Question about Garden
Blades rotate on tractor when new belt was put on
MTD 38'' tractor. I replaced the belt, when I go to start the mower the blades rotate. I raised the deck as far as it will go. Should I replace the brakes. I read where I could spray graphite on the PTO that might help
  • 284 Answers
Be sure you have the correct belt for that mower?
Even though your deck is raised to disengage the
belt it may need to go up a small amount more,try pulling back on the deck raise handle to see if that helps,and find a way to keep it at that higher point if that worked or run the new belt for awhile and see if that makes a difference.
Check the belt guards to see if they are close to the belt as possible while engaged,but not hitting the belt
and when disengaged guards should be hitting the belt somewhat to help keep it from turning.
and yes be sure you have good belt brake pads and know they have good tension and hitting in the proper place
Posted on May 06, 2010
Why doesn't the shifter on my 42"mtd mower not effect the trans?
If the tractor has a hydro-static transmission. There is a rod at the back to make tractor roll easy for pushing. Rod out for neutral.Rod in for drive ingaged.
Jul 21, 2014 | Mtd Drive Belt 42"
Blades keep running in all gears on my mtd 420/38
Assuming you have put the blade drive lever into 'disengage' check the blade drive belt tension. With blade disengaged, belt should have significant slack. You may need to adjust the control cable, adjustment is usually on the mower deck; or you may have some debris on the deck preventing the pully to release belt tension
Jun 26, 2014 | Garden
I have a 38" deck yard machines(MTD) lawn tractor. When I raise the lever to disengage the blades, the blades still keep turning. Does anyone know how to fix this problem?
If they are slow to stop,thats ok if they don't ever stop thats an issue,the brake shoes that drag on the top of the blade spindles are worn out or not adjusted correctly !
May 14, 2014 | Mtd Garden
Vibrating 38" deck on MTD yardman mower
Hi, first replace the blade spindle bearings, if you had to hit them to free them up the bearings are shot. Secondly, replace the deck belt. Because you engaged the blades with a siezed bearing the belt will have a worn section where the v will be thinner thus causing the vibration as it passes through the pulleys. Regards Phil.
Jun 19, 2012 | Mtd Garden
Replaced drive belt on 1985 38 inch cut MTD lawn tractor, belt id smoking
Your rubbing something that's not moving I suspect a belt idler or blade hub, as for diagrams the internet has them http://cf.mp-cdn.net/db/30/8c384c4f3c61628a0487bed5f925.jpg
May 05, 2012 | Garden
How to put on driver belt for a MTD 38 inch cut
Your owners manual should have instructions for changing belts. If you need a manual, go here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
Aug 05, 2009 | Mtd Arnold Corp 38" /42" Mulch Kits
MTD 12-38 Shifting problem
mtd 12/38 blads not stoping ? theres a ajustment rod on right side under the mower turn clockwise to losen belt .
Jul 09, 2009 | Mtd Garden
Installing blade belt
you have to raise the mower then drop the rear of the deck by removing the 2 pins on the blade adjustment lever.once you do that it should go pretty easy
May 17, 2009 | Mtd Garden
Garden Logo
106 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
