Question about Xerox WorkCentre 4250SM All-In-One Printer
I am getting an error message that reads: "Auto-registration process fails to communicate." what does that mean?
    Scholar:
  • 92 Answers
This message is related with a Smart eSolution service on your device. This service allows your device to communicate with Xerox servers and provide meter information.
By not having the service configured or by not being able to contact the server you will be displayed with this message. (Re) configure the service is the solution for your "problem".
This will not influence the good production of the device. All services will be fully functional
Posted on May 06, 2010
Thanks Bill I have an OBD2 scanner but when I hook up it says LINK ERROR indicating that it has a problem communicating with the car is that standard
Linking Error w/ OBDII Diagnostic scanner (unable to communicate ...
forum.mazda6club.com > ... > Electrical
Nov 16, 2010 - When I try to run the scan (initial link-up. ... the device keeps saying"Linking Error," meaning that the OBDII and diagnostic device aren't able to communicate. .... autozone and have them hook their scanner up for free to verify.
What am i doing wrong? obdII scanner hookup? - D-series.org
www.d-series.org > ... > D-series Knowledge Factory > General Tech
Sep 16, 2009 - 21 posts - ‎8 authors
well i borrowed my friends obdII scanner and im trying to check my codes but everytime is says link error? im stumped i tried it multiple times with. ... but it sounds like you may have an electrical problem somewhere. Discovery ...
"Linking Error" OBDII Comm failure ' DSMtuners
Dec 06, 2015 | Cars & Trucks
Tip
Error codes related to Canon ir 2200/2800/3300
E000 Heater temperature fault
(fails to increase)
E001 Overheating detection error
E002 Heater temperature error (fails to reach
specific level; inadequate increase)
E003 Heater temperature error (abnormal
drop; low-temperature detection)
E007 Fixing film rotation error
E010 Main motor rotation error
E014 Fixing motor rotation error
E019 Waste toner case full, sensor error
E032 DA unit communication error
E051 Horizontal registration HP
detention error
E064 Power supply voltage error
(high-voltage error)
E100 Laser BD error
E110 Polygon motor rotation error
E202 No. 1 mirror base HP detecting error
E204 ADF image leading edge signal
detection fault (absent)
E220 Lamp ON error
E225 Standard white plate/edge white
plate read error
E240 Mcon-Dcon communication error
E243 Mcon-control panel
communication error
E248 Backup (EEPROM) error
E261 Zero-cross signal error
E302 Shading error
E315 Image data processing error
E601 Image transfer error
E602 Hard disk error
E604 Image memory fault
E605 Image memory battery fault
E606 HDD error
E674 Fax board error
E677 PDL board mounting error
E710 IPC initialization error (Rcon)
E711 IPC register error (ctrl)
E712 Communication error (with ADF)
E713 Communication error (with sorter
finisher)
E716 Communication error (with pedestal)
E717 Communication error (with ASSIST)
E719 Card reader, coin vendor
communication error
E732 Reader communication error
E733 Printer communication error
E737 SDRAM error
E740 Ethernet board error
E741 PCI bus error
E742 RIP1 board error
E743 Mcon-Rcon communication error
(Rcon detection)
E744 Language error
E746 Resolution conversion board error
E803 MPWS power supply voltage error
(low voltage error)
E805 Fan rotation error
E901 Pedestal main motor rotation error
[ADF]
E420 Back-up data read error
E421 Back-up data write error
E422 IPC error
[Saddle Finisher-G1]
E501 Communication error (Punch unit)
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E530 Width plate shift motor
E531 Stapler motor
E532 Stapler slide motor
E537 Alignment motor
E540 Tray ascent/descent motor
E577 Paddle motor
E590 Puncher motor
E592 Puncher sensor error
E593 Puncher shift motor
E5F1 Saddle folder motor
[Finisher-J1]
E500 Communication error
E514 Stack handling motor
E530 Rear alignment motor
E531 Stapler motor
E537 Front alignment motor
E577 Delivery motor
E580 Delivery tray ascent/descent motor
E585 Stack handling error
If the thermistor has a short circuit, the indication in service mode
(COPIER>DISPLAY>ANALOG) will be as follows from the start: FIXC=250°C
for the main thermistor; FIX-E=310°C for the sub thermistor.
Error codes from E000 to E003 can be in some cases reseted from service mode: PROCEDURE:
Press*
Press2
Press8
Press*
Navigate to: COPIER>FUNCTION>CLEAR>ERR.
Turn off and on.
on Aug 03, 2010 | Office Equipment & Supplies
I had bought nokia E71 from nokia store and now after 1 odd month it has started showing sim card registration failed followed by insert sim card message on white screen...what could be the problem and i...
Sim card registration failure means that the card in the phone is not being recognized by the service provider as a valid or current account. The service provider is denying service based on the sim card that you are trying to use in your phone. If you have a current and valid account with your cell phone provider then you need to contact them to remedy the problem because something in the registration process has failed. They need to update and/or correct their records to link your account to the sim card in your phone so that your service will work.
Sep 12, 2011 | Nokia Cell Phones
Error code E000002-0000
dispite the error, you should be able to enter the service mode.
Procedure for service mode is:
- press * ( additional functions - user mode )
- press 2
- press 8
Then choose COPIER, then under FUNCTION screen is CLEAR.
But you only can try to clear the error like E000, E001, E002 and E003.
Wich error code is apearing on display?
Here is some examples of error code:
(fails to increase)
detention error
E100 Laser BD error
E220 Lamp ON error
plate read error
communication error
E302 Shading error
E606 HDD error
finisher)
communication error
E737 SDRAM error
E741 PCI bus error
(Rcon detection)
E744 Language error
(low voltage error)
[ADF]
E422 IPC error
E505 Back-up RAM
E510 Feed motor
E514 Delivery motor
E531 Stapler motor
E577 Paddle motor
E590 Puncher motor
[Finisher-J1]
E531 Stapler motor
E577 Delivery motor
If nothing of these helps, send more specific description of problem.
Hope it helps
Jul 06, 2010 | Canon imageRUNNER 2200
ERROR Window: Fail to read from dependant file.
If you are getting "Failed to read from dependent file" during installation, this is because Registry Booster is already running in the background.
If this is the case, then you should be able to see an icon in the
system tray next to the system clock. Double clicking on this icon should
restore the program window.
If you do not find it here, please right click on the taskbar and choose task
manager. In the processes tab you should find a registrybooster.exe entry. Select
it and click End Process.
Sep 19, 2008 | Computers & Internet
Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Jan 24, 2008 | Ricoh Aficio CL2000N Laser Printer
VOIP321 is unregistered
I had a similar problem. I unregistered the main handset & then when I attempted to re-register it, I had the same issue (handset attempts the registration process & eventually fails). I tried everything including pressing the "Reset" button on the back of the basestation & downloading firmware version 1.0.4.80 (started with 1.0.4.50). Turns out I had to press & hold the "Page" button on the basestation while the handset is attempting the registration process.
This info is in the manual. I know, I should have read the manual first. But at least I'm not alone; the guy at Philips told me to return the product because it must be defective.
It appears that the registration process is a security process/exchange between the basestation & handset. I'm not certain how standard this process is (i.e., whether differing manufactures utilize the same security protocols). If not, it is likely that other manufacturers' handsets cannot talk to the basestation. I mention this because you said you registered the main handset multiple times, so it sounds like you are familiar with the registration process.
Nevertheless, this might help others who decide to spend their weekend pressing the "reg" button a bzillion times, watching it fail as many times, & looking for answers on
Nov 08, 2007 | Philips VOIP3212 IP Wireless Phone
Xerox WorkCentre 4250SM All-In-One Printer Logo
1,210 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
