Question about Wap Cleaning System: SQ 15 Gallon RDF Vacuum
I am looking to find out if there are attachments for the WAP SQ 440-11 RDF. I am looking for a HEPA beater bar, HEPA filters and HEPA debris collection bags.
  • 20 Answers
Parts are expensive , only available from wap. a local vacuum repair shop should be able to fix you up with a hose and tools. wap ia a odd size . but they should be able to adapt / downsize the hose.
Posted on May 06, 2010
I have an Eureka Altima Model 2961AVZ vacuum that suddenly stopped picking up. I have taken it apart, checked the belt which was fine, replaced the hepa filter, and checked for clogs in all the hoses
Is the beater bar actually turning when the power is turned on? Sometimes the belt is fine, but something is jammed and keeping the beater bar from turning. What about the section behind the beater bar, but before the hose upright. I've found large pieces of paper jammed in here and then hair gets caught, ultimately blocking the whole system. Usually you have to turn it over, remove some screws and disconnect the belt and beater bar to get underneath. Just reassemble it in the reverse order to how you took it apart. Double check the hoses and run a "unwound" metal coat hanger through to unclog anything. Does the vacuum " suck" with the hose or tube up to it disconnected? If not you may have a motor that somehow got junk pulled into it. You can open this up as well and clean this out. Of course unplug it all before doing anything.
Nov 03, 2014 | Vacuums
Beater bar is not coming on- belt is on, canister is empty. Vacuum runs but no beater bar
Remove the beater bar and clean the debris from the bar and the end bearings. Remove the belt (remember how it is installed) and check it for any damaged areas. Make sure the bar turns freely before the belt is attached to the motor drive. Hope this helps!
Mar 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Low suction
Hi, You can take care of both things at once. Here's how:
Unplug and flip your vacuum over, beater bar side up. Remove the cover base plate that surrounds your beater bar. It's held on with either clips or screws, and usually "hinges" toward the front of the vacuum to release when the clips/screws are undone. Remove the base plate. The beater bar sits in sockets where it fits into the vacuum. Pay particular attention to how it comes out as you remove the beater bar, so it will be much easier to put it back together. If your belt is good, it will want to come off with the beater bar, but will remain attached to the motor. If necessary, slip the belt off of the beater bar. Behind the beater bar, you'll see a cavity. This is where the vacuum pulls the dirt from the beater bar. Look up into the cavity; stuff almost always hangs up in there. Remove any debris that you can find. While you have your beater bar out, look at the ends, where it fits into the sockets. Hair and other material catches on the beater bar and winds around it. If it is in and around the sockets, it causes the vacuum to have to work harder to clean. Remove any debris that you find on either end. Get your new belt and place it on the motor shaft. Slip the beater bar into the belt, and install the beater bar and sockets back into the vacuum frame. It takes patience so don't worry if it takes a few tries to get it right. Once in, test your work by revolving the beater bar a bit with your hand. You should be able to feel the tension of the belt as it turns the bar and the motor shaft. Take one more look at the sockets, just to be sure that they are in the proper place, and that the beater bar is level in the frame. Reinstall the base plate. This should have you finished at this end.
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Aug 01, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Hoover U6476-910 - Very little suction from the bottom
If you haven't already, remove the beater bar. This is accomplished by unplugging the vacuum and turning it beater bar up. Remove the clips or screws that hold the plate on the beater bar and set aside. The beater bar sits in sockets, so carefully remove the bar, noting the correct position of the sockets. This will make reassembly much easier. Slip the beater bar out of the drive belt. Now, inspect the suction cavity that the beater bar would discharge into. Usually, things clog up here as there is a flex hose that catches things, creating a pluggage.
Hope this helps, --W/D--
Jul 18, 2009 | Hoover U6476-910 WindTunnel Upright Vacuum...
The brush rotates on my dyson slim but there is no suction. though there is suction from the hose... has anyone any ideas????
Un-plug the machine first. Turn the unit over and remove the bottom plate. Check for and remove any debris in, around, or behind the beater bar assembly. While you're in there, look at the beater bar ends where the bearings sit. and clean any debris, hair, etc, from those areas as well.
May 17, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
No suction from base or hose attachment
I had the same problem with my Eureka vacuum cleaner. I don't have the problem with the beater bar, but I had the problem with the attachment hose not getting any suction. I found out that I was putting attachment on the wrong end of the hose. The end that you use in the front. Don't how I got that confused because it always worked before. Hope this helps with the hose part of the problem.
Glen
Mar 19, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Wap 300 aero. Air release cover.
Contact wwwultimategarage.com. They are a stocking dealer for Wap vacuums, and can probably get the part for you. Wap is one of the best vacuums made & is definitely worth fixing.
Dec 05, 2008 | Wap Cleaning System: SQ 15 Gallon RDF...
Spitting Out Debris
the hose from brush go to the bag need to check for blockage you have to open there hose to clean
Aug 13, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Wap Cleaning System: SQ 15 Gallon RDF Vacuum Logo
159 people viewed this question
Top Wap Vacuums Experts
ray gallant
Mai Lor
Are you a Wap Vacuum Expert? Answer questions, earn points and help others
