Question about Whirlpool Washing Machines
My whirlpool washer 3357978 will not run? I turn to each cycle, and can hear a little noise but it doesn't run?
  • 141 Answers
The problem may be the motor is short circuited kindly replace the motor, If problem exist check for the wire connection if everything is fine means then check for the main board of the machine
Posted on May 06, 2010
3357978 whirlpool: it would fill water to correct level but would not do the wash - there would just be a mechanical rattle. when i turn it off and move the dial to the spin cycle it would not spin but it...
look on bottom of unit... there is a drive coupling made of plastic that is in between the transmission shaft and connects the motor shaft . this is like a shear pin on a tractor when put under to much stress of just after wear will break to prevent damage to motor or transmission.,. it has three teeth on each piece and is connected by a black bushing in between the 2 pieces.. if the teeth break it will rattle and prevent the tub from turning... a very in expensive part to replace and have seen many people throw out perfectly good washers thinking the transmissions were bad and it was just a 10.00 part... good luck to you...
Feb 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine make loud noise after spin cycle quits. Noise continues until cycle winds down. Sounds like a machine gun being fired
Hello,have to tell you that most noises from a washing machine occur during the spin cycle. If you hear loud thumping noise during the spin, the load of cloth may have become unbalanced. Stop the washer and redistribute the cloths, then restart the machine. Repeat these steps if necessary.
Thanks
Jun 04, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Six year old Whirlpool 3357978 washer stops spinning violently
the bowden cable requires adjusting like the brakes on a push bike
Nov 17, 2009 | Washing Machines
Washer doesn't spin, just makes funny noise.
i would change the coupler between the motor and transmission.... whirlpoolpartssurplus.com
Jun 23, 2009 | Whirlpool Washing Machines
Washer will not agitate or spin
it looks to me u need a new motor as the one u have is burned out...this is the humming u hear....contents insurance will pay for new motor if u have one
Apr 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Usually it is the drive coupler in between the motor and transmission. Do you know how to repair that if not read my articles here or contact me.
Apr 19, 2009 | Whirlpool Washing Machines
Washer will not complete cycle
washer fills up but wont start washing i can turn the knob just passed the numbers and the little marks and it starts washing and when it gets to the rinse cycle it wont rinse but when it gets to spin cycle it spins good
Mar 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Gwh9100 washer spins slow
did you clean pump? remove bottom cover remove clean out port on front of pump by turning white handle counterclockwise clean pump and reinstall if still have pump out issue ..pump impeller may be loose on shaft and not pumping properly..
Aug 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washer keeps stopping during any cycle
the humming noise could be from two sources and it is worth while doing a few simple checks first the drain pump is jammed with a foreign object. check nothing caught in the impellor second water not available - check taps turned on. also turn water off, undo fill hoses, put in a bucket and turn water back on try on drain or spin programs to check water drainage as well
Jun 19, 2007 | Tecnik TKL9260 Front Load Washer
Washing Machines Logo
371 people viewed this question
Dan Webster
Dan Webster
Sal De
