Question about Dell Inspiron E1505 Notebook
I think the speakers in my computer melted or blew out. They got really hot and it smelled like burnng a little bit. Now the sound is really low and crackly. What can do about this?
    Guru:
  • 109 Answers
Simple! If its still the warranty period, get it replaced.
Posted on May 06, 2010
Gouges in ceramic stovetop. Roasting pan set on a very hot burner. Pan had remnants of plastic packaging on the bottom. Plastic packaging hit the burner and explosive bits of ceramic blew up.
Lots of plastics have a very low melting point and such plastic coming into contact with a very hot surface would probably vaporise fairly explosively and that is likely to be the cause.
May 06, 2017 | Refrigerators
No air, now it works.
It sounds like the air temperature control blend door actuator or blend door may be sticking. Only a shop will be able to confirm this. I will note that your post is very confusing and provides little info that can be clearly understood about what is going on here. You may need to read what you wrote and clarify it a bit. Thanks
Oct 10, 2012 | Cars & Trucks
GETTING HOT. replaced thermastat.....ran for a while good, then got hot and melted sparkplugs...and now won't start...just turns over
There are several reasons for overheating, but I think you problem goes a bit deeper than that. For the plugs to melt you must have had an extremely lean fuel mixture that could be coupled to incorrect spark plugs and running on fuel of too low an octane rating. There is also a good chance that you have burned valves at this rate. Do a compression check and if that checks out I would say that your fuel mixture is still to lean which is the reason for your starting problem and you really need to get you car onto a computer to have it set up properly.
Feb 28, 2011 | 2005 Hyundai Accent
Speaker level really low
you have to make sure you increased the volume on the computer itself.go to the control panel and click on sound,speech and audio devices.change the volume settings and speaker settings.this should bring about the desired result.
Jul 01, 2010 | Creative Labs Inspire 6600 Computer...
Alesis m1 mk2 active emits low pitch hum and does not work
You need to take a closer look really, see if anything on the power supply board inside has melted, burned, popped, etc.
Mar 13, 2009 | Alesis M1-Active MkII Main / Stereo...
Dell E1505 speakers melted, New speakers smell burnt too.
The speakers are heating up because there is a short in the audio circuitry on the mother board, and I would consider you extremely lucky if that is all that is over drawing current and heating up. You may get lucky and be able to connect external speakers to get sound without melting your laptop.
Feb 06, 2009 | Dell ADA745 Computer Speakers
Burnt Rubber Smell
ok the rubber smell is your socks and underwear band,,and things with elastic in them ...ok open your dryer ,,look in the back where the hot air blows out,,,does it look like a burned iron..that where the clothe stick and melt too..just take a brillo with a little bit of water,,little dampness ans scrub the area..onthejob...
Feb 02, 2009 | Whirlpool LER7646E Dryer
ONKYO M282 AMP seems to have lost all mid and low range
It's probably salvagable but I doubt it will be cheap or easy. Most likely you have one or more ruined output transistors. If you're into taking things apart and soldering, it might be easy for you. Just look
for abnormalities on the transistors, usually a little hole in the center of them or blistering. Replace those and you'll either have it back to sounding good or much closer to it. Most output transistors do not fail without showing visual evidence of it.
Nov 17, 2008 | Onkyo M-282 2-Channel Amplifier
Dell Inspiron E1505 Notebook Logo
77 people viewed this question
Alun Cox
