Question about AcerPower 2000-UD431C - Core 2 Duo E4300 1.8 GHz (S6463626) PC Desktop
Cant get an acerpower 2000. the light on the power supply is on but when i push the power button nothing turns on the fans seem to hesitate to spin but at the end they dont.
  • Jose Ferrer
    Jose Ferrer May 11, 2010
    Does your system beep at during the failed startup?
  • 51 Answers
Well, your fans are shot. Get them replaced and all should be well.
Posted on May 05, 2010
  • Larry Sobelman Nov 08, 2010
    Nah, fans are not the issue, there were 4 domed caps on the motherboard that needed to be replaced. that will fix it.
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
E-machine modem wont turn on the fan and little yellow light on bottom are on
This is not a full solution, it is a partial solution, and something I would like you to try;
1) Unplug the computer from power.
2) Press, and hold the Power On button in for a count of at least 5 seconds.
Let go of the Power On button.
Perform this procedure 2 more times.
3) Plug the computer back into power. WAIT 1 minute, turn the computer on.
If the computer doesn't turn on you have a bad Power Supply.
Weak voltage power rail
Computer may have enough power to light LED lights, and perhaps spin fans, but not enough power to turn the Processor on.
A) If ALL of the LED lights were on at once, they would use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use from 51 to 125 Watts of power.
Maximum power consumption will depend on what Processor it is.
So you see a Power Supply with a weak voltage power rail, will have enough power to light LED lights, and perhaps spin fans, but not enough power to turn the Processor on.
[ You press the Power On button.
The first chipset on the motherboard to receive power, is the BIOS chipset. { Basic Input/Output System}
BIOS looks to see what devices are installed, does a Ram Memory count, turns the Processor on, then hands the computer over to the Operating System.
{Windows XP and Windows 7, are but two examples of an O/S }
I do not see what model number of eMachines you have, listed here.
If it is Not one of the slimline models, you may want to try swapping the Power Supply with a KNOWN to be good one.
I post this with the thought in mind, that there may be an unused desktop computer around, and perhaps you could borrow it's Power Supply for a test unit.
This may sound far fetched, as far as having a spare working desktop computer around, but I have had a reply from a poster who stated their relative had one.
If the Power Supply works, you know what the problem is, and how to solve it. Replace the Power Supply.
Replacing a Power Supply in a desktop computer may seem daunting, if you have never performed this procedure before.
It really isn't.
I can guide you on here, and add links which I believe may be beneficial.
Post back in a Comment.
Regards,
joecoolvette
Jan 03, 2012 | E-Machines eMachines Desktop PC
HP pavilion a705W pc desktop/ on back by power plugin, green light is on, push power button to turn on, light goes out and nothing happens. I opened panels and observed light again on back lite green and...
if you have installed a new hardware, that might be the cause. specially if it is a video card. The wattage of your power supply might not be enough to run the computer. try to remove newly installed hardware such as video card. If there is none, you may try to remove the power for the hard drive and the dvd drive and check if it will turn on. Just bood in to bios..
if that works, then it definitely is the power supply. it cant provide sufficient power to your equipment..
hope that works.
regards.
May 07, 2011 | HP Pavilion a705w PC Desktop
I put a new bulb in the tv about 3 months ago. I was watching the tv the other day and turned it off when done. I went to turn it back on the other day and it does nothing, no red, green, yellow blinking...
Try pushing in the reset button on the front panel, its very small and you will need a pin to push it in. Do this while the TV is plugged in, then power it on again see what it does. If still nothing then the FMT board is developing a known fault. You will need to replace the FMT board if reset doesn't work....
Also..
It could be a fan issue, if one of the fans in the TV stop working this will cause the TV not to power up too.
Let me know what you find...
http://tvtechwork.webs.com/
Nov 10, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Acerpower sv wont turn on, the fan only keep spinning with no display. And no signal beeps
Good day.
Primary culprit is your motherboard and the processor. But just to be sure, check your power supply cables going to your board and the voltage. Next, to isolate the problem and the board/cpu, remove all the device (cards, memory, drives, etc.) then power on, if there still no beeps then your board is dead, no way to check for the processor unless you have a good processor.
Good luck
Ted
Sep 13, 2010 | AcerPower SV PC Desktop
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
I have a AcerPower 2000 desktop computer, when plugged in the fans run but I am unable to start the computer, no other lights are on.
Hi fspade
If you're lucky this could be very simple:
- Unplug the power from the back of the unit.
- Press the power button a couple of times.
- Wait 10 seconds.
- Plug the power back in and try and turn on.
If the above doesn't work then most likely there is an internal part failure (normally the power unit). I would take it somewhere to get checked out.
Hope this helps
Scott.
Feb 01, 2010 | AcerPower 2000-UD431C - Core 2 Duo E4300...
New power supply
CHECK YOUR POWER CORD CHECK YOUR ELECTRICITY THAT LINE IS WORKING
Sep 27, 2008 | Gateway 830GM PC Desktop
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
AcerPower 2000-UD431C - Core 2 Duo E4300 1.8 GHz (S6463626) PC Desktop Logo
285 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
