Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Craftsman mower is stalling.
It could run for 10 minute or so and then stall. I turn it off and it starts back up. This is the third cut after I had it serviced over the spring. It has plenty of gas. What could be the problem?
Vapor lock. Try putting in a new fuel filter and moving the fuel line away from the engine block to keep it from heating up and vaporizing in the line (which blocks additional fuel needed to keep it running).
Posted on May 09, 2010
    President:
  • 2,702 Answers
It could be a fulty oil level switch????
Posted on May 05, 2010
Husqvarna 61 inch zero turn model ZTH6125 Engine cuts out.
Sounds like the safety switch may have stuck. Allowing it to set, the switch "released". Just my guess.
Apr 18, 2015 | Husqvarna Garden
Craftsman lawn tractor model no.917.289101 stalls out
Stall or quits? Will it run 15 minutes again after it cools down. Check
carb bowl for water. Loosen the bottom screw a little until gas come out and water will "roll" off the gas that drops out on the deck.
May 21, 2012 | Craftsman Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Craftsman 16.5hp 42 in. Mower runs for about
mine always starts-- and won't start again if I turn it off- going to try the flywheel key replacement-- which affects the timing-- otherwise-- let me know what you find out as a solution
May 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Briggs and Straton 8 hp, craftsman snowblower stalls
Sounds like you coil is over heating after running a few minutes. The windings are seperating, then when it sools they make contact again. Try replacing the coil.
Feb 05, 2010 | Craftsman Garden
Craftsman 7.0 HP Briggs & Stratton mower stalling
Check the muffler, if the muffler is clogged it could cause overheating of the engine, and could keep the engine from getting the necessary fuel-gas mixture.
Aug 09, 2009 | Garden
YS 4500 Stalls out after running for 20 mins
I do believe they change plug(s) and air filter? There could be impurities and water in tank. Check for any loose electrical connections. Problem with valve clearance. Keep me informed.
Jun 13, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
371 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
