Question about Kenwood KD-291RC Turntable
Directions to install the belt
How do install the belt?
  • 21 Answers
Most units can be accessed by seperating the unit from the bottom. remove the feet..screws etc...secure tone arm when turning unit over... remove dust cover glass..etc...be careful. belt should be accessable and you may have to remove a guide of two. Take pictures with a digital camera as you go..just in case you forget where something goes when u reassemnble. Trace Electronics Repair. Canada
Posted on May 07, 2010
How to put on belthow do i install fab belt 2003 saturn ion cant fin how to move tensioner
See the arrow ?? Near the 'tail' of said arrow is a 'square' hole in the tensioner....Add tool,rotate25305889-he3vdclfw2d3q24brnzekcbx-3-0.gifin the direction of arrow & remove belt.....New belt installs in reverse order.
Dec 03, 2014 | 2003 Saturn ION
Water pump 2000 3.0 liter dodge caravan
For The 3.0 Motor. (3.3 Way down the line.)
Drain cooling system.
Remove timing belt. Refer to Engine for procedure.
Remove water pump mounting bolts.
Separate pump from water inlet pipe and remove water pump.
Timing Belt Removal
Raise vehicle and remove accessory drive belt splash shield (Fig. 66).
Remove accessory drive belts.
Remove crankshaft pulley and damper (Fig. 68).
Support engine and remove right side engine mount.
Remove engine support bracket (Fig. 67).
Remove timing belt covers (Fig. 67).
Mark belt running direction for installation (Fig. 69).
Loosen timing belt tensioner bolt (Fig. 71) and remove timing belt.
Remove crankshaft sprocket flange shield (Fig. 68). CAMSHAFT SPROCKETS To remove camshaft sprockets
Hold camshaft sprocket with Spanner Tool MB-990775. Loosen and remove bolt and washer (Fig. 70).
Remove camshaft sprocket from camshaft. To install camshaft sprockets:
Place camshaft sprocket on camshaft.
Install bolt and washer to camshaft. Using Spanner Tool MB-990775, hold camshaft sprocket and torque bolt to 95 Nm (70 ft. lbs.) (Fig. 70). TIMING BELT TENSIONER
Install timing belt tensioner and tensioner spring.
Hook spring upper end to water pump pin and lower end to tensioner bracket with hook out (Fig. 71).
Turn timing belt tensioner counterclockwise full travel in adjustment slot and tighten bolt to temporarily hold this position (Fig. 72).
INSTALLATION
Install timing belt on crankshaft sprocket and keep belt tight on tension side (Fig. 69). Install belt on the front (radiator side) camshaft sprocket. Install belt on the water pump pulley, rear camshaft sprocket and finally on the timing belt tensioner.
Rotate the front camshaft sprocket in opposite direction to take up belt slack. Check that all timing marks are aligned (Fig. 69).
Install crankshaft sprocket flange (Fig. 68).
Loosen tensioner bolt and allow spring to tension timing belt.
Turn crankshaft two full turns in clockwise direction. Turn smoothly and in clockwise direction ONLY.
Align the timing marks on the sprockets and tighten the timing belt tensioner locking bolt to 28 Nm (250 in. lbs.) torque.
Install timing belt covers.
Install engine support bracket.
Install right side engine mount.
Install crankshaft damper and pulleys (Fig. 68). Tighten damper center bolt to 135 Nm (100 ft. lbs.) .
Install accessory drive belts.
Install accessory drive belt splash shield (Fig. 66).
Be sure to also replace all the cam and crank seals why you are there. Might as well put a belt on too.
FOR THE 3.3 OR 3.8 MOTORS.
Drain Cooling System.
Remove accessory drive belt.
Remove right front lower fender shield.
Remove water pump pulley bolts and remove pulley.
Remove water pump mounting screws. Remove water pump.
Remove and discard O-ring seal.
Clean O-ring groove and O-ring surfaces on pump and chain case cover. Take care not to scratch or gouge sealing surface
Installation
Install new O-ring into groove.
Install water pump to chain case cover. Tighten screws to 12 Nm (105 inch lbs.) .
Rotate pump by hand to check for freedom of movement.
Position pulley on pump. Install screws and tighten to 30 Nm (250 inch lbs.) .
Install accessory drive belt.
Install right front lower fender shield.
Refill Cooling System.
FOR THE 2.4 MOTOR
Disconnect negative cable from battery.
Raise vehicle on a hoist. Remove right inner splash shield.
Support engine from the bottom and remove right engine mount.
Remove right engine mount bracket.
Remove timing belt idler pulley.
Hold camshaft sprocket with Special tool C-4687 and adaptor C-4687-1 while removing bolt. Remove both cam sprockets.
Remove rear timing belt cover.
Install new O-ring gasket in water pump body O-ring groove. CAUTION: Make sure O-ring is properly seated in water pump groove before tightening screws. An improperly located O-ring may cause damage to the O-ring and cause a coolant leak.
Assemble pump body to block and tighten screws to 12 Nm (105 inch lbs.) . Pressurize cooling system to 15 psi with pressure tester and check water pump shaft seal and O-ring for leaks.
Install rear timing belt cover.
Install camshaft sprockets and torque bolts to 101 Nm (75 ft. lbs.) .
Install timing belt idler pulley and torque mounting bolt to 61 Nm (45 ft. lbs.) .
Install timing belt. Refer to Engine for procedure.
Install right engine mount bracket and engine mount. Refer to Engine for procedure.
Fill cooling system.
Lower vehicle and connect battery cable.
Mar 29, 2012 | Cars & Trucks
I have a very old Wizard (Western Auto) Front Tine Rototiller Model gis 6990 A27 with power reverse. I am looking for a manual or a diagram of the drive belt routing. (Patent #2903077). Any assistance...
Hi and welcome to FixYa, I am Kelly
Here is a picture of the belts installed.
http://photos.cubfest.com/albums/userpics/10231/Belt_Routing.jpg
NOTE the front fwd direction drive belt / closest to the motor is installed like any other belt. The rear belt for REVERSE direction has 1/2 twist. The idler pulley presses in for foward driving and pulls out against the reverse drive belt.
This should be what you need.
Thanks for choosing FixYa,
Kelly
Jun 20, 2011 | Garden
How do I time a 1994 dodge caravan 3 0L Problem PLEAS IF ANY ONE HAVE THE DIGRAM
Is this what you needed?
Fig. Fig. 14: Sprocket timing for belt installation-3.0L engines
Fig. Fig. 15: Secure the sprocket when removing or installing the nut-3.0L engines
Fig. Fig. 16: Timing belt tensioner-3.0L engines
Fig. Fig. 17: Positioning the tensioner-3.0L engines
The timing belt can be inspected by removing the upper (front outer) timing cover.
  1. Disconnect the negative battery cable.
  2. Remove the accessory drive belts.
  3. Remove the timing belt covers.
  4. Identify the timing belt running direction to avoid reversal during installation.
  5. Loosen timing belt tensioner bolt and remove timing belt.
  6. Remove the crankshaft sprocket flange.
To install:
  1. Rotate the crankshaft sprocket until timing mark on crankshaft sprocket is lined up with the oil pump timing mark at 1 o'clock position.
  2. Rotate the (inner) camshaft sprocket until mark on (inner) camshaft sprocket is lined up with the timing mark on alternator bracket.
  3. Rotate the (outer) camshaft sprocket (radiator side) until mark on the sprocket is lined up with the timing mark on the timing belt inner cover. Refer to timing belt illustration.
  4. Install the timing belt on the crankshaft sprocket while maintaining pressure on the tensioner side.
  5. Position the timing belt over the camshaft sprocket (radiator side). Next, position the belt under the water pump pulley, then over the (inner) sprocket and finally over the tensioner.
  6. Apply rotating force in the opposite direction to the camshaft sprocket (radiator side) to create tension on the timing belt tension side.
  7. Rotate the crankshaft in a clockwise direction and recheck engine timing marks.
  8. Install the crankshaft sprocket flange.
  9. Loosen the tensioner bolt and allow tensioner spring to tension the belt.
  10. Again rotate the crankshaft in a clockwise direction (2) full turns. Recheck the engine timing. Tighten the tensioner bolt to 23 ft. lbs. (31 Nm).
  11. Install the timing covers.
  12. Install the accessory drive belts.
  13. Connect battery negative cable.
May 29, 2011 | Dodge Caravan Cars & Trucks
Belt slipped on my hoover self propelled windtunnel
Please give additional information?
Sometimes belts can be mounted in 2 directions. If installed in the wrong direction, the roller will rotate backwards and the belt can come off. Also, it is possible that the belt has stretched. Verify that the roller spins freely with the belt off. If it doesn't, remove it and clean it and verify that the bearing are good.
Sep 27, 2010 | Vacuums
Need to know what the timing marks and locations for replacing the timing belt
Timing Belt Removal & Installation 3.0L Engine To Remove:
Exploded view of the timing belt and sprocket assembly (3.0L engine) 86723255.gif
  2. Remove the accessory drive belts. Remove the engine mount insulator from the engine support bracket.
  3. Remove the engine support bracket. Remove the crankshaft pulleys and torsional damper. Remove the timing belt covers.
  4. Rotate the crankshaft until the sprocket timing marks are aligned. The crankshaft sprocket timing mark should align with the oil pump timing mark. The rear camshaft sprocket timing mark should align with the generator bracket timing mark and the front camshaft sprocket timing mark should align with the inner timing belt cover timing mark.
  5. If the belt is to be reused, mark the direction of rotation on the belt for installation reference. Mark the direction of travel for the timing belt for correct installation 86723p72.jpg
  6. Loosen the timing belt tensioner bolt and remove the timing belt.
  7. If necessary, remove the timing belt tensioner. Turn the center tensioner pulley bolt until the timing belt has enough slack . . . 86723p73.jpg
  8. Remove the crankshaft sprocket flange shield and crankshaft sprocket.
  9. Hold the camshaft sprocket using spanner tool MB990775 or equivalent, and remove the camshaft sprocket bolt and washer. Remove the camshaft sprocket.
To Install:
  1. Install the camshaft sprocket on the camshaft with the retaining bolt and washer. Hold the camshaft sprocket using spanner tool MB990775 or equivalent, and tighten the bolt to 70 ft. lbs. (95 Nm).
  2. Install the crankshaft sprocket.
  3. If removed, install the timing belt tensioner and tensioner spring. Hook the spring upper end to the water pump pin and the lower end to the tensioner bracket with the hook out.
  4. Turn the timing belt tensioner counterclockwise full travel in the adjustment slot and tighten the bolt to temporarily hold it in this position.
  5. Rotate the crankshaft sprocket until its timing mark is aligned with the oil pump timing mark.
  6. Rotate the rear camshaft sprocket until its timing mark is aligned with the timing mark on the generator bracket.
  7. Rotate the front (radiator side) camshaft sprocket until its mark is aligned with the timing mark on the inner timing belt cover.
  8. Install the timing belt on the crankshaft sprocket while keeping the belt tight on the tension side. NOTE: If the original belt is being reused, be sure to install it in the same rotational direction.
  9. Position the timing belt over the front camshaft sprocket (radiator side). Next, position the belt under the water pump pulley, then over the rear camshaft sprocket and finally over the tensioner. CAUTION
    If any binding is felt when adjusting the timing belt tension by turning the crankshaft, STOP turning the engine, because the pistons may be hitting the valves.
    Rent or borrow the special tool to hold the camshaft sprockets steady . . . 86723p75.jpg
    . . . while loosening the center retaining bolt on the camshaft pulley, then . . . 86723p76.jpg
    . . . remove the camshaft sprocket from the end of the camshaft 86723p77.jpg
  10. Apply rotating force in the opposite direction to the front camshaft sprocket (radiator side) to create tension on the timing belt tension side. Check that all timing marks are aligned.
  11. Install the crankshaft sprocket flange.
  12. Loosen the tensioner bolt and allow the tensioner spring to tension the belt.
  13. Rotate the crankshaft two full turns in a clockwise direction. Turn the crankshaft smoothly and in a clockwise direction only.
  14. Again line up the timing marks. If all marks are aligned, tighten the tensioner bolt to 250 in. lbs. (28 Nm). Otherwise repeat the installation procedure.
  15. Install the timing belt covers. Install the engine support bracket. Tighten the support bracket mounting bolts to 35 ft. lbs. (47 Nm).
  16. Install the engine mount insulator, torsional damper and crankshaft pulleys. Tighten the crankshaft pulley bolt to 112 ft. lbs. (151 Nm).
  17. Install the accessory drive belts.
  18. Reconnect the negative battery cable.
  19. Run the engine and check for proper operation.
Aug 17, 2010 | 1997 Dodge Caravan
Can you tell me where I can print instructions for free to help me change my timing belt in a 93 ford festiva
Here are the instructions for removing the timing cover, and for replacing the timing belt. If this is helpful, please click my accept button! Thanks!
  1. Remove water pump pulley to pump hub attaching bolts, then the pulley.
  2. Remove right inner fender panel to gain access to crankshaft pulley.
  3. Remove outer crankshaft pulley attaching bolts, then the outer stiffener/spacer and outer pulley
  4. Remove inner stiffener/spacer, attaching screws, inner pulley and baffle plate.
  5. Remove attaching bolts, then the upper and lower timing covers.
  6. Reverse procedure to install. When installing crankshaft pulley, ensure curved lip on baffle plate and deep recess of inner pulley face outward
  1. Remove timing belt covers as outlined previously.
  2. Remove timing belt tensioner pulley attaching bolt, then the tensioner pulley, spring and spring cover
  3. If reusing old belt, mark direction of rotation on belt to aid installation.
  4. Remove timing belt from crankshaft and camshaft sprockets.
  5. Check crankshaft and camshaft sprockets, tensioner pulley and timing belt for wear or damage. Replace components as necessary.
  6. Align camshaft and crankshaft sprocket timing marks with marks on cylinder head and oil pump housing
  7. Install timing belt. If reusing old belt, ensure belt is installed so that direction of rotation mark made during removal is positioned correctly.
  8. Install spring and spring cover onto tensioner pulley, then install pulley and attaching bolt. Do not tighten bolt at this time.
  9. Install tensioner spring onto anchor, then tighten pulley attaching bolt to torque listed at the end of this section.
  10. Reinstall timing belt covers.
This photo shows timing marks.
Jul 14, 2010 | 1993 Ford Festiva
How to changing a timing belt on a 2000 ford focus SE
FOR A 2.0 SPI ENGINE:
Removal
  1. Remove the accessory drive belt.
  2. Detach the coolant expansion tank.
  3. Remove the bolt and position the expansion tank to one side. Detach the power steering reservoir and position to one side.
  4. Remove the right-hand front wheel and tire.
  5. Remove the crankshaft pulley/vibration damper.
  6. Lower the vehicle. Disconnect the ignition wires from the spark plugs.
  7. Remove the two ignition wire separators from the valve cover.
  8. Remove the spark plugs. Place a jack with a wooden block under the oil pan and raise slowly until the front engine mounting is free from strain.
  9. Remove the engine front mounting. Remove the timing belt cover.
  10. Remove the engine front mounting bracket. Align the timing marks.
  11. Remove the timing belt. Use an 8 mm Allen wrench and turn counter clockwise 1/4 turn.
  12. Insert a 3 mm (1/8 inch) drill bit to lock the timing belt tensioner in place.
  13. Remove the timing belt.
Installation
  1. Check the alignment of the timing mark on the crankshaft timing belt pulley.
  2. Check the alignment of the timing mark on the camshaft timing belt pulley.
  3. Install the timing belt. Install the timing belt over the pulleys in a counter clockwise direction starting at the crankshaft.
  4. Keep the belt span from the crankshaft to the camshaft tight while installing the timing belt over the camshaft.
  5. Remove the 3 mm (1/8 inch) drill bit to release the timing belt tensioner.
  6. Turn the crankshaft at least two turns in clockwise direction to TDC position for cylinder one.
  7. Check the alignment of the timing marks.
  8. If the alignment is not correct repeat the previous steps. Install the engine front mounting bracket. Install the timing belt cover.
  9. Install the engine front mounting. Remove the jack. Install the spark plugs.
  10. Push on the spark plug connector until it engages.
  11. Raise and support the vehicle. Install the crankshaft pulley/vibration damper.
  12. Position the drive belt on the crankshaft pulley.
  13. Install the right-hand front wheel and tire.
  14. Install the power steering reservoir.
  15. Install the coolant expansion tank. Install the accessory drive belt.
Nov 10, 2009 | 2000 Ford Focus
Serpentine belt diagram for 1996 audi a4 quattro v6. I can't find a proper diamgram and install procedure, can you help?
Ribbed Belt: Service and Repair
Ribbed Belt, Removing and Installing
Ribbed belt, removing and installing
CAUTION: Mark the direction of belt travel before removing, using a crayon or marker. Reinstalling a used belt in the opposite direction
could damage the belt
Note:
There are two different types of ribbed belt, identified as versions A and B.
Ribbed belt versions, identifying, refer to Application and ID
Removing
Old version A
- Remove ribbed belt guard.
- Loosen ribbed belt tensioner using 15 mm wrench and drift 3204.
- Remove ribbed belt.
New version B
- Using 10 mm hex socket wrench, turn downward in direction of arrow to loosen ribbed belt.
Installing
Install in reverse order of removal, noting the following:
- Place ribbed belt over drive pulleys and idler roller first, and onto tensioning roller last.
- Remove drift 3204.
- Install ribbed belt guard.
Sep 24, 2009 | 1996 Audi A4
Cassette Tape Deck Problem
Unit may have worn belts that are slipping. All cassette player belts are subject to deterioration even if recently installed. You may try ordering the belts yourself and have a service tech install them. The tech that installed belts 9 months ago may have used used belts. Although dishonest, it is common.
Jul 17, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
Kenwood KD-291RC Turntable Logo
138 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
