Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
2004 v twin 16 hp 500hours on it runs but spits fuel throught carb when giving gas runs like its missing on one cylinder replaced carb, plugs, fuel filter, it has 120 lbs of compression in each cylinder spark plugs are black will start & everytime ruff idle and seems like has blow by through intake spitting fuel through it when giving gas??
  • Anonymous Mar 19, 2014
    has spark and compression
  • 755 Answers
You should take one of the heads off and look at the valves. You may have deposits building up no the valves.
120 pounds compression sounds pretty good for a six year old engine with 500 hours on it. It probably started life at 9 to 1 and now is around 8 to 1.
Posted on May 05, 2010
After changing the spark plugs, and riding the bike for about10 minutes, I heard a back fire , and the bike started smoking, and gasoline leaking throught the tail pipes.
When you drove it for 10 minutes did it work & run perfect without any missing? One cylinder possibly started missing backfired and then maybe the carb flooded some how. I would pull both plugs first. Have a look at the plugs, then you will be able to tell which one was missing (wet with fuel). Check compression on each cylinder and then check the carb. I hope this helps.
Jul 11, 2015 | 2002 Suzuki VS 800 Intruder
Spitting gas out of carb with new carb and plugs
could be the coil getting hot and loosing spark
Feb 22, 2013 | Garden
Gas shooting out top of carboratore on a 20 h.p turbo twin cylinder craftsman lawn tractor , idles fine but past idle starts spitting gas
This tells you that the carb is flooding out and needs to be rebuilt. Most likely the float in the carb has a leak and is sinking in the bowl.
May 05, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Bogs down & spits back through carb.
Sounds like you may need a valve job. Have you been keeping the valve clearances adjusted? It's important to do that on a four-stroke engine. Check your compression to find out if the valves are ok.
Sep 19, 2009 | Polaris ATV
I have a 2004 883 sportster, it keeps fouling out the front cylinder. when you take off from a light in low rpm it spits and sputers and just does not want to go. I have changed the ignigtion coil and...
u know if it iznt electric then u hav carb n compression left-do an inspec on the fuel system-low speed gas n air jet specially-mite want to buy a manual-always git other opinions 1st or ull keep being a partz replacer
Aug 16, 2009 | 2004 Harley Davidson XL 883 Sportster
Briggs and Stratton 16 hp v twin..replaced con rod and piston
Needle and seat not functioning ... float stuck or trash in needle and seat of carb.
Jul 08, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Have a 20 HP twin cylinder KOHLER engine on CRAFTSMAN mower.
If you are able...have someone do a compression check on the engine. Usually if a mower is loosing power and it is a twin cylinder engine, one of the headgaskets may be blown.
May 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Spitting and sputtering
mine did the same, I found out that the high speed jet was clogged, I pulled the fuel line off the filtor(going to the carb), stuck the line into a mixture of half gas half carb cleaner, I fanned it up and in 2 or 3 minutes it started running well, hope this helps.
May 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
767 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
