Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I need to charge the battery
But, I don't see where I hook up the charger. We don't have the manual anymore. I know to hook positive to positive etc...but where are those located on my mower?
I have a craftsman 17hp 42" riding lawn mower.
  • 284 Answers
Check under the seat and possibly under another plastic cover
Posted on May 06, 2010
I have a Schumacher 6/2 amp dual charger, SE-82-6. I took off the clamps. Now don't know which wire is positive. One has a white line on it.
Get a volt meter and hook up the test probes to the cable ends and turn the meter on, the meter will say 12 or -12 if it says 12 then you have the red and black from the meter connected to the red and black on the charger in the right manner, if it says -12 then you have them reversed. Take the cable clamps and put them back on.
Mar 01, 2016 | Schumacher SE82-6 Manual Charger...
I don't have a manual for my small Black & Decker Smart Charger. I'm trying to charge the battery on my '07 Honda Rebel 250cc. It has settings for 2/6/12 volt batteries. How do I hook it...
You just need to set black & decker charger to 12V . Don't make mistake while connecting + / - leads. + lead usually come with Red color cable. You can use the AVO tester to justify the lead cable. The charging time is normally about 10 -12 hours (or just just check the status on your charger display). If your charger does not has trickle charge facility, you have to disconnect your charger after 12 hours continuous use.
Also, you can find the guidance about your charger here :
www.blackanddecker.com/power-tools/VEC1087CBD.aspx
Regards
Sep 22, 2011 | Honda CB 250 Motorcycles
HOW DO I CHARGE THE BATTERY ?
In the hood of the jeep there is the battery. The jeep should of came with a plug-in quick charger that fits in a general outlet. Simply unplug the battery, and plug it into your wall in the house, etc.
Sep 04, 2011 | Fisher Price Power Wheels Barbie Jammin'...
The electronic throttle control light is on in my dodge magnum and my car is stalled what do I do to fix it?
Your throttle pedal is electronic and not controled by cables anymore. So there is sensor that sense's what postion your throttle body needs to be opened or closed. The sensor probably needs to be replaced.
The whole pedal assembly will have to come out and be replaced as it is all one unit. They are easy to take out. I learned about these at the SRT Track Expereince when the Charger that I was driving stopped having so much go and the ETC light came on. They showed us how to replace them and told us that they have to replace them all the time and keep them in stock due to people mashing the pedal. It is all plastic and you don't have to mash these like the old system.
You can try resetting the ETC as well. Place your car in the run position without starting and depress the gas pedal and release all in 2 seconds (1 down and 1 up). You should hear a confirmation "ding" if done correctly and you have know reset the sensor to know when you have open throttle.
You are still safe to drive your vehicle but you need to get it fixed or you are not going to get good performance.
May 25, 2011 | 2005 Dodge Magnum
USING PERKO SWITCH HOW DO I POSITION SWITCH USING 120 VOLT AC CHARGER USING 2 MARINE BATTERIES AND WHAT TERMINALS ON BATTERIES DO I HOOK UP ALLIGATOR CHARGING CLIPS? THANK YOU DON
Hi Don!
If you wish to charge one battery at a time, the switch should be set to "off". Charger clips will connected to the batt you wish to charge hot-to-hot and cold-to-cold. If you want to charge both batts at once (not really recommended) switch set to "all".
Hope this helps.
Mar 26, 2011 | Perko Battery Selector Switches Ignition...
Golden buzzaround scooter - new around 2003? 3-wheel - need to know how to hook up the batteries - not sure we have them hooked up correctly.
If you go this link it will show you the connections for the battery pack wiring. Essentially there is a jumper between one of the positive terminals on one battery and one of the negative terminals of the other battery to give you 24 to 27 volts in series. The two remaining terminals are for the positive and negative output voltage and the charger connections (run in parallel). Please see the following:
http://www.goldentech.com/pdf/support/ride/gb101-service-manual.pdf
Feb 20, 2011 | Golden Technologies Health & Beauty
Location of negative battery charge ground
I don' know what you are asking. The "positive terminal" on the battery is marked + the "negative teminal" is marked - . Are trying to hook up a battery charger?
Jan 08, 2010 | 1999 Ford Explorer
Samsung u740 wont charge anymore
Bad battery, you can get one pretty cheap off of www.uxcell.com for like 3 or 4 bucks, as far as using a generic charger, I never heard of that before, if you know someone with the same phone, ask yhem to use the battery for a second, and try to charge your phone.
Sep 24, 2009 | Samsung SCH-u740 Cellular Phone
Need to charge battery on my chevy venture. Please show me how
Okay... One can not see the negative battery terminal so.... Connect the negative clip from your charger to the chassis and then remove the RED plastic cover in front of the black relay box above the battery OR the plastic cover from the positive battery terminal and connect the positive cable. Make sure you have good connections by watching the meter on your charger. Then plug in the charger and turn it on. Charge time depends on the strength of your charger. I'm going to go hook mine up again because I need to go out for a bit. I don't think I'm going to like changing this battery..... Just thought I'd share..... Good luck.
Sep 19, 2009 | 1999 Chevrolet Venture
How do i connect a battery charger
I suppose this is what you want to know
The battery charger has 2 leads coming off it as well as the power lead to the external power source .THE TWO LEADS WITH CLAMPS ON GO TO THE BATTERY THE RED GOES TO THE POSITIVE TERMINAL PLUS SIGN AND THE BLACK GOES TO THE NEGATIVE TERMINAL.MINUS SIGN, THE POWER LEAD PLUGS INTO THE POWER. AND THAT IS ALL THERE IS TO IT..
Sep 10, 2009 | 2002 Mitsubishi Lancer
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
103 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
