Question about Kenmore 24032\24036 Top Load Washer
During spinning, machine makes lots of big noises.
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
If you look at the section on "Machine Base Parts" you'll see a number of springs and vibration pads.
It's possible that one or more of the springs or pads has come loose or broken.
In order to get to them you have to remove the cabinet.
Here is a description of how to do it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=90fdc122f6335c7c64f46f2ea1b1c887
Also see the Whirlpool Service Manual for top load washers. It has a troubleshooting section that describes the reasons for excessive walking or vibration.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
If it's not the springs or pads, you may consider that the "Agitator Cams" in the transmission are not raising the Agitator Gear high enough (about 1/16" ) when the washer goes into spin mode. They don't necessarily have to be broken, just worn.
See the description of what the Cams do in the Service Manual.
We had the same problem, excessive vibration and noise during the spin cycle.
In order to solve that problem, :
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
Pull the transmission.
Remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (15 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
It sounds a bit complicated but it really isn't too bad and (For a $15 part, saved buying a $170 transmission.)
Following is the Whirlpool parts list for their commercial washers although the consumer models use the same part numbers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Posted on May 05, 2010
Started making a lot of noise during spin cycle. The drum seems loose. How do I fix?
Big job replacing bearings damaged for sure you can buy kit for it on internet washing machine spares hope this helps
Mar 06, 2016 | Bosch Nexxt 300 Series WFMC2201UC
Why does Miele w2515 makes loud banging noise when it is about to spin?
See if you can level out the unit. Sound like the case is responding to un-even pressures.
May 23, 2014 | Washing Machines
I have a westpoint washing machine wen it is spinning it make a lot of noise serial number wtw 500. it is a 5kg. can you help me with this problem.
Thanks for choosing FixYa and welcome to the site. You need to check your spin bearing and the motor drive. If the noise is only during spinning, you need to check these. Anytime a washer makes loud noises during spinning, always check the spin bearing and motor drive.
Apr 24, 2011 | Washing Machines
The washing machine makes a lot thumping noise during the drying cycle. Sounds like it is bout to take off. A lot of rubbing during the wash cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Dec 12, 2010 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Big noise when the washer is spinning
If the noise only happens during the spin and it is a loud rapping sound, it may be a mounting bolt.
Mar 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Sep 20, 2009 | Washing Machines
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
AWM 8163 Whirlpool washing machine
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Aug 29, 2008 | Whirlpool AWM8163 Front Load Washer
During spin cycle started making loud noise now drum feels loose
during spin cycle it makes a lot of noise could it be the bearings that have gone
May 17, 2008 | Hotpoint First Edition FEW12 Front Load...
Kenmore 24032\24036 Top Load Washer Logo
116 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
