Question about Fisher and Paykel WL26CW1 Top Load Washer
Washing maching overflows
The washing machine will not stop filling with water and completely overflows. What could the problem be and how can we fix it?
    President:
  • 2,702 Answers
Inside the washer is a fill valve it has a tube from the bottom of the tub leading to this valve if the tube is blocked with sope the washer over fills clear this tube first also if there are any holes in it it still over fills the washer, the valve works on air presher,,as the washer fills the air presher builds up in the tube and shuts this valve off stoping the flow of water into the washer,,,ok? sorry but me spelling is roten?
Posted on May 05, 2010
How to fix amana w10240534c washer wont fill?
check your water inlet valve. Check it for continuity with a multi meter it should show Ohms or a closed circuit. To test it when water is overflowing unplug the unit and see if it still overflows or continues to fill. no fill If it stops when unplugged. Then it is not a water inlet problem but an electrical signal problem going to ur water inlet valve. Possibly from the panel or board.
May 31, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Kenmore washing maching overflow after washing
The pressure switch, also called the water level switch, is what control the amount of water goes in the machine, If your machine is constantly filling to the overflow point, then that is your problem. Now, if water is going in and the level is staying the same then your machine drain line is lower than the pump and your siphoning out the water as it goes in. Pull the drain up a little a that should fix the problem.
May 28, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
WashMachine wont wash and wont stop filling
There is a rubber tube that goes from the outside of the outer plastic bowl up to the pressure switch in the top panel. It is on the left rear corner. It may have been pulled off the pressure switch. Look under on that corner and locate where it is attached to the plastic bowl. if that is OK then follow the tube up and check top connection.
Hope this will help you.
Feb 07, 2012 | Simpson Washing Machines
Maching not taking in water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 26, 2011 | Siemens WXL132GB Front Load Washer
Water doesnt stop fillinG in panasonic NA F60A6 WASHING MACHINE
Fyi. All new washing maching already tested on their functionality and features but not test run with water intake and drain function. I would like to share My experience last time with this model. The water outlet valve will release by motor when you set to drain mode.it suppose manage to retract back by spring when drain process finish or afte small you change to wash mode.
Take a look on the spring movement.normally it not properly hold valve switch hence the retracted spring not block the valve to stop water drain. Just rectify the alignment of the valve swich which directly connected to the retractable spring.
Dec 26, 2010 | Washing Machines
My Frigidaire Galaxy Washing maching will not allow water into the tub.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 07, 2010 | Washing Machines
Will not stop filling with water, overflows
Yeah, it's kinda the opposite of these tips... you got dirt in the solenoid valve and it won't shut off...
heatman101
Sep 02, 2010 | Washing Machines
The washer/dryer combo dose not stop filling up with water
check the fill valve and the connections to it the problem probly lies inthere. the valve is located inside the machine where you water hooks up.
Jul 09, 2009 | Washing Machines
Fills up with water and wont stop
if it still fills , with power off, the valve is letting by water and has become faulty,if water stops with power off,check for smudged powder at the lower part of the pressure switch pipe giving a false read to pressure switch,other than that the pressure switch has become faulty,look at the pressure switch pipe first for blockage,hope this helps
May 07, 2009 | Whirlpool WTW5200S Top Load Washer
Whirlpool washer continuouse water water runninng into tub
try turning the mach off while it is spinning and filling.if it continues to fill or drip heavy,the mixing valve is not closing completely and needs to be replaced.if the water stops when the mach is turned off,there is a problem with the pressure switch.
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Fisher and Paykel WL26CW1 Top Load Washer Logo
339 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
