Question about Bosch Axxis WTL 6307 Electric Dryer
Bosch dryer won't start
Bosch Axxis dryer's lights come on, but we hit the "start" button and nothing happens. Problem began one night after we did several loads. I figured all would be well in the morning, after a cool-down period, but dryer still won't start. I've cleaned the heat exchanger, but still it won't start. Blown fuse? Is there a reset switch? Door seems to close fully. Axxis dryer is about 3-4 years old (best guess -- we are not original owners). It's a condenser dryer -- not vented to outside.
  • 11 Answers
SOURCE: Dryer drum will not turn
check to see if there is a little red button on the back if so push it in thats your re-set button
Posted on Mar 24, 2009
SOURCE: Bosch Axxis Condensation dryer not working
Try to vacuum clean inside the door contact breaker (female part). If you can remove the dust it should start working again.
Posted on Aug 01, 2009
  • 191 Answers
SOURCE: Error Code
open the thing up and locate the service manual. once located it should list what that error means. alternatively call bosch and ask them.
Posted on Aug 25, 2009
apart4u
  • 213 Answers
SOURCE: Bosch Axxis WTL5410 condensation dryer does not heat up
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Posted on Jan 13, 2010
  • 51 Answers
SOURCE: WTL 5410 BOSCH AXXIS CONDENSATION ELECTRIC DRYER
the thermostats at the element have to be replaced, they burn out prematurely if the condensor unit is not cleaned on a regular basis.
Posted on Feb 02, 2010
Bosch tumble dryer
Try holding down the start button for 10 sec's to reset it.
Jan 15, 2014 | Dryers
Bosch Dryer WTL 5410 UC do nothing after selecting a program and hitting the start button. The only thing that happens is that the Drying light lits and nothing else happens. I have tried to hit start...
Door switch may still be your problem. Mine showed lights as if working when closed but I decided to use a screwdriver and push in switch all the way in. It worked then without door closed. It will stay stuck until you pull it own a bit to release it. Give it a try. The door switch appears to have two switches in it requiring it to be all the way in.
Aug 12, 2011 | Bosch Axxis WTL 5400 Dryer
Hello, I have a Bosch Axxis electric dryer that when i turn it on and hit the start button the light comes on telling me that the unit has started but it is not spinning. Also there is not any heat being...
Hi, Welcome to FixYa. If you turn the drum by hand do you feel any airflow out the back ? (you need to undo the vent hose too) This will tell you if the belt is broke. Let me know and we can go forward from there. Regards, Macmarkus :)
Mar 21, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Bosch axiss dryer WTA3510US wont run checked power, fuses. i close the door hit start the drying light comes on but nothing happens no clicks noies's nothing. is it the relay board or somthing else?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 14, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Everything on the dryer indicates that it is working but nothing happens when I push start
The push start button may be gone. U have to get to the wires to bypass the botton to know for sure if this is your problem......Hope this helps.
Aug 12, 2010 | Bosch Axxis WTA 3510 Electric Dryer
I press the start button, the light goes on but nothing happens
I had the same problem. It is the door latch. It cost about $150 to fix. I can't believe the tech didn't know it. It is very common for Bosch Dryers after about 3-4 years old.
Jul 11, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Jun 08, 2009 | Bosch Axxis WTL 5400 Dryer
Bosch axxis wtl 5400 dryer
I found that the dryer will not start because the door isn't fully closed. My wife has basically split the plastic door a bit, but if you firmly close the door, it will start.
Jul 25, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch Dryer misfunction
Check the fuse. This is a German unit, so every part including the light bulb is 208/240 volts. If the fuse for the dryer on the back is open the unit will not start.
Nov 18, 2007 | Bosch Axxis WTA 3510 Electric Dryer
Bosch Axxis WTL 6307 Electric Dryer Logo
259 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
