Question about C3 RS665 3Channel Vehicle Security System with Car Alarm and Rem
How to un program autopage alarm to stop locking
How to unprogram autopage from locking and unlocking the doors when ingnition is on
    New Friend:
  • 103 Answers
Http://www.autopageusa.com/resources/C3RS665installmanualfinal.pdf
you will find this in the programming features in the link above.
Posted on Aug 13, 2010
  • kaspera
    kaspera Dec 18, 2013
    I avtopage c3 RS 730 damkokit raised the alarm and did not know ramit pushing damekhmaret
  • kaspera
    I avtopage c3 RS 730 damkokit raised the alarm and did not know ramit damekhmaret subaru forester pushing the vakeneb
Posted on Dec 18, 2013
  • kaspera
4 Suggested Answers
SOURCE: how do i use autopage xt42-lcd
new baterie
Posted on Jun 01, 2009
  • 7 Answers
SOURCE: i have the normal alarm Autopage AutoPage C3RS603
Nothing is hard to hookup just time consuming andf it all depends on how good you R with wiring how good R you..?
Posted on Jul 16, 2010
logosc75
  • 625 Answers
SOURCE: autopage xt74 alarm in silent mode
The only reason that your alarm would not chirp when locking and unlocking the doors is that the system is in valet. A visual notification that the alarm is in valet mode is the LED light is on solid. If the LED is on solid and you wish to make the alarm active again, turn the ignition on then, press and hold the valet/programming switch for two seconds. The LED light will turn off.
If the LED light is not on solid then, the issue may be with siren itself.
Posted on Sep 28, 2012
My youkon alarm goes off every time i unlock the door with the autopage key fob.
Aftermarket alarms have to be configured to bypass the factory alarm system when using it.
I don't mean you have to permanently delete your factory alarm. What I am saying is, when you use your autopage key fob to unlock your doors, it must also send a signal to the disarm wire of your factory system simultaneously. If not, your alarm will go off just like you are experiencing.
May 16, 2017 | GMC Yukon Cars & Trucks
I have lost my smart remote key for my Mazda CX-9 2011. Can I program a new one myself?
You may need 2 keys to do this, possibly just one. My source does not specify if 1 key will work but here is the procedure i found
With two programmed advanced keys
  1. Bring the programmed advanced keys (2) and a unprogrammed advanced key into the vehicle.
  2. Close all doors.
  3. Insert the supplementary key into the ignition key cylinder. NOTE:
  • Complete the procedures up to Step 7 within 30 s after the supplementary key is inserted.
  1. Turn the ignition switch to the ON position.
  2. Press the UNLOCK button on advanced key 1.
  3. Press the UNLOCK button on advanced key 2.
  4. From the ignition switch in the ON position, switch the ignition switch in the order indicated below.
  • ACC->ON->ACC->ON->ACC->ON
  1. Open the driver-side front door, press the door switch twice , and then close the door. NOTE:
  • After Step 3 is completed and the advanced key programming mode is activated, the door lock actuator operates to lock, and then operates to unlock.
  • If the door lock actuator does not operate, repeat the procedure from Step 2.
  1. Press the UNLOCK button on the unprogrammed advanced key twice . NOTE:
  • After Step 8 is completed and the advanced key is programmed, the door lock actuator operates to lock, and then operates to unlock.
  1. If programming more advanced keys, remove the supplementary key once, and then repeat the procedure from Step 2.
Aug 04, 2016 | 2011 Mazda CX-9
My Autopage alarm is malfunctioning...the led light steadily on even if the engine is running.the remote wont work to lock or unlock the door,also no siren when you try openning it with key.
Check to see if all the cables and wires are tight and not corroded. You can also get live help at my auto repair advice dot com.-------------------------------------------------------------------------------------------
Ford Outcode/Incode Calculator
Mar 18, 2013 | Cars & Trucks
Autopage xt74 alarm in silent mode
Sep 25, 2012 | Megatronix - TW71 - 5 Button 2 Way LCD...
My alarm system went off due to wrong key ingnition...had to take a battery terminal off to stop the alarm, now I have the key and it wont start...is there a security reset?
Yes there is. 1. Press (LOCK) button 5 times at 2 second intervals to resynchronize transmitter. Attempt to function transmitter, if working as designed discontinue programming. 2. Turn ignition to run position. (Allow ignition chimes to stop).
3. Using any original (working) transmitter, press the [UNLOCK] button for 4 to 10 seconds.
4. Within the specified 4 to 10 seconds, continue pressing the [UNLOCK] button and press the [PANIC] button for 1 second and release both buttons (AN/DN release either button first). A chime will sound to indicate that the transmitter programming mode has been entered (allow 3 seconds for chime to sound).
5. Press [LOCK] and [UNLOCK] buttons simultaneously for 1 second and release (a short chime will sound for AN/DN).
6. Press and release any button on the same transmitter and a chime will sound after successfully programming the transmitter (locks will cycle for AN/DN).
Aug 15, 2011 | 2002 Jeep Liberty
I bought a used 2007 Expedition and the door pad remote entry does not work. I have one AUTOPAGE XT-33 remote that came with the car. I turned the key in the driver's side door lock and the alarm...
I'm not sure exactly if this is what you're looking for, but if you're trying to program a new keyfob remote, follow these steps:
  1. Turn the key in the ignition from off to run 8 times within 10 seconds. You'll hear the door locks cycle (lock and unlock) three times to confirm that the car is in learning mode.
  2. Within 20 seconds, press any button on your keyfob. The locks will cycle again to confirm.
  3. Repeat step two with any additional keyfobs you wish to program.
  4. Turn the ignition off. The locks will cycle again to confirm the end of programming mode.
As for the alarm type, you would probably want to contact Ford and ask them. As for the door pad, while you're on the phone with Ford you'll need to get the factory door code. You might be lucky and find it written somewhere in/on the car or inside the book that came with the car, unless the new owner got rid of it.
Jun 28, 2011 | Ford Vehicle Parts & Accessories
2002 VW Cabrio alarm problem: alarm will not un-set. Door will not lock using the key OR the remote. Hitting "alarm off" button on remote, it unsets, then arms again immediately. With engine...
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
Nov 08, 2010 | 2000 Volkswagen Cabrio
Where is the relay system on a car alarm
it is a standard bosch style relay, it should be under the dash on left or right of the steering cloumn
Sep 11, 2009 | Viking - VT73 - 4 Button Random Code Mini...
Jag S-Type -intermitent fault where the remote fob does not work
This does not sound like a fob fault - but a locking control module fault , either in the hardware or software of the unit. Get it checked at a Jaguar dealers. When unlocking using the key - as soon as the door is opened you should hear a chime sounding inside the car - this is a timer counting down to sounding the alarm. If you put your key in the ignition as soon as you open the door the alarm should not go off and the chime should stop. If it does not this again points to a fault in the locking controller.
hope this helps - good luck.
Jun 22, 2009 | 2004 Jaguar S Type
2002 ford explorer-alarm goes off in the middle of the night...no one around Alarm goes of whenever it wants to. I don't lock my doors, because when I unlock them the alarm goes off and will not stop even...
At one point the door was lock from the in side and then closed and then unlocked with alarm, try un-locking it from the drivers door, then from the in side push the un-lock button and then close the drivers door. U should have no problems with it, but they do say that putting the key in the ignition and then do what you would like starting it but don't and do it 2 times and then start it will tell the alarm that it is not stolen.
Do u know that key less entry code to your drivers door?
Let me know if you would like your code that is if you don't know where to look.
Nikki2913
Feb 01, 2009 | 1996 Ford Explorer
Open Questions:
C3 RS665 3Channel Vehicle Security System with Car Alarm and Rem Logo
792 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
