Question about NEC VT676 Multimedia Projector
NEC LT280 lamp error.
Is there anything that i can check by myself in order to solve this problem?
  • 2 more comments
  • guy_eve May 05, 2010
    The thing is that the lamp led indicator is not lit so i wonder if its worth to buy a new lamp now.
    Thanks,
    What is the meaning for the ballast?
    NEC projector LT280 - I get a "lamp error" fault. The lamp indicator is off.
    NEC projrctor LT280 - i get a "lamp error" but
    the lamp indicator is off.
    can i check some things by myself about that problem?
    Thanks,
  • 3,083 Answers
I would take the lamp out, and clean it's contacts, and also the contacts inside the projector (use alcohol and a soft cloth). It's also possible that it's slightly loose. If you have a spare lamp, try that to see if the error goes away. I'm assuming that the lamp doesn't work. In that case, you can use a voltmeter to "ohm" out the lamp filiment. You should see a .1 to maybe .6 ohm reading, I would think (some vary). If your bulb's good, and the contacts are clean, it's another issue with a circuit board, power supply, or possible mechanical problem. If you disassemble the unit, look for cracked traces on the circuit boards- this can happen, over time and even slight bumps. Hopefully, it's just a loose bulb.
Posted on May 05, 2010
    President:
  • 1,469 Answers
You can use this link to check for the problems solution.
emerson.edu/media_services/upload/NEC-LT380-LT280.pdf
Take care.
  • 1 more comment
  • Egwe Emmanuel Onyedikachi
    when a lamp of a projector shows error, it means that the lens is bad and it will need to be replaced.
    If you do not want to repair?,
    If you want me to give you the procedure on how to change the len i can help.
    I would advice to save you the stress of repair that can get damaged again, if you have money to purchase a new one. it will help you out. You can even get a better with guarantee.
    Take care.
    Hi to reset follow this step(hold down left " VOLUME - " button, followed by pressing
    menu button for 5 - 10 seconds).
    Take care.
    this is to reset lamp timer.
    There is basically two ways to reset the lamp timer :
    1. ) On the Projector's physical buttons
    Arrow Keys - Up , Down , Left , Right then Menu and Enter - this should
    be done quickly whilst the Projector is in standby mode.
    2.) Switch Projector on - Hold in the Up Arrow Key on the physical
    buttons on the Projector untill a PIP screen appears - then just follow
    the on screen steps.
    Take care.
  • 10,515 Answers
This is a Common Error on these Models. How old the Lamp is?
Replace the Lamp. Most of the times, when Lamp is at fault, this would Happen.
If after replacement of Lamp, Problem persists, then we need to Inspect and Test Other Components or then, you could ring a Local Serviceman in your area.
Let me know, so that we could Proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
  • 1 more comment
  • taran_2005
    taran_2005 May 05, 2010
    Thanks for your response!!
    I am still doubting this or Ballast now, as you said, Light Lamp does not Come on.I cam across the same problem with another Model VT595. In that Power Light was Green and then later on it was Orange.
    Ballasts do fail from time to time and that is the one that came with the machine. You may want to contact the company and inform them of uncommon number of ballast failures and ask for their input on a better replacement for that bulb. Matching the ballast to the load characteristics of the bulb is imperative.
    Let me know,if needed further assistance.
    Hope i helped you.
  • taran_2005
    For General Information, you could look at :-
    http://en.wikipedia.org/wiki/Electrical_...
    http://www.lrc.rpi.edu/programs/nlpip/li...
    Hope i helped you.
  • taran_2005
    If you want my Assistance Any More, let me know.
    Hope i helped you.
    day!!
I want to cancel my subsciption on my dog food order...I will order it myself when it is needed.Thank you
OK.. - BUT, Jerita, I would contact the company you ordered the dog food from, let them know you want to cancel... NO ONE on Fixya knows where you ordered anything from..sorry
Sep 08, 2017 | Dogs
Model LEQ9508PW1. It has stopped getting hot. Just stopped putting out any heat. I assume that it is probably the heating element that has gone out. Is there anything else I should check first before...
Check first the thermal cut-off (cut-out) and the high-limit thermostat located on the heating element housing by bypassing the said components. Disconnect power then remove the rear access panel to access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect the power then start the dryer. The problem is in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make.
Also bypass the cycling thermostat if the dryer still doesn't heat up with the thermal cut-off (cut-out) and the high-limit thermostat both bypassed. If the dryer still doesn't heat up, take the heating element out and inspect it for damage. Replace the heating element if damaged.
Jan 18, 2011 | Whirlpool Dryers
Can I connect two mac computers to a Viewsonic 2235 and switch between them
Yes, purchase a kvm (keyboard, video, mouse) switch. They are usually arranged as dual, quad, and eight. Just push a button and it cycles between them in order (toggles back & forth on a dual). Anything more than two is usually used on a server rack to control multiple servers with one keyboard, mouse & monitor. I use a quad myself. You can get one on ebay, staples, office depot, compusa, etc.
If this solution helps to solve your problem, then please take a moment to rate it.
Jun 02, 2010 | ViewSonic VG500b (Black) 15" LCD Monitor
Explain how do i delete myself from face book
In order to delete your Facebook account, kindly refer to the detailed instructions by clicking this link.
Hope this solves your problem. Thanks for using FixYa.
May 10, 2010 | Facebook Social Network
POWER CORD IS BROKEN
You stick with Best Buy until they get it right, that is why you paid the extra money for on the extended warranty, that's what it's for.
Jul 14, 2008 | Toshiba Satellite A105 Notebook
SCPH-50004 NO PICTURE AND SOUND
Replace IC501, Parts may be difficult to source.
Apr 20, 2008 | Sony PlayStation 2 (PS2) Console
My washing machine issue
order on line it should be easy to get one
Nov 29, 2007 | Kenmore Elite 45986 Front Load Washer
Error code 2-2
error code 22 means short to ground. for a start check your power supply to see if anything is shorted to the ground.
Oct 14, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Stucked power switch
Open the panel and check if its anything you can do yourself - cleaning or reassembling. not much else ;] Do a dry clean, you dont wan't any liquids around an open cellphone. Good luck
Apr 09, 2006 | Nokia 3230
NEC VT676 Multimedia Projector Logo
1,209 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
