Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
I can not get convergence to work.
I have a sony kp 51wss20. And Im haveing problems getting the convergence to work. When I try to get the crosses to line up they wont move, the red, blue or yellow. I followed the manul But no go.
  • Sony Master
  • 8,617 Answers
You will need to install a convergence repair kit. The Sony type 1 convergence kit from www.tvrepairworld.com is the correct one for your model, the kit contains the CD with instructions plus the replacement parts.
Posted on May 08, 2010
I have a Sony KP-57WS510 and am having problems converging. The red works fine however the blue cross on the outside colums of the convergence pattern is off to the left. I am unable to move these blue...
The tv convergence board it is dead.The tv convergence board require replacing 2 STK convergence ICS and some or all of it resistors too.U have all the tools and also can do soldering ICS works?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a complete convergence kit parts for ur tv model and repair it ur self.Or the tv shop,will cost u like $300-350 for parts and labors.
Apr 23, 2011 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
I stumbled across a tutorial on fixing the convergence for my Sony KP-46WT510 a while ago, and now I can't find it again! Does anyone know where I can find that tutorial or one similar to it? We've been...
Here is a walk through on how to set your convergence.
A quick and easy way to try and let the TV realign the convergence try this...
1) Turn on the TV and tune to a channel and let it warm up for about a half an hour to let everything settle into its normal operating mode.
2) Press the Flash Focus button on the original TV remote. A cross pattern will show on the screen and the process is complete when the cross turns white and the TV returns to the program you were watching.
3) Do not press any other buttons until this process has completed.
If this does not adjust it enough you can adjust the convergence manually as follows:
1) Press the menu button on the original TV remote.
2) Use the arrow keys on the remote to highlight setup and press + button to select.
3) Use arrow keys to select convergence and press + button to select.
4) A pattern of white crosses appears, with a yellow [ ] around one of the
crosses. Aligned crosses (which do not need adjustment) look white and
have little or no red or blue showing. Crosses that are not aligned show
red or blue shades beyond their edges.
5) Use the arrow keys to move the [ ] to a cross that is not aligned. ***Note: start with crosses in the middle and work outward ****
*** TIP: Set the alignment while about 5 feet from TV for better results ****
6) Press the + button to select the cross and the [ ] will turn red indicating it is ready to adjust the Red convergence.
7) Use the arrow keys to move the red cross on top of the white one or at least as close as you can get it.
8) Once the Red is aligned press the + key again and the [ ] will turn blue. This indicates it is now ready to adjust the blue convergence.
9) Use the arrow keys to move the blue cross on top of the white one or at least as close as you can get it.
10) Once you have aligned the blue cross press the + button again and the [ ] should turn yellow.
11) Repeat steps 5 through 10 until all the crosses are aligned. To exit back to regular programming press the menu button on the remote.
Jan 08, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Flash focus
You need to get into service mode if flash focus does not work. Of course you have to fix the convergence problem first or neither modes will help
Sep 25, 2009 | Sony KP-53S65 53" Rear Projection...
RED SHADOW AROUND IMAGES of SONY KP-57WS510 RPCRT
Your set uses two STK392-560 convergence ICs they are attached to a large heat sink on the D board. You can save your self about 400 for a twenty minute repair by getting new ICs at the following link as trhey provide free instalation instructions with pics so you can do the job yourself. It only requires basic soldering skills I would order about six 4.7ohm 1/2 watt resistors as well just in case you need them asusually sonys' will burn one or two of the 4.7ohm convergence resistors when the ICs fail. Heres the link
http://servicemanuals.vstore.ca/
May 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
SONY KP 413SU
Sony convergence problems
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
look for the board that has heavy heat sinks on them the ic will be stk392-XXX
no experience in soldering i would send the board into ptscorp.com and have them repair it.
Dec 06, 2007 | Sony KP-41T65 41" Rear Projection...
Sony KP57WV700 Convergence problem
Problem could be low voltage from power supply as well as the amp ic for the convergence board. Need to take voltage readings from the test points on the board and compare them to the readings you should be getting from the service manual.
Jun 23, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
96 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
