Question about Haier HTF27R11 27" TV
I would like to know if i can or if my tv is digital ready its a Haier HTF27R11 27" TV. I tried to hook up an antenna but get nothing but snow in tv
  • 736 Answers
This tv requires a convertor box. It is not digital ready.
Posted on May 05, 2010
My tv just went off all at once to nothing it just looks like snow on it thats it and we have it hooked up to cable and was viewing it at the time
snow is an indication of signal failure either from the station or an antenna connection problem
if it all channels then I would be looking at the cable connection at the cable box or outside antenna connections
Mar 03, 2016 | Panasonic Original Pansonic Tv Vcr Dvd...
I have a Toshiba tv and I need to hook it up to my direct tv box and all I get is snow. Please help
snow is an indication that the antenna is not properly connected
try connecting the antenna cable to the input of the box then from the box to the input of the tv
follow the user manual directions
Feb 08, 2016 | Toshiba Televison & Video
MY NEW HAIER 7" TV SAYS "NO DATABASE"! AND WHEN
Don't throw it away just yet. It's still under warranty so returning it would be far better than throwing it away ;)
As you can tune the cable channels OK, I suspect there is a problem with the reception from the antenna and the signal strength is too low. Please can you answer the following simple questions so that I can help you to solve this problem
1. What antenna are you using - indoor/rabbit ears or outdoor/roof antenna?
2. Do you have a good reception on another TV connected to the same antenna ?
If you are using an indoor antenna, try moving the TV to another location to see if you can get a better reception.
Please let me know the answers to the above questions. I will then be able to assist you further.
Regards,
BElectric
Jan 22, 2011 | Haier HLT71 7 in. Portable TV
I'm wanting to know if this TV is one that is Digital or analog? Will I need to buy a converter box for it if it isn't hooked up to cable or direct TV? I believe it was purchased in 2006.
No.It is a digital tv.Just require a good digital antenna for a better and a longer ranges for the tvs broadcasting stations incommming signals.After a digital antenna is hook up.When u go in to the tv menu go to Setup.go down to CH. pick AIR and enter and tv should be automatically be scanning for DTV free air broadcasting tvs stations.
Dec 05, 2010 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Does my haier 20AL25S have a digital tuner?
If you cant get HD channels through a tv antenna then you dont have a digital tuner
May 27, 2010 | Haier 20AL25S 20 in. EDTV-Ready LCD TV
HOW TO HOOK UP A ANTENNAE
Well you can follow the below steps -
1. Inspect the antenna for any signs of damage. Identify and examine the power adapter cord and the coaxial antenna cable for any rips tears or other defects.
2. Plug the adapter into the antenna's power adapter socket. It will be labeled "12V DC/Adapter". If you are using an antenna that does not require power, such as rabbit ears, you may skip this step.
3. Next connect the antenna cable to the television using the TV's "Antenna In/75 Ohm" input jack. Make sure the antenna connector is twisted tightly into place. Place the antenna on a sturdy surface such as the top of an entertainment center. If you have an older analog TV that is a non high definition ready/capable display and are using a digital to analog converter box, generally, the antenna will plug into the input of the converter and the output of the converter will plug into the antenna input of your TV.
4. Plug the antenna's power supply into a 120V AC wall outlet. This will turn the antenna on. If you are using the "rabbit ears" style antenna, make sure that the each section of the antenna is fully extended. This will give you the best reception.
5. Turn on the TV and check for digital reception. You will know that you are receiving digital signals because the picture will be clear and free of any analog "snow" or other artifacts. Digital TV channels have DVD quality picture and sound.
Follow the below link for more help -
http://www.wonderhowto.com/how-to-hook-tv-antenna-094240/
Good Luck!!
Mar 26, 2010 | Akai PDP4273M Television
NOTHING BUT SNOW ON THE SCREEN
Are you connected to cable TV or an outdoor antenna? If on cable TV check the signal on another TV or if on an outdoor antenna you will need a digital TV adaptor to pick up local stations due to them not being available in analog anymore. Please take moment to rate my answer. Thanks...
Nov 26, 2009 | Toshiba 32D46 32" TV
No HDTV reception with Jensen JE3269 LCD tv
Looking at the manual, the specifications indicate that this is an NTSC TV. You would need an ATSC tuner (a digital converter box) to convert the digital signals into the analog ones that this TV can receive. You may also need an antenna designed for DTV signals to get a good reception.
Nov 11, 2017 | Televison & Video
Sanyo tv # DS35580
you need a new tuner
Dec 04, 2007 | Televison & Video
Haier HTF27R11 27" TV Logo
224 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
