Question about Pelco PMCL417 17 in. LCD TV
Monitor wont turn on. is there a fuse of some sort inside? or any other minor issues i should check?
  • 308 Answers
There is always a fuse inside and if it is blwn, there is something else that has failed. Check the power supply caps also. Common failure.
Posted on May 05, 2010
You need to check for any hairline cracks in LCD screen. If there are any then the LCD screen will not work but red light on front of unit will show power is going to Monitor.
Posted on May 02, 2012
My detrola turntable wont turn on.turn the button,but nothing.bought it in 05
Fuse issue. If it were me, Id turn it off, ground my self, open it up and look for fuses that have blown. replace. should sort it out. If not, its an more serious Ac/Dc issue.
Jan 02, 2015 | Audio Players & Recorders
My Sony Trinitron kv-27v45 won't turn on at all. Is this something minor, can it be repaired?
minor evrey thing can be repaired chack all the fuses see if in clean inside open it first there are smalal ic fuses near the fbt (some thing big on the pcb with red cable going to the CRT) check for bad connection if you have multimeter test the FBT transisor
Sep 22, 2010 | Sony KV-27V45 27" TV
Computer monitor wont turn on when you hold the power button a small orange light turns on. What is wrong?!
CONNECT THE MONITOR DIRECTLY TO THE WALL OUTLET
CHECK WHETHER YOU GET CHECK AUDI SIGNAL OR NOT OR ANY MESSAGE---HTEN CHECK FOR THE CABLE---IF STILL THE ISSUE PERSISTS CHECK IT WITH A DIFFERENT CABLE---
THEN CONNECT IT TO THE COMPUTER MAKE IT SURE THE COMPUTER IS TURNED ON AND THE POWER IS GIVEN TO THE MONITOR AS WELL----CHECK THE COMPUTER WITH ANOTHER MONITOR---IF THE OTHER MONITOR IS WORKING FINE THEN CONNECT YOUR MONITOR TURN IT ON AND THEN FLASH A FLASH LIGHT OR TORCH LIGHT AND THEN SEE IF YOU CAN SEE A DISPLAY INSIDE..
WHILE CHECKING FOR ALL THESE STEPS YOUR ISSUE WILL BE RESOLVED IF NOT TYOU GOTTA CONTACT THE MANUFACTURER FOR A FAULTY MONTIOR---
STEPS IN BRIEF:
DO A MONITOR SELF TEST
CHECK FOR THE LIGHTS
CHECK FOR THE CABLE
CHECK FOR THE PHYSICAL SIGNAL
PUT THE MONTIOR ON A DIFFERENT COMPUTER AND CHECK
CONNECT THE COMPUTER WITH A DIFFERENT MONITOR AND CHECK
FLASH A FLASH LIGHT AS A LAST STEP TO SEE A DISPLAY
IF THE ISSUE IS NOT RESLOVED THE MONITOR IS FAULTY..
HAVE A NICE DAY!!!!
Jun 22, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor won't stay on more then a second or two
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
May 31, 2010 | Dell E193FPC 19" TFT LCD Flat Panel...
When i turn on the desktop my monitor is not getting feed, light just blinks, i tried another but nothing.
it's either your monitor is faulty or your display card... the only way to confirm this is to hook your PC to another monitor.. if same problem.. then you need to check your display card inside your CPU.. if you are using intergrated MBO.. then you might need to do some minor troubleshooting..
May 24, 2010 | Compaq D51C PC Desktop
My Proview Technology 15' tft is fluctuating from last week...actually it is minor fluctuation..i tried to solve this problem by removing speakers form it's side but it doesnt effect this...
Magnet does not affect the LCD panel like the CRT monitor because LCD dose not use electron beams for display function.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 20, 2010 | Proview Technology 15" .297 1024x768...
ViewSonic Monitor Flickers
Check your MAC's standby, power and screen saver settings
Nov 13, 2008 | ViewSonic VA902b 19" Monitor
What can i do? my laptop screen wont turn on.? the comp turns on, but the screen wont. it has power/battery. works normal, no virus. slow system. but sometime it works. and sometime the screen doesnt turn...
- Try using a desktop monitor and check if the issue still persist, If the issue is not happening on the desktop monitor .It maybe the LCD.
- Check If you can download some manuals of your system and try to check if you can follow the instruction on how to reseat lcd cables inside your laptop. If you can do it it will help us isolate the issue.
Oct 08, 2008 | Acer Aspire 5100 Notebook
Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor won't turn on.
chheck poer cable of monitor.if it is ok then check on off switch of monitor .and it is ok then check fuse inside monitor in power section.if it is ok then check horizantal output transistor.
Mar 03, 2008 | Computers & Internet
Pelco PMCL417 17 in. LCD TV Logo
244 people viewed this question
Top Pelco Televison & Video Experts
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
