Question about Lincoln Electric K1170 AC-225 Stick Welder
MY WELDER WILL NOT STRIKE AN ARC, I took the rod right to the ground lead clamp, nothing, the fan comes on & welder is running, but no juice. This happened once before, about a year ago, I disassembled the welder looking for loose connections, inspected everthing, did not find anything, reassembled & the welder went back to work. Now it's doing it again. any insight?
    Scholar:
  • 173 Answers
Check the transformer for voltage. Also disabled. And clean all connections
Posted on Oct 03, 2012
  • brandon day Oct 03, 2012
My dad has the same problem.he says it need an exciter.
Posted on Jun 30, 2010
Welder is not sending strong arc
maybe its your volts too. make sure you are grounded properly and clean from debri's, strike the electrode like a match and keep the arc close to your work-piece. dont go too fast and make sure your not wearing to strong of a lens in your hood. gold lens number 10 are the best for 7018 rods.
Jan 27, 2013 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welder wont strike and keep an ark
Check the output voltage of the welder (the torch and earth clamp). The voltage should be around 30 to 40 volts. If yu see the normal spark from the rod as you strike, but cannot hold an arc, have a look at your rods, they could be old, damp or incorrect for your welder or the type of work you are attempting.
Jan 19, 2011 | Hobart Welding Tools
WHEN I TRY STRIKE AN ARC WITH A ROD YOU HAVE TO HIT IT 5 OR 6 TIMES TO GET IT TO WELD ITS HARD TO KEEP IT GOING BUT AFTER 4 OR 5 SECONDS IT WILL BURN LIKE NORMAL (USING PROPER AMPERAGE)
Is this on new rods as well as one's you'be been already welding with? Depending on rod types, some will "flux over" the end, after welding insulating the tip. When you're welding at a low setting, with a small rod, sometimes it is hard to start an arc. A 7018 rod is a good example of this. Strike the rod like a woodden match, or drag it on the metal, to expose the rod. It also depends on your welder. Some have settings to help start an arc and then control the current. Older transformer welders arn't that smart and are less forgiving on low current thin metal settings.
Jul 02, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
Will not arc
Check ground connection at welder along with your ground clamp. Bad connection could be the issue. Also check settings on your welder.
Apr 23, 2010 | Hobart Welders IronMan 210 MIG 500304A...
Everything comes on and the wire feeds. However it
Check that your ground clamp is connected to the work piece securely.
Mar 14, 2010 | Clarke Power Products Clarke 130EN...
Problems with welding with a Forney 180 amp. Arc Stick Welder
check your input power connections on the primary side of the welders transformer, then if its an infinite control welder check that control,otherwise if it's a plug- in selectable amperage check these connections,it sounds like the infinite control is getting dirty and not passing all the current it shows on the control, also double your O.C.V. on the secondary and see if its with-in welder specs
Nov 15, 2009 | Welding Tools
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
I have a speedline 180 amp arc welder and it doesn't want to arc i turn welder on it makes the nose its spose to make and i connect my earth go to strike and nothing happens? any ideas??
Check for output voltage (ac or DC depending on model).No voltage,welder has a problem.
You must have a clean ground clamp attached to bare metal with some welders to make them work.
Sep 08, 2009 | ARC Welding Tools
Lincoln Electric K1170 AC-225 Stick Welder Logo
702 people viewed this question
Top Lincoln Welding Tools Experts
Steve
Robert Monigold
Robert Monigold
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
