Question about LG DLE5977 Electric Dryer
My lg dle5977 dryer is making a loud noise, and it seems like the drum is not spinning right. Can anyone give me any suggestions how to fix it?
  • 1,998 Answers
Check the rollers on the inside remove the drum to check also check the tensioner pulley at the same time you do this and inspect the belt
Posted on May 05, 2010
Loud dryer noise when drying
sounds like bearing take off back and see if and black markes around the bearings only other thing it could be is the felt ring around the drum
Apr 05, 2014 | LG DLE5977 Electric Dryer
Dryey makes loud noise on startup
Check for excellent air flow. Could be an object caught in fan.
Mar 05, 2018 | LG DLE5977 Stainless Steel Electric Dryer
TE1 error...thermistor seems fine
that's a bad thermistor,the thermistor isn't alot of money it's like 15 dollars,change it out,remove the code anf go from there but it should fix it,also check the wire connections.the tech sheet will tell you how to get it into diagnostics to remove the code
Nov 24, 2013 | LG DLE5977 Electric Dryer
My LG Front-load dryer is making a loud noise during the drying cycle. If i press on the lower left front panel - the noise is muffled quite a bit. Model # DLE5977
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gfg
Sep 27, 2010 | LG DLE5977 Electric Dryer
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
Severe noise - drum is jammed and won't turn - LG DLE-5977 dryer
A piece of clothing is probably caught in the blower wheel.
Remove lint filter.
Use flashlight to look into filter housing to the lower left.
You may be able to retrive the item if you can see it.
Try rotating the drum in both directions while looking.
Jan 07, 2010 | LG DLE5977 Stainless Steel Electric Dryer
I have a thumping noise as the dryer runs, but it seems to work fine.
Look closely at the seam of the dryer drum, at the very front and the very back. I suspect that the seam has developed a crack, and makes a thumping noise each time the crack passes over the drum support rollers. You will have to replace the drum to eliminate the problem
Jun 28, 2009 | LG DLE5977 Electric Dryer
LG TROMM DRYER DLE5977 Burning Smell
It is a POS dryer, we have the same one. My suggestion get another dryer. We vacuumed it all out (don't you have a problem with the lint catcher?) Then it started loud pounding noise, which a lot of people seem to have the same problem, then our sensor went out and we had to dry the clothes 5-10 x's...now crack in stainless steel drum and is chewing up all our expensive clothes!
Feb 21, 2009 | LG DLE5977 Stainless Steel Electric Dryer
LG DRYER MAKING CLUNKING NOISE
Look inside the drum at the seam, front and back side. The weld on the stainless steel drum may have cracked. You would need to replace part number 3045EL1002F. It is moderatly difficult to replace.
Oct 16, 2008 | LG DLE5977 Electric Dryer
LG DLE5977 Electric Dryer Logo
652 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
