Question about Akai Mpc2500 Music Production Center
My mpc 2000xl is not recognizing the sound disk when i try to load what should i do?
Try letting it sit for a few minutes. That worked most of the time with my xl
Posted on May 21, 2010
Help with using usb chord and sony vaio lap top.
Have you tried a different usb port or different usb cable also boot off your laptop and connect then connect the mpc 1000 and boot it up also make sure you have install the correct software for it
Jun 26, 2012 | Akai Mpc2500 Music Production Center
Im trying to connect my mpc 2500 with pro tools 8. im using an mbox 2 pro as my interface. I can get pro tools and the mpc to sync...but i cant seem to understand why i cant hear any of my samples from the...
Check if the Mbox2 has an echo setting that echos the audio from its input. If you want the audio to loop through the PC then it will have to echo there instead. Check that in "Sound and devices" of the PC are all set to transfer via the MBox for voice and playback instead of the internal PC audio system.
Apr 12, 2011 | Akai Mpc2500 Music Production Center
How do you wipe out everything and put back regular settings on the mpc 2500
from the akai forums:
to set the os back to factory settings press and hold the erase key till the mpc has booted to the main screen.
to erase the harddisk goto either the load or save screen and then choose utility - there you will find the option to format the hdd.
you can also format the drive (or any inserted compact flash-card) from your computer thru the usb connection, but it is recommended to use the internal format because the mpc can be a little picky when you format it from the outside.
at first i would check if there is any folder or the internal memory is set to autoload and just turn that of or point it to another folder of you choice. that way you can keep the factory delivered sounds. maybe you want to use them later, even if it is just to explore the mpc. the factory sounds can be also downloaded later, but be advised that there are different iterations of the stock sounds, depending on whether your mpc shiped with a 32 or 128mb compact flash card.
also the mpc os is not on the harddrive but in the internal memory. to check the version hit mode-> pad10. latest official version is os 1.24. if your main srceen looks different than in the manual check double and triple before you do anything, because the previous owner might have installed the third party jj os which comes in different versions. some of them cost a lot of money! if you find this check the other forum here for the alternative os.
Mar 05, 2011 | Akai Mpc2500 Music Production Center
I am trying to record sounds from my keyboard into my MPC 1000. I have what I think is the proper set-up. MIDI sync...softthru as track...etc. Problem is when I set it up I can play one sound and record...
It is not clear whether you are recording audio or MIDI. If you recorded Audio samples, you will get the same sounds back even if you change the voice on the keyboard.
If you record a MIDI sequence, and then play it back you will STILL get the same sounds UNLESS you also record the MIDI voice or patch changes so the voice is changed as it occured when you recorded it. Usually there are options taht you can enable or disable voice changes.
Feb 11, 2011 | Akai Music
JUST WANT TO INSTALL FX BOARD IN TO 2000XL
Try downloading the manual for the 2KXL. It should have instructions. Here's the link to download:
http://www.mpcsounds.com/download_akai_mpc_manual.php
You'll have to scroll down the page to find your manual, but it might help.
Feb 07, 2011 | Akai Music
I purchased an akai mpc 2500 used and it came with sounds and sequences all ready occupied, how do I delete all these sounds, or restore its factorys settings?
Try holding erase while you turn it on. You may have to turn off autoload also. You'll have to read the manual first ( pages 110 and 114 especially ) available here:http://www.mpcsounds.com/download_akai_mpc_manual.php It depends I think on whether the previous user saved to memory card or the internal HD.
Aug 20, 2010 | Akai Mpc2500 Music Production Center
What sound files can be loaded from a pc to an mpc 500? aiff, wav,mpc...? thanks
Data Compatibility
MPC1000: SEQ, WAV, PGM
MPC2000/2000XL: SEQ, WAV, SND, PGM (Most parameters of PGM file can be loaded.)
MPC4000: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
MPC3000: SND (THRU Computer)
Z4/Z8: SEQ, WAV, PGM (DRUM program only. Only note assign and tune are loaded.)
S5000/6000: WAV only (THRU Computer)
S1000/3000: No compatibility
Feb 21, 2010 | Music
I have a Mpc 2000xl. I also have a small fast track m-audio. My bx5a monitor speakers the grey and red wire is connected to that. There is a guitar symbol in the back of my fast track m-audio. So what i...
The jack with the guitar symbol is a high impedance input for a guitar so you will get a proper level and sound when plugging your guitar straight in. All of your question did not appear in the post so try rewording it so we know what you are trying to do. Thanks.
Jan 25, 2010 | Music
Loading an MPC5000 with midi files
if the mpc has GM soundbank then this should be possible. You might be better off recording the audio from a suitable GM unit first of all before gigging with it, then you can make it sound the way you want and change the key to suit etc.
Dec 18, 2009 | Akai Mpc2500 Music Production Center
Not reading my floppy disk( MPC 2000xl by akai)
Have you tried formatting the disc using your MPC 200XL?
Mar 20, 2009 | Music
Akai Mpc2500 Music Production Center Logo
116 people viewed this question
Top Akai Music Experts
T-Comtech Repairs
T-Comtech Repairs
ray gallant
Are you an Akai Music Expert? Answer questions, earn points and help others
