Question about Brother IntelliFax-2820 Laser Fax
Brother 2820 intelifax I need to set the number of Rings How do you do it
    President:
  • 405 Answers
Press Menu/set then the numbers 2,1,1.
Posted on May 06, 2010
I have a Brother Intelifax 2820 that when you fax anything it puts a black line down the middle of the page. I have taken a soft dry cloth and cleanded the corona wire and that didnt seem to help.
the corona wire, which is on the drum unit only comes into play when you are receiving faxes. if i read right and its only on sent faxes, you need to clean the scan glass. that is located underneath your control panel where your originals to fax out get fed. open up your control panel and locate piece of glass that goes left to right across machine. clean that good as you probably have white out or something similar on that.
hth,
razors
Sep 21, 2011 | Brother IntelliFax-2820 Laser Fax
Brother 2820, LED display says "telephone". I have tried menu/set, press 0, then 1, selected fax only and pressed again menu/set and then stop/exit. But telephone is still on the display. When...
Kindly check if the telephone cord is connected properly from the walljack to the LINE jack of the machine and the handset is connected to the jack that shows picture of a telephone.
If it still shows telephone press hook/speaker phone.
Hope this will help.
Mar 28, 2011 | Brother IntelliFax-2820 Laser Fax
When i send or receive a fax their i a narrow blank space down the left margin of the fax. when I send copy to fax from my PC everything is fine brother intelifax 2820
Hi!Please just lift up the adf(where u put in the faxes)U should see a thin glass strip,Take a damp cloth and gently wipe out any marks that might be on there and have a look!The stripe should be gone!Good Luck!
Dec 08, 2010 | Brother IntelliFax-2820 Laser Fax
Our intelifax says memory is full and I do not know how to clear it so we can receive faxes
This page has instructions for entering the Maintenance Mode, and for clearing memory. Note that you should only need to use the "91" clear method. The "01" method is for when the machine's memory is thoroughly messed up, or if you're selling the machine and want it to go out the door a blank slate.
Feb 17, 2010 | Brother IntelliFax-2820 Laser Fax
I would like to know if it is possible to print from my computer to the brother intelifax 2820? Is it possible to use this machine as the printer? Do I need to down load a program to do this.
Yes; the machine has printer capabilities. It comes equipped with a USB port (cord may not have come with machine and needs to be purchased). Just connect the machine to your computer via the USB and your computer will search for software to install it as a printer. You may also install it using the software that came with the machine.
Oct 26, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax-2820, will not print incoming faxes. It rings, says it's receiving data and thats it. Yes I have paper in tray. Sends and copies fine.
You need to make sure that your machine is set to "FAX" mode,not"PHONE"mode and that it is in "AUTO"receive, not "MANUAL"receive mode.
Oct 04, 2009 | Brother IntelliFax-2820 Laser Fax
How do you set the number of rings before thepick up?
I don't know for that particular model, but it should be in the manual somewhere. If not, what I like to do is just play around with the settings until I find the right one. If the fax machine has a screen on it, that should be much easier.
Jan 05, 2009 | Brother IntelliFax-2820 Laser Fax
Not receiving faxes
make sure your answering machine is plugged in to the "EXT" jack on fax machine, and your main line plugged into "line". try setting fax rings to 1 or 2. set your answering machine to 4. your fax should intercept the call and if it hears the fax tone, will receive the fax. if it doesn't hear the fax tone, it should forward the call to your answering m/c.
hth,
razors
Jan 03, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intelifax 1820c problem
that is a printhead error. call brother and see if its under warranty by giving them the serial number. if its not, the last i knew, the printhead w/ cartridges was about $100.00. hth, ray
May 31, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
66 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
