Question about Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum
It leaves several dust lines on my carpet
My vacuum had a clog but i have since then removed it. every time i use it, it leaves several dust lines on my carpet. could this mean that i need a new filter. i took the one filter off and washed it but that didnt help.
  • 20 Answers
Still plugged somewhere .start at hose.
Posted on May 06, 2010
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
The vacuum has a lack of suction compared to when we bought it 6 months ago
Clean all filters and if there is a hose it could be partially plugged as well. Take hose off and shove something like a dry water hose through it.There is usually a filter back of the dirt bag as well. If it has been used to vac up drywall dust the dust bag will plug up before its filled as the dust is so fine it will plug up every thing on the vac. Really clean every thing and it will work better.
Apr 12, 2015 | Vacuums
No suction at all
No suction means there is a clog or restriction somewhere or the filters need replaced.
Mar 29, 2015 | Vacuums
My dyson dc14 leaves lines on my carpet why?
Hi Geoff, it's Jack at Dyson.
To answer your question effectively we would need to understand a bit more about the type of lines your DC14 is leaving in the carpeting. The rotating brush bar sweeps into the carpet pile to remove ground-in dirt and pet hair. The bristle tufts can have the effect of raising the pile where it's been trodden flat from use. Equally, as with any upright vacuum, the two rear wheels can leave temporary impressions in the carpet pile, which may be more noticeable in deeper pile carpeting.
We wouldn't expect the machine to leave other types of lines, and we'd like to help you check the soleplate and brush bar are undamaged, and fitted and working correctly.
When you have your DC14 easily to hand, please contact the Dyson Customer Helpline. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 23, 2015 | Dyson Vacuums
Its not turning brushes all the time & it has very little to no suction on floor or hand tool modes
HI, it's Jim from Crucial Vacuum!
If your vacuum is experiencing difficulties with suction there are several places you can check to help your vacuum operate at its peak performance. After applying these solutions you should see an improvement in your vacuums suction and the maneuverability of the brush roll.
Lets check out your brush roll first since that's experiencing issues with turning. Look for any noticeable debris, and be sure to manually rotate the brush roll to unearth any hidden clogs that may be behind your brush roll. If you see carpet fibers, or strands of hair remove these with a razor, or scissor.
How do the bristles look on the brush roll? If they're loose, or look worn down then it may be time to replace the brush entirely.
Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight. If your brush roll isn't operating properly it won't be able to pick up dirt and debris.
Be sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction for your vacuum.
If you're also getting little to no suction from your vacuums hose and attachments then check your vacuums hose for a clog. Stretch it out as far as you can to unblock any clogs. If there is a clog in a hard to reach spot try using a broom handle to reach the area.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 01, 2015 | Vacuums
Eureka airspeed one leaves lines of dust
I suspect your vacuum has a blockage deeper than you searched.
Jan 10, 2014 | Vacuums
Bissell carpet cleaner does not suction
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 17, 2012 | Bissell 1699 ProHeat Clear View Upright...
Hoover Core Plus Vacuum Cleaner is no longer cleaning properly. The button on the handle which when turned on has before allowed for a more efficient cleaning of my carpets and allowing easier movement...
Simple. The dirt sucked in is trapped inside a bag with tiny holes. Once these holes are clogged, the vacuum cleaner cannot do its job efficiently. Remove the 'bag' by opening the back, clean it of dust (do not wash it), replace it and close the cover. The cleaner will do its job properly again!
Jun 19, 2017 | Vacuums
Carpet setting: the brush drive does not work with the carpet setting. Is there a way to remove the bottom to determine if something is caught in the system?
To determine if you have a clog, first remove the attachment hose like you were going to put an attachment on. With the vacuum in the upright position, turn the vacuum on and place your hand over the hose. Do you feel a strong suction? If not remove the hose attachment by turning the locking ring at the end of the hose on the back of the vacuum counterclockwise, then remove the hose. Stretch the hose to it's fullest length several times. I would do this over some plastic or outside to keep the dust down.
Once you have done this replace the hose turning the locking ring clockwise to lock it in place, give the hose a little tug to make sure it's attached and locked.
Again, with the hose free from the agitator turn the vacuum on and fee for a good suction.
If you still don't have one then you likely have a plugged filter.
You will need to remove the dust bin.44d2af9.jpgOnce the dust bin is removed, over you trash can empty it by pressing the dustbin door release downwards. Now rotate the dustbin lid counterclockwise to remove the primary filter. With the lid removed grasp the filter and turn counterclockwise to remove the filter.
Pull the filter out over a trash can. Once out inspect it, if it's dirty you should wash the filter in warm water until the water is clear. When finish let the filter air dry for 24 hours before reinserting it.
Upon reinserting the filter, turn it clockwise to lock it in place, install the filter cover with a clockwise rotation to lock it in place and reinstall the dust bin.
Now plug the vacuum back in and again with the hose removed from the agitator or brush and ready to install an attachment then the vacuum on and you should have a solid suction.
These vacuums are really prone to poor suction if the filter get dirty. Because they have washable filters, you should take time about one a month to clean the filters.
Thanks Dorrian
Aug 13, 2010 | Kenmore Progressive Bagless Upright with...
Dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
May 30, 2007 | Bissell 3522 PowerForce Bagged Upright...
Eureka Whirlwind 4388 Bagless Upright Cyclonic Vacuum Logo
293 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
