Question about Maxtor Hard Drive
New sata hard drive not recognised - Maxtor Hard Drive
    Scholar:
  • 193 Answers
Did you check in the bios settings under the first optin?
if its note there, re-check your cables, if the problem persist contact your provider (seller), and take all the infos about the hard drive, like serials number, how many heads how many sectors....how many bites, u should see all the info you need in the bios settings. and putt them manually....
your bios might have some limitation and an update is requierd (contact your manufacturer or google if ur an advances user), or its just your hard disk.......
Posted on May 07, 2010
    Scholar:
  • 91 Answers
You will need to format the drive and put a OS on it. If you have already try checking the connection again and i think in windows vista there is a function to try and locate a new drive.
http://www.seagate.com/ww/v/index.jsp?locale=en-us&name=install-troubleshoot-sata-non-mac&vgnextoid=2b089d2c3c90e010VgnVCM100000dd04090aRCRD
http://www.brighthub.com/computing/windows-platform/articles/52719.aspx
this is pretty basic info on the link but it pretty much applies to all the windows OS
Posted on May 05, 2010
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
SATA hard drive not recongised.
hi, sorry but i have to ask the question , why did you take the drive out of a external drive then buy a kit so as you can use it as an external drive , if its because the Seagate casing is damaged then its highly likely the drive is damaged too .
Apr 28, 2010 | Seagate 1 TB SATA II Hard Drive
I've connected my Samsung 250GB HD250HJ SATA drive (from a Linkstation) to my PC with a sata-ide adapter. It's recognised at boot time but I get the message 'primary master hard disk fail'. It isn't...
You may need to address the way that the old HDD was used in the BIOS. Meaning that if you had regular IDE drive the setting that may be in the BIOS might need to bee disabled and that could be the cause to the new SATA IDE controller you have installed as a boot device. Also if you are trying to boot from you new SATA drive you will need to install some form of and operating system on it like windows or whatever you have been using.
Sometimes it’s easier to create a disk image of the old drive and transfer it to you new SATA, using a disk image utility like Norton Ghost.
Of course I am assuming that you are using a PC and not a MAC.
-Aaron
Dec 05, 2009 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
My new 500GB WD SATA internal hard drive isn't recognised
Paul: Usually the drives come with a disk/cd from WD. Did you use this to format the drive?
Nov 19, 2009 | Computers & Internet
Cant load xp onto sata HDD
To use XP with a SATA drive you'd need to use the HDD disc software first as XP didn't come with preloaded SATA drivers. This is what is preventing you from installing XP on the drive. Once the driver is loaded you should have no problem. If your new hdd didn't come with a disc then you can download it from the hdd manufacturers website under the support link. Hope this helps.
Jul 12, 2009 | Seagate (ST3250824AS) 250 GB Hard Drive
Windows 2000 advanced Server does not support Seagate 250 GB Hard Drive.
I am inclined to think that this would be a problem with the jumper settings limiting the size of the drive.
I can't offer anything more than that, sorry. Hope it will help a bit.
Aug 08, 2008 | Seagate (ST3250824AS) 250 GB Hard Drive
Sp2004c sata hard drive is not recognised on system by bios or samsung hard disk manager all pluged in corectly to a new m/b, please help built a few pc`s now and not had this prob b4
  • Some SATA HDs have jumper for 1.5 G (SATA I) and 3 G (SATA II)mode. Try switching the jumper to 1.5 G or SATA mode (see motherboard manual).
  • Or you might need to upadte BIOS to support SATA drives.
Good Luck
Iqbal
May 11, 2008 | Computers & Internet
Motherboard does not recognise new SATA hard drive
Is your board an ABIT? If so then here is the link to select your motherboard and download the latest BIOS. Make sure to read the web sites instructions on how to update your BIOS. Let me know if you still have issues.
http://www2.abit.com.tw/page/en/download/download_bios.php?pMAIN_TYPE=Motherboard&pSUB_TYPE=Socket%20754
Dec 30, 2007 | Abit KV8 Pro Motherboard
Maxtor Hard Drive Logo
66 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
