) and then turned them on. Then i went to the internet settings on the Ps3 and tried the internet connection check and it worked! I hope you have some help of this.
Jan 14, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
384 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
