Question about Toshiba Satellite M115-S3094 Notebook
I would like to replace the dvd burner and would like to know how to remove the old one from the system
    Scholar:
  • 91 Answers
Http://www.videojug.com/film/how-to-install-or-change-my-computers-optical-drive for a desktop.
for laptops i suggest contacting the laptop maker and asking them what would work best for you and then trying to find it on Newegg.com .
Otherwise buy an external dvd burner and use that inplace of the internal drive.
Posted on May 05, 2010
I need the install cd.
if the system is really old it may not accept the dvd burner .the system has to be big enough have enough space in HDD for the program and have a processor big enough to run it also .
Jul 30, 2015 | HP Hewlett Packard HP DVD557S 8x USB Slim...
My dvd-ram doesnt read original dvd,why?what can i do i have to do to makeit work?when i insert the original dvd it doesnt appear on pc.thank you
Hi lorena,
    Here is what I suggest you try.
  • Download and install CCleaner (free) from Piriform- http://www.piriform.com/ccleaner
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
If this does not resolve your problem, try the following
If VLC will not play a CD/DVD, try this,
    • Use the Device Manager and uninstall the burners drivers
    • Run the Registry cleaner in CCleaner again, this time in Windows Safe Mode. Remember to backup the Registry
    • Reboot, Windows should reinstall the DVD burner
If you take all these step and you still can not play a CD/DVD, chances are your CD/DVD componet needs to be replaced. Good Luck,
    • If this helps resolve your issue, would you please rate the solution.
Dec 29, 2010 | LG GSA-H55N DVD-RAM Burner
I am getting an error message that says : could not preform end of disc-at-once
Hi Aubri,
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not burn a DVD, chances are your DVD burner componet needs to be replaced. Good Luck.
Dec 29, 2010 | Gear Head 8XDVDEXT DVD External Slim...
Its junk
Hi Popevil,
    • Reboot
Dec 29, 2010 | Memorex (cdw-40emax-pb-r) CD-RW Burner
I cannot get the dvds to burn it says drive not presant
Hi Bramam,
    • Reboot
Dec 28, 2010 | Gear Head 8XDVDEXT DVD External Slim...
Write error on first write
HI Robert,
    • Reboot
If you take all these step and you still can not burn a DVD, chances are your DVD burner needs to be replaced. Good Luck.
Dec 28, 2010 | Sony DRX-830U (027242700338) DVD RW Dual...
My cd burner will not burn cd's. it just makes a funny sound and pops up insert disc.
If the system is not in warantee, you will need to replace the CD burner drive. You can generally find a replacement for around $30. Depending on where you live you can find one locally or online.
Replacement is very easy.
Open the system to access the old CD burner, make sure you take note of where the cables (power and interface cable). Remove the old CD burner and replace it with the new CD burner replacing the power and interface cable.
If I were you, I would op for a CD/DVD burner so that you can read and write both CD;s and DVD's. Cost should be around $40.
Jul 14, 2009 | E-Machines emachines (emachinees) CD-ROM...
Cannot detect the CD burner
just restart system if it not resolved problem then remove cd/dvd Writer & reinsert it. May be some connector lose or burner not able to communicate with main board.
Jul 10, 2009 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
SH-S182 installation
before anything else.. your computer must not be plugged in
have some screw drivers ready
open the case
remove the connections of your old cd/dvd-rom
remove the screws
remove the drive from the bay
replace it with your new dvd writer
replace the connections and the screws
put everything else back
then turn on your system :D
Nov 02, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
How to install a dvd burner
First you shutdown your computer, then disconnect all power cords. I don't know if you have a tower or a deskpro, with the tower just slide the panel out pulling from the back, you may have to remove a piece from the front with a tower. Pay attension to how your cd rom is hooked up, I don't know if this is a combo (cd/dvd/RW) if it's a combo, if it is a combo you would have to take out the old drive and replace with the new, just pay attenion to how the old drive is hooked there should be two cords to connect to .  If there separate drives there should be an empty bay.  Let me know how your doing, and if I can assist you more.........Thanks, Heidi
Oct 19, 2007 | Computers & Internet
Toshiba Satellite M115-S3094 Notebook Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
