Question about Miele 30 in. KM443 Electric Cooktop
Display blinks and then lights go out
Switch circuit breaker on and the lights on the cooktop start blinking. The lights blink for about 5 seconds and then go out. After that, no display lights appear. This cooktop has never been used.
I have the same problem. i've been on the phone with Miele tech support. i'll let you know if i have any luck.
Posted on Aug 04, 2008
How do i shut off hot service light and cool the burner
Good Afternoon Friend,
I understand you want to know how to turn the "Hot" service light, and cool the burner on your Frigidaire cooktop, model# GLEC30S8. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any burner. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 03, 2014 | Frigidaire 31 in. GLEC30S8 Electric...
I was trying to on oven all of a sudden massage appear f10
Hi khan, this is Z! Thank you for your post!
Typically error code F10 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. I suggest waiting approximately ten minutes and then turn on your range. If the error code does not clear, I would recommend contacting a professional technician to assist you in the exact diagnosis and repair of your range. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Mar 29, 2014 | Frigidaire Gas & Electric Stove/Oven/Range...
I have a GE 36" Profile Gas Cooktop JGP963 and when i light one of the burners, it trips the GFCI , main breaker and a little fire ball comes from under the knob. what could cause this?
IT SOUNDS LIKE YOU HAVE A SHORT IN THE IGNITER. YOUR COOKTOP SHOULD BE ON A DEDICATED CIRCUIT AND NOT A GFCI. YOU MIGHT HAVE TWO CIRCUITS TIED INTO THE SAME RUN. POPPING THE GFCI AND THE MAIN BREAKER IS SUSPECT. THE GFCI SHOULD SHUT DOWN THE CIRCUIT WITHOUT POPPING THE MAIN. THIS IS PROBLEM THAT SHOULD BE LOOKED AT BY AND ELECTRITION.
Apr 04, 2013 | GE 36 in. Profile JGP963 Gas Cooktop
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
The cooktop will not turn on. The little red light in the lower right corner of the touch panel is blinking. If one touches and holds it it does not turn on a burner per usual. The timer function works....
I'm going to assume this is a new installation, either way, it sounds as if you're only getting one leg of your 220v circuit, which wld run the timer and lights but not enough to power the burners. This is prly not something you shld try and repair yourself as a 220v circuit can cause some serious damage. At the least, you could first, TURN OFF THE BREAKER and then check the connections to the cooktop to make sure all connections are secure.
Jun 11, 2010 | Gaggenau CK 171 28 in. Electric Cooktop
Wolf Induction cooktop is locked in Showroom mode
If Shr (5hr) appears on the display then the cooktop is in showroom mode. To exit showroom mode the cooktop must be locked by pressing and holding the key symbol for 5 seconds. After the cooktop is locked, press and hold the melt touch pad for 5 seconds.
May 01, 2010 | LG 30" Built-In Electric Induction Cooktop...
Cooktop is locked out on digital kenmore unit, already tried cutting circuit breaker and waiting 5 minutes, that unlocked the oven but not the cooktop
Hi and welcome to FixYa. I am Kelly
I could be of much better help with a complete model number I.e. (example 110.XXXXX)
The wait is supposed to be 10 minutes. go back and turn off your breaker by "Physically" pushing it with conviction to the OFF position and wait 10 minutes.
If after 10 minutes the cooktop is STILL locked:
Push the touch pad that looks like a padlock for at least 5 seconds. The lock light should go out.
If it does not go out I will need your model number to go any further.
Thanks for using FixYa and I will be watching for your response.
Kelly
Feb 18, 2010 | Cooktops
Popping noise and red light
it could be a switch, element or a short somewhere else
Apr 29, 2009 | Kenmore 30 in. 42701 / 42702 / 42709...
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Wont turn on, LED just blinking
Couldent find any help, pushed the small switch until display reacted then touched the touch fields one by one in order from top left until the display showed nine. Then beep it all worked again !
Gggenau offered a rep at 400-500 eur for this ! Shame on them !
S:DOlberg
Jan 15, 2009 | Gaggenau 28 in. CK 171 Electric Cooktop
Miele 30 in. KM443 Electric Cooktop Logo
239 people viewed this question
Top Miele Cooktops Experts
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
