Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Door won't unlock even when turned off - LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
  • LG Master
  • 43,501 Answers
Here is a tip that will tell you how you can get your washing machine unlocked manually...
Washing Machine Door Jammed
http://www.fixya.com/support/r3864434-washing_machine_door_jammed
heatman101
Posted on May 05, 2010
2000 toyota echo door
It depends on the actual problem. A body shop may be able to use a tool to go down thru the window sill to unlock the latch. If the latch is damaged, you may have to cut into the door to remove it.
Jul 01, 2013 | Cars & Trucks
1990 Audi 100 key won't lock or unlock doors
This is usually caused by broken plastic parts in the lock system. The best would be to verify and lub all locks and check out the elecrical.
kess v2
Mar 13, 2013 | Cars & Trucks
I have a 2004 G35 coupe and the gas door won't open even though all doors are unlocked
there is a release threw the trunk check the latch after you open it
Sep 09, 2012 | 2009 Audi A4
I just bought a 2001 Subaru Forester, I put the key in the door lock to unlock the door and the alarm went off and won't stop. How do I turn the alarm off?
I would try to close the door and press the unlock button on the kay fob. (If it has a remote intergrated with the key). This should unlock the door and turn off any anti-theft devices.
Jul 27, 2012 | Car Audio & Video
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
The doors will not lock or unlock from the door but will from the remote?
The title suggest the door won't unlock unless the remote is used but during the summer it was the inverse. If while inside the car the doors will not lock or unlock from the door but will from the remote then you have a faulty switch.If while outside the car the key turns while in the lock but the door won't lock or unlock then the linkage at the end of the lock is faulty. You'll need to remove the door inside plate to check this.
Dec 07, 2011 | 2004 Infiniti FX45
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
Passenger door won;t unlock
CV boot, requires axle disassembly, or you could use an aftermarket, split boot. You MUST replace the lube....
It is often much better to exchange the shaft with a new or rebuilt one. Many vibrations are caused if there is even a minor imperfection in the CV joint.
Jun 30, 2010 | 2004 Saturn VUE
Washing Machines Logo
258 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
