Question about Panasonic PT-52LCX65 44" HDTV
Have green spot on left third of picture.
Replaced lamp two months ago and in the last couple of days noticed a green spot light in the left third of picture. Can this be ajusted or did I get a bad lamp?
any help will be appreciated.
  • 308 Answers
Is it an LCD rear projection? Then it is the light engine. Confirm it with a tech visit and then buy another set. The light engine costs as much as a new set.
Posted on May 05, 2010
White fog "ring" around outer third of screen. Dark spots and a single white pinhole in picture as well.
If the model above is correct you are describing a bad optical light engine, about the most expensive part inside that set.
Dec 13, 2012 | Mitsubishi WD-65737 Home Theater
I have a Samsung HLT6176SX/XAA. Can anyone tell me what a blinking green and blinking red light mean? Sounds like it is trying to power on but no picture comes up.
Hello. I had the same problem your having. You need to replace the lamp. I bought a replacement lamp on ebay for $99.00 (Lamp code: BP96-01795A (P132W). They don't last long though. After 4 months I have hundreds of white spots on my screen.
Oct 09, 2010 | Samsung HLT6176S Television
6 months ago, the colors started messing up and it made this screaming banshee sound. The TV would turn itself off after a minute or so. I read about it and figured it was the color wheel. I bought a...
You need to put in the values for x,y, of red,blue,green & white.
when you get the color wheel, sticker(printed values) was in the same box.
If you have, let me know and I''ll let you know how to put in.
Jan 13, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Just replaced bulb two days ago and now theres no picture
there could be a couple of things causing thie, make sure the lamp is all the way plugged in, make sure the lamp door is on and completily closed, also if a fan is stuck and cant spin, also the ballast can cause this, that is the small board that lights the lamp
Jan 11, 2009 | Mitsubishi WD-62531 Projection Television
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Light green and pink spots on my hd tv!!!
Hi--Bought my panasonic pt-52lcx65 on sale for $2200 in 8/05. Replaced the lamp for about $300 in 1/08, just prior to Superbowl. Admittedly, this was to be expected after family members watched lots of tv over 30 months. However, two months later the blue spot emerged in 3/08, and red spot emerged 5/08. Set looks decorated by a Andy Warhol or Van Gogh wannabe. I'm looking for a fix it solution. Dr. Bob Heiliger, Lebanon, OH.
Jun 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic PT-52LCX65 44" HDTV Logo
237 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
