Washing machine stops working when door light goes out part way through cycle. I have to switch off and restart by giving door a thump. This seems to happen mostly during rinse cycle, but sometimes drum does not turn and it just fills with water. When it does work it washes, spins and will also dry. I always have to start machine with a thump to door. Any suggestions, please.
  • mobrien663 May 06, 2010
    Thanks for your prompt reply. The washing machine is a Zanussi WDJ 1500 washer/dryer. I cannot find the nylon band around the front door seal.
    I think you are right in your suggestion that I contact my local serviceman.
  • 269 Answers
I do not know the model of your machine but if you have to keep hitting the door then I would most certainly suspect that the door switch is the fault.
If you are handy with DIY.Then you could replace this switch yourself.Make sure the power is off,remove the nylon band around the front door seal,If it is an Electrolux machine remove the 2 screws holding the switch remove plug or if seperate wires make note of where they were on switch.Fit new switch and refit door rubber and the nylon clamp compress with big pliars and run machine.If switch is left as it is you could end up damaging the Programmer.If not sure I would get the local service man to call out.
Hope this helps.
Good Luck.
Posted on May 05, 2010
I have a FE WCVH6260. Multiple times every cycle the machine door will unlock, and the cycle will stop. It will only restart when the "start/stop" button is pushed again.
WHAT IS WRONG WITH YOUR WASHING MACHINE?
small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
Aug 11, 2008 | GE Washing Machines
Indesit Washing machine WIL88 red light flashing
Seems that the main board or the processor is hanging up and does not take up the full process control. You need to remove the panel and check for moisture on the board, check for loose connectors. If this seems fine the fault seems related to the board and can be confirmed with a board swap before one can be ordered. Check the door switch and wiring to the main board.
Jun 03, 2013 | Washing Machines
We have a Whirlpool 7KG frontloader washing machine (6th sense) model AWM8121. The problem is that the door light is flashing, the cycle has stopped at rinse (rinse light is on) and the machine is not...
We have an awm8121 and there seems to be a fault on the Spin cycle indicators with th 0 RPM and the 800 RPM flashing..
We can't seem to get the frontloader to finish the drain cycle and continue into the next was.
The last load of washing was still saturated when we managed to open the door.
Apr 20, 2011 | Whirlpool AWM8123 Front Load Washer
Whirlpool washer spin cycle works off and on
no the slowing down maybe caused by a sticking clutch and as before the lid switch may also be broken if when you depress it the reason i'll give is if you bump it it sometimes starts up replace the lid switch and once done the circiut will close properly then the delicate cyc should work
Aug 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
DE code on WM0642HW TROMM washing machine We've been getting this error code on our washing machine for some time. The code is coming up quite frequently now. It stops the cycle so the load is not...
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Jul 11, 2009 | LG Washing Machines
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
Washing machine prob
You need to replace the door interlock. Try giving the handle a firm push and see if the machine will start.
Oct 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
