Question about Star CG10I Sandwich Maker
Top and bottom caked with junk
How do i remove the caked on build up without damaging the coating on plates. Thanks
    President:
  • 2,702 Answers
Well now who's a naughty girl then??? il give you a tip,, next time your cooking in this sandwich maker put a small drop of oil or butter in it first,,,it stops all this sticking,,,,however,,, get a wet cloth,,put it in your "hot toster" and tost it a bit,,,,,the steem will clean off all the gunk for you and what it cant get off it sofens so you can rub it off with a paper towel,,,,or wet cloth,,,clean it whan its warm not when its realy hot! burnt fingers hurt? this also works in microwaves put a dish of very hot water inside shut the door and leave it for a time,,the steem dose the work for you,
now mine's a bacon butty please??
Posted on May 05, 2010
How to replace samsung LNT3253HX/XAA t-con board...There is a metal plate covering the t-con board. I removed the screws holding the plate in place.
On some sets the cables need to be removed before the metal plate will come off. If this is the case the top connector will release the ribbon cable by carefully flipping the black plastic piece down. The bottom connector has two points on the sides of the cable that need to be compressed to remove the cable from the T-con. The metal plate is having a resistance of removal due to the heat sink pad. A slight even pulling pressure will separate the two without damage, Hope his helps. :)
Apr 28, 2017 | Samsung Televison & Video
How to make a lava cake start to finih
Molten Centre Chocolate Cake Ingredients Ganache ¼ cup whipping cream
2 oz bittersweet chocolate, chopped
Molten Cakes ½ cup unsalted butter, cut into pieces
4 oz bittersweet chocolate, chopped
2 large whole eggs, at room temperature
2 large egg yolks, at toom temperature
¼ cup sugar
2 Tbsp cocoa powder
icing sugar, for dusting
Assembly Directions Ganache Molten Cakes Assembly 1. For the ganache, heat the cream until it just begins to simmer and then pour this over the chopped chocolate. Let this sit a minute, then gently stir with a spatula starting at the centre and widening the circles until the chocolate has fully melted and the ganache is smooth. Chill until firm, about 2 hours.
2. Preheat the oven to 425 F. Grease four 5-ounce ramekins, coat them with sugar, shaking out any excess, and place them on a baking tray.
3. Melt the butter and chocolate in a metal bowl placed over a pot of gently simmering water, stirring until smooth. Remove this from the heat (but it can still be warm).
4. Whip the eggs, egg yolks and sugar until they have doubled in volume and hold a ribbon when the beaters are lifted, about 3 minutes. Fold in the melted chocolate, then sift in the cocoa powder and fold in (using the beaters). Divide this batter between the 4 ramekins and chill for 15 minutes.
5. Spoon the chilled ganache into 4 truffles (you can roll the truffles between your palms to shape) and gently place this one into the centre of each of the cakes, pressing down into the batter slightly, but not to the bottom.
6. Bake the molten cakes for about 9 minutes, until the top of each cake has domed up a bit and has a dull finish. Let the cakes sit for at least 2 minutes. Lift each up using a towel, run a spatula around the cake to loosen, place a plate overtop and invert, and lift off the ramekin. Garnish with a dusting of icing sugar and serve immediately.
7. Alternately, the batter can be prepared, ramekins filled and then chilled until ready to bake and serve. Simply add an additional 2 minutes to the baking time.
Mar 28, 2015 | Baking
Ice building up in freezer section
You need to clean the drain line from the freezer it is plugged resulting in a big ice build up at the bottom. Remove the shelves and back cover you will see where the water is suppossed to drain, you will need a hair drier to melt the ice build up because it has backed up and now is frozen too. After you remove the ice build up you can take a coat hanger and insert it into the opening, see if you can work the coat hanger down through the line to push out the obstruction, if not pull the fridge out and remove the bottom cover you will see where the line exits and drains into a tray it may be plugged right there. You may have to force out the obstruction with compressed air if none of the other things work or do what I did, blow into the tube from the bottom to force what ever is blocking the line out the top, doing that though is a little messy. Cat hair or dog furr is usually the problem.
Sep 09, 2012 | Refrigerators
Hi, my Bissell 3920 has lost almost all of its suction. I checked the hoses and tubes but did not find any blockages. Filters are clean. Thanks.
Hi, Have you checked and made sure the floor plate is secure and tight without any gaps around the edges? If that's ok then check the suction hose where it bends down to the floor unit,, lots of times dirt,hair and stuff collects there when the filter was plugged up. remove the floor plate ( like you were going to change the belt ) and use a wire coat hanger to run up the suction hose and back out and clean out any debris, also check the entire hose for blockage ( top to bottom ). if this is all clear and you still have little suction - then the problem could be the vacume motor itself
Nov 27, 2011 | Bissell 3920 Bagless Upright Vacuum
The damn cakes and muffins for the easy rise oven will not rise for me oh yeah and where do I find the cake and additional cupcake accessories for this toy in canada
The muffin is controlled by using magnets. Get any magnet and put it on the bottom part of the muffin and the muffin should inflate. If not, you can remove the bottom plate on the bottom and manually remove the plunger inside.
Mar 17, 2011 | Disney Princess Magic Rise Oven
Waffles sticking to plate. Unit over 10 years old.
It probably needs to be carefully and thoroughly cleaned with a gently detergent to remove any build-up that is preventing the release of the waffles. If the teflon coating is damaged it will have to be replaced or revert to the use of a release spray when using the unit.
Feb 08, 2011 | Faberware FWM800P Deluxe Chrome Belgian...
I need to know the color code of my 2000 ford f150 radio
Look in the driver's side door jamb. There should me a sticker with the details of your truck.
At the bottom you'll see EXT PNT:
Mine says EXT PNT: SU
I believe SU is the the color code. You can probably order the paint from the dealer, or any good paint supplier can get you the equivalent.
Remember that paint can fade and change color over time, so if you're not a pro painter, blending the bright, new color will be very hard to do; you might as well just paint the entire panel or the whole truck if you're not already going to.
Feb 27, 2009 | 2000 Ford F150 Flareside SuperCab
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
LG VX8350 got wet
This just happened to me when my son dropped it in a glass of water this morning. You have to remove the battery and the 2 screws behind that plate and the 2 toward the bottom of the phone, then remove the small red plastic piece at the top back. There's another screw behind that. Then you can carefully pry the plate off. For the front plate you have to open the phone and remove ( I used a pin) the 2 little rubber nubs at the bottom of the screen. Then remove those 2 screws. Then, starting at the top front, carefully pry the front plate off. The front plate didn't come off as easily as the back one for me, but I was eventually able to get it with a flathead screwdriver without anything getting damaged.
Sep 01, 2008 | LG VX8300 Cellular Phone
Star CG10I Sandwich Maker Logo
82 people viewed this question
Top Star Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Steve
Bill Boyd
Are you a Star Kitchen Appliances - Other Expert? Answer questions, earn points and help others
