Question about Kenmore Energy Star 44092 Front Load Washer
Kenmore 48102 Front load washer won't siphon out laundry detergent.
  • 15,935 Answers
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Why do Whirlpool Duet washers have such a problem with "over sudsing"? And how to prevent it?
The "oversudsing" problem is usually due to operator error. These new front loaders require the use of HE laundry detergents. These greatly reduce the sudsing issue. They also require VERY LITTLE detergent. For example, a normal-size laundry load only requires 1-2 TEASPOONS of HE laundry detergent. Most folks use much more than that, causing a possibility of oversudsing.
See this link for more info.
What Is HE Laundry Detergent And Do You Need It
Aug 08, 2016 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
How do i remove the drawer to clean it out the bleach, softener, detergent dispensers?
The dispenser slides out . There are plastic slideson both sides of the outer dispenser tray which run into grooves internally . be careful not to force its removal as you will damage the tray
Feb 10, 2015 | Kenmore Washing Machines
I have a frontload he washer. My question is, will using a regular laundry detergent instead of he laundry detergent cause problems with the washer.
top load detergent will suds a lot and detergents made for from load washers wont suds very much at all, suds ina front loader will cause it to not spin or drain very well while i know it is more expensive you should always use detergents with the HE logo on the package
Jul 25, 2011 | Washing Machines
48102 kenmore washer drains but more on floor than thru drain pipe
You only have to look under where the hose might have come loose, refit. Check out your filter also.
Mar 01, 2009 | Kenmore 44102 Front Load Washer
Excess water remains in detergent/softener compartments
the best thing that you can do is to pull the dispenser out and clean it. the softener works on a siphoning action and if it is a little clogged then it will not work properly
Dec 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Laundry detergent
Why do you want to use a special detergent??? Tide works fine! You just need to use about 1/4-1/2 what is used in the American machines. Now if you really want some exceptional laundry detergent like we use in Europe, buy Persil (google it).
Dec 10, 2008 | Bosch Axxis WFL 2060 Front Load Washer
I just wanted to know what pedastals will fit with the kenmore washer 48102
BEFORE U BUY PEDESTALS PLZ GIVE THEM MODEL NUMBER AND THEY WILL LET YOU KNOW WHAT WILL FIT THANK YOU
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
236 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
