Question about Car Audio & Video
I have a parametric equalizer, which has only three wires. How do I connect it up to my car stereo?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 155 Answers
Most of the time you'll have 1 yellow or red for power 1 black for your ground and 1 blue for your remote then all thats left is your RCA jacks some eq are different and has more wires to none hope this was helpfull
Posted on May 09, 2010
How to get the whinning noise outta my radio in a f-150
Try running the ground wire directly to the battery ground.
Aug 07, 2014 | Planet Audio Peq15 5-band Parametric...
I need data sheet or user manual for my pioneer graphic equaliser
If is a parametric equalizer is zero watts. ,pionner should have a front, rear and subwoofer connections. If i remenber correctly, a single rca going to your stereo and the rest from eq to amp or amps. Hope this helps ,hope you get WIRED.
May 15, 2013 | Pioneer EQ-6500 9-Band Car Equalizer
Don't no how to hook it up ...
Instructions
Hook up an RCA patch cable
between the output of your car's
stereo receiver and the graphic
equalizer's RCA inputs. Use
stereo cables with male RCA
connectors.
Connect the equalizer's outputs
to the RCA inputs of your
amplifiers. How many cables you
need will depend upon the
number of amps in the system. In
most cases, you'll need two to
three to connect the equalizer to
the inputs of your amplifiers.
Hook up the equalizer to 12-volt
power. Use the same power
connections you used to connect
your amplifiers and receiver. The
equalizer's yellow wire should be
connected to a constant power
source, one that is not switched
off with the ignition, and the red
wire (not always present) to a
switched 12-volt power source.
Splice the wires by stripping the
insulation off the end of each
wire and then soldering or
crimping them together.
Connect the equalizer's blue
"turn-on" lead to the receiver's
blue wire. This turns the
equalizer on when the receiver is
powered up.
Mar 28, 2013 | Car Audio & Video
My cda-9887 does not have a bass/treble setting. Only fade/balance
In the initial stage of the set up your 9887 the stereo is set with an Equalizer (parametric or graphic), Until you use the Imprint set up module to Tune your car you wont get bass / treble controls. Also after Tuning with Imprint you will lose the EQ function, and it will only be B/T.
Nov 02, 2010 | Alpine CDA-9887 CD Player
I want to attach an equalizer to my power amplifier. but How?
assuming the ouput of your car stereo is high frequency, then from your car stereo ouput connect it to the equalizer's hight frequency input and then the output of the equalizer's had to be connected to the amplifier 1 for your sub, What kind of equalizer are you installing, is it two way one way or three way?
Jun 08, 2010 | Audio Players & Recorders
Equalizer setting help
try to use the preset equalizer settings after which you can come back to the parametric equalizer and adjust to your own taste. no problem if you don't connect the subwoofer just make sure you set the hi-pass filter to off so that you will hear the full range to your speakers. but, I advice you to put a subwoofer. There is more dynamics to the lower freqs too. don't adjust the source level if there is no problem. take note the EQ of your head unit is a parametric equalizer. hope this helps while you read about parametric EQs.
Apr 20, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
How do I wire an car stereo to an equalizer
from what you have explain you have a no experience to do so get your system installed by an audio installer safety come first and u have no clue for your safety seek a qualified person to do it
Mar 13, 2009 | Car Audio & Video
Hi! Looking for a manual on hooking up the speaker wires to my car stereo for Realistic stereo equalizer Model Number 12-1959? Thank you very much, jnbrucelee@yahoo.com - John
Hey there ninja. I was not able to find a manual in English(Spanish only!!!), but I did find this site with a few PDFs that may help you out. It has the Features, Installation, Operation, Specifications, and Wire Connections, so it should help you out.
Mar 06, 2009 | Car Audio & Video
Stereo wiring
Wire outputs from CD player into inputs of Equalizer, then connect outputs of equalizer to inputs of amp, then output of amp to speakers. Use the best wire possible for all connections, i.e. Monster cables ect.
Please post ratings for all solutions please.
Dec 04, 2007 | Washing Machines
Car Audio & Video Logo
106 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
