Asus P5KC board has esata but cannot get my WD Mybook recognised. Should the J-Micron eSata controller be in "IDE" mode? Would appreciate guidance. J.O.
    Genius:
  • 1,027 Answers
If you are connecting the mybook to the esata than the controller should be on esata.
This link is a generic users manual.
But by all accounts after you set it up and press the power button on the back of the MY BOOK you then power up the PC and use the MY BOOK's Disk managment to reformat it to NTFS because by default it is formated FAT32.
Posted on Mar 27, 2008
Tip
ESATA ports on Dell E-Series portables is disabled when SATA Controller is...
The eSATA port on any Dell E-Series Latitude, Precision Workstation or Vostro notebook will only operate if the SATA controller is in IRRT or AHCI operating mode. The Legacy ATA mode emulates IDE and the eSATA function of the port is disabled.
on Mar 19, 2010 | Computers & Internet
I want to install window XP into DH55TC mother board with eSATA hard drive with 500 GB but os is not support the eSATA drive. Please suggest for the same.
is it the motherboard that will not support the sata hard drive
does it have 40 pin Ide leads
if so you will have to get a Ide to Sata adapter which yuo can buy on Ebay for about $8aus
hope this helps
Dec 11, 2010 | Intel DH55TC Motherboard
My seagate hard drive wont power on,it sounds like it trys to spin then stops then trys again,my computer wont read that its connected
Do you have an different power supply to try with the hard drive? I had the exact same problem with a WD MyBook and the power supply was weak. I had the drive for a little over a year when this happened. Thank goodness for multiple year warranties on the MyBook!
Mar 11, 2010 | Seagate FreeAgent Pro 1TB External USB...
Esata controller does not see my WD My Book Home Edition
If your WD id IDE
There is 2 ports for IDE master and slave you can try to swap to see it can recognize providing you set the correct jumper for M or S.
If your WD is SATA
There is more than one of SATA ports you can try to connect for every boot.
If it doesn't recognize, either bad board or bad WD
Jul 03, 2009 | ASUS AiLifestyle P5KC Motherboard
ESATA Connection problem with My Book & my laptop w/ Vista
Had the same problem with a WD esata 1TB drive and an HP DV6 laptop. Using Vista home premium. Lots of experimentation BIOS settings and driver update, and finally fixed it by trimming back a couple of mm of the plastic shoulders on each connector of the esata cable. A few depth measurements and it became clear that the connectors weren't going in deep enough otherwise. The cable was a Belkin of reasonable quality.
No problems now, but the drive is only recognized if it's connected at boot-up.
The core of the problem is the external casing of both the laptop and the WD drive enclosure. They're thick and keep the cable connector from going in far enough. Perhaps manufacturers of the cables or the esata devices are sloppy, or the standard isn't specified well enough. I've seen pictures of esata cables that have significantly different dept.
May 14, 2009 | Western Digital My Book Essential Edition...
ESata drive not recognised by Windows XP
need to go in CMOS an
set non raid use sata mode for eSTAT ports in bios
Apr 17, 2009 | IBM ThinkCentre M51 PC Desktop
Serial problem
Get a SATA to IDE converter for you. available on ebay.com
Jun 22, 2008 | ASUS P5K-V - Motherboard - ATX - iG33 -...
Raid JMB363 RAID BIOS UTILITY
The P5K motherboard has a four port vanilla ICH9. There
Is no RAID on the Intel, when the chip has only four ports?
So S1, S2, S3, S4 are not RAID.
In the P5K manual, the RAID function exists on the Jmicron
Controller. One drive connector is internal (SATA_E2, on the
Left of the motherboard picture in the manual), and one
Drive connector is external (F_ESATA on the back I/O area).
This is not convenient for building a RAID0. (The intent is
To allow making RAID1 backup disks.) You'll have to snake
The SATA cable back into the computer, if you hope to use
It with two internal SATA disks.
The manual has full instructions for setting up RAID on the
Jmicron JMB363. The manual says to set the Jmicron to RAID
Mode in the BIOS. Two disks must be connected, in order to
Be able to press <control-J> at the start of the BIOS, to
Enter the Jmicron RAID setup in the BIOS. At that point, you
Can declare an array in the BIOS setup.
Then, when Windows is installing from the Microsoft install CD,
You’ll need to press F6 and offer the Jmicron RAID driver.
Section 5.5 of the Asus manual, describes how to make
A RAID driver floppy. The application in the mother board cd is available for make drivers disk
Dec 07, 2007 | Intel D101GGC Motherboard
Computers & Internet Logo
620 people viewed this question
David Payne
David Payne
