Question about Compaq Computers & Internet
Having problem with print showing up on screen---have to unplug computor and restart for the print to show up on the screen----then works okay until it is on idle or off and then have to go thru same thing when bringing back up
  • 6,487 Answers
This is a problem with your video card driver , you can try first to install a updated driver for the video card on your computer and better uninstall and reinstall the video card driver , but by the way it will also be advisable if we can try a different monitor so we can test if this will happen again , because if same problem happen on different monitor so we now know the problem is the monitor that you have.
Posted on May 05, 2010
How do you repair a hp521n error
It depends on what kinda error it has..If it is a boot failure is best to see what is saying on screen and select the correct configuration if it is the case..or reinstall the operation system ..If it does not start to show the devices and just has a black screen the issue is physical ..and you have to see whats wrong ..If it is the cpu ..the fan will start but nothing on screen and no action at all not even a beep ..if it is the ram memory it will beep ..and restart in loop ..or freeze with devices on screen but not intelligible ..Ifg it is a hard disk failure will boot up until loading windows but never show windows screen ..and report a issued hard disk ..(in this case may be the bios settings or a unplugged cable on hard disk )
Also when the video card is to blame it may beep in sequence or long ..and showing nothing on screen ..and in this case try to on board video card if it has one ..but after you remove the other one ..
If it is just a classic case of windows failure..and it tries to load it but in error after ..cause it is missing a file or incorrect boot sequence ..just reinstall the operation system or use the recovery partition or disk to do that ..
Let me know more and I will advice after that in case..!
Dec 17, 2011 | HP Pavilion a1450n PC Desktop
On the screen it is showing L and 6 in turns if you press start key it shows 10 what can I do.someone says it is polygon motor please help
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now
If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 12, 2011 | Sharp AR-M160 Laser Printer
Error message - appropriate print head not installed - what do i do
Pixma MP760 error is showing on printer: The type of print head is not correct. Install the correct print head. I unplugged the printer for a few minutes. Didn't help. The same error window shows up when I try to print from computor. When I open the printer to look at the cartridges they do not come out to the middle.
Jan 04, 2010 | Canon Office Equipment & Supplies
I have an Elements 250G working fine until my computor started to wear out, and wouldn't show that my hard drive was there, I now have another computor, plugged in Hard drive, and the computor says it's...
If the disk is recognized, you can go to the Disk Management console (right-click My Computer and select Manage in the popup menu). There the disk should be listed, and you can check if it is partitioned and formatted.
Also check the drive letter assignment for the disk, if there is a conflict with some other device one of both will not show. You can simply change the drive letter.
More tips on this: http://www.devicedriverfinder.com/blog/device-errors/external-hard-drive-troubleshooting
Jules
Jul 19, 2009 | Western Digital 250GB ELEMENTS EXTERNAL...
After getting error 79 won't print
A solution:
  • Unplug
  • Hold down "*" & "enter/ menu buttons"
  • While holding down both buttons, turn power on
  • Wait until something like "initialize" shows up on the display
  • Let go of buttons
  • Wait until display reads "ready"
  • Unplug for 10 seconds, then plug back in
  • Hope it works for you
Apr 24, 2009 | HP LaserJet 3330 All-In-One Printer
Need to turn off report after every fax sent
Press [function] button and then [dataregistration] on the display dataregistration will be displayed,press [ok] user settings will be dislpayed,press the arrow down until you find report settings press [ok], tx report will be displayed,Press [ok] again.It will show on the screen "output yes",press the arrow untill it show "output no" and press [ok] again.
Thats it.
Apr 01, 2009 | Canon FAXPHONE L80 Laser
Printing does not start until I restart computer
Drivers are very good. If you will go on the website and look for the firmware(not the driver) for the printer. This is the "driver" for the printer to communicate with the signals of the computer. Sometimes, it needs to be updated if the manufacturer finds they need to be more compatible with more operating systems, such as the new Vista. Hope this helps.
Nov 30, 2008 | HP PSC 1410 All-In-One InkJet Printer
E-mails won't print the last few words on the right side.
Your margins need to be adjusted. Do a print preview. You should see the margins. Click on the right hand margin and drag it over to the right until the rest of your document shows up on the screen. If you print it then it should be fine.
Nov 13, 2008 | HP PSC 1410 All-In-One InkJet Printer
Computers & Internet Logo
21 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
