Question about Weber Gas Go-Anywhere Grill
My weber gas grill wont start I try to turn on gas grill wont go heats a little bit then goes out why, I thought according to Sears that they are guaranteed for lifetime?
SOURCE: Weber grill
Can you tell if the gas is flowing? Its either dirty or perhaps your regulator got damaged.  I'd check that out.  Above all else, though, be careful!
Posted on May 19, 2008
cdenham1st
  • 3 Answers
SOURCE: my weber gas grill will not heat up past 300F
Hi John,
I just experienced the same exact problem ! I just bought a brand new Weber E-310 a 3 burner grill.
After I seasoned it up with cooking oil,I turned all the burners to high, opened the tank and clicked electrnic button several times , the grill was on then I went inside, I came out about an half-hour later and it was saying around 275 degrees..
I looked into my manual and there is a gas limit control valve that shuts down gas flow, when it thinks there is too much gas flow.
Sloution;
Turn the propane gas knob to off
Turn the gas grill knobs to Off.
Click the igniter several times to clear out any gas.
Then unscrew the regulator from the tank,( I then blew into the tank hole and regulator),
Screw back on the regulator to the propane tank.
I then clicked igniter again couple of times.
Now open your propane tank.
Then turn on front burner while clicking igniter, this will lite 1st burner.
Then turn 2nd burner on low then to high.
And if you have 3rd burner or more, turn low then to high!
John I did this and my grill went to 600 plus in a few minutes!!
The problem was turning the gas grill knobs on first then opening the tank then lighting...
You have to open propane tank with knobs off, THEN AS SOON AS YOU TURN ON 1ST KNOB, YOU MUST IGNITE ...
Posted on Mar 21, 2009
onyxvu
  • 74 Answers
SOURCE: weber gas grill will not ignite
you will probably have to get a new igniter or try to adjust the one you have. there is a little electrode on the igniter that needs to be clean and a certain distance away to work properly.
Posted on May 26, 2009
  • 512 Answers
SOURCE: Weber Silver Genesis C regulator purging gas after reset process
This could be caused by a couple of problems. First the regulator could be bad, or the tank is getting to hot. Which causes the relief valve to open and release pressure. This will happen when weather outside is hot.
Posted on Jun 17, 2009
SOURCE: Gas is not moving from tank to Weber silver grill
  1. you need to shut off all the valves and disconnect the tank.
  2. slowly open the tank valve and listen for gas escaping. (DO NOT ATTEMPT TO SMELL FOR THE GAS, THIS COULD PROVE HARMFUL TO YOUR HEALTH)
  3. you are looking for a valve or connection that is clogged. if gas escapes from the tank the reconnect the tank and check at each connection.
  4. if all connections are complete and functional, your problem may be at the burner itself. Using a push pin, **** the holes in the burner, paying attention to the amount of greasy build up.
  5. If the level of build up is severe, remove the burners completely and soak them in a tub of concentrated dish soap and warm water. DO not use hot or cold water.
  6. remember to shut the tank valve off in between each test cycle.
  7. a clean grill is the key to keeping it functioning properly,
  8. if you are having trouble getting the burners out, spray lighter fluid on the burners holes and light with a fireplace match, or rolled piece of paper.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Posted on May 03, 2010
Weber Genesis with a low flame! I've replaced the reglator twice and each time it works for a bit then the flame goes down to almost nothing. There seems to be screen protecting where the...
if you can take the burner out and try blowing air down it see if this clears , check injector is not block, check gas line is not blocked , or try new burner
Sep 05, 2011 | Weber Genesis Silver B Grill
We have a Weber Genesis Grill Silver and now we thought we needed gas and got a new tank. Okay now it will not heat up past 250 degrees. We found out about the trick with turning on the gas and...
Well, if turning OFF the tank valve, disconnecting the hose and wait 5 minutes before reconnecting it. And then, opening the tank valve VERY, VERY, SLOWLY (Slow motion slow) before lighting the burner farthest from the tank first and turning it to high didn't work. You need to replace the grill's hose/regulator assembly.
You can purchase one at any home center or hardware store that sells gas grills and accessories. They run around $30.00. Be sure to take your old one with you for comparison purposes.
Hope this helped you and Happy Grilling!!
Jun 06, 2011 | Weber Genesis Silver B Grill
My weber grill doesnt get above 200 degrees
Try these steps in order.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Sep 06, 2010 | Weber Performer Grill
My weber genesis silver starts up, but doesn't get hot enough to cook the food. Seems like not enough flame out of either front or back burners. I tried Outting in a full propane tank, but that didn't...
Sep 06, 2010 | Weber Genesis Silver B Grill
I have a weber genesis grill. just refilled the tank and connected it. this afternoon my wife smelled gas near the unlit grill. There was also an intermittent hissing sound. could the heat of day 90 plus...
seems like I can always smell a little gas on a freshly filled tank until I use it down a little bit. Also there is a bleed off screw on the valve of the tank Make sure it is tightly closed
Aug 09, 2010 | Weber Genesis Silver B Grill
Our Weber is working fine on full power but as
Try replacing the regulator and hose, easy to do and not very expensive. If this doesn't work, please let me know.
Jul 11, 2010 | Weber Spirit? E-310 Propane Grill
We have a new Weber Genesis LP gas grill. The
My thoughts, are you turning tank off after cooking, not only turning of cooking valves but also turn off tank, if you don't gas will leak out. If you do turn tank off, then you have a leaking valve in the tank.
Jun 13, 2010 | Weber Genesis E-310 Gas Grill
Weber grill wont heat past 350 degrees. Tank is full. Not leaking gas.
either your regulator is not hooked up to the tank all the way try to turn tank off make sure all knobs are turned off disconnect tank then reconnect turn tank on and try again if this doesnt work the regulator is bad
Aug 09, 2009 | Weber Genesis Silver C Grill
Weber gas grill wont heat past 300 degrees
are the fire red , orange or blue?
must likely is the burner control.
check the air control at the back of the burner control, it should be open all the way.
it it is, then try another themostate.
Mar 23, 2009 | Weber Genesis Silver C Grill
Weber Gas Go-Anywhere Grill Logo
134 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
