Question about Kodak EasyShare P850 Digital Camera
Flash slow to get started.
When I first turn my camera on, I have to take 6 or 8 pictures that will not flash before my flash will work. It then works fine until I turn it off. This happens even in flash fill mode.
    Guru:
  • 1,049 Answers
The capacitor that runs the flash is going bad.
I'm no electrical engineer, but as it was explained to me...These things are filled with a semi conductive gel that dries out as they go bad, when this happens they don't conduct electricity. But when your starting the flash, the resistance causes the capacitor to heat up until it liquefies and starts to conduct electricity again. As a result, each time it takes more to get it going, eventually however it will burn out and stop working altogether.
That said, I'm not sure how you would go about replacing it without a trip to radio shop, a soldering gun, and some experience with electronics repair.
Posted on May 05, 2010
The flash does not work when i make a picture on dark situations
you must set the flash to turn on by pressing "FLASH" button near the lens...
or set it manually by press (+) / left bottom beside the LCD
you can choose Flash OFF, RED EYE REDUCE,FLASH ON, SLOW SYNC and REAR SYNC
thanks
Jan 03, 2011 | Nikon D40x Digital Camera
My flash isnt working on my A835 camera and i have only had it for 6 months
Check the flash mode that your camera is set to. The flash modes are: Auto, Red-Eye Reduction, Forced Flash, No Flash, Slow Synchro, and Red-Eye plus Slow Synchro. You might have the flash mode set such that your camera detects that the lighting doesn't require the flash mode selected. You can try manually overriding the flash mode by pressing left on the circle function button next to the LCD view screen. If you are still unable to manually turn the flash on, try changing the shooting mode with the mode select dial on top of the camera, then if necessary repeat the flash override step mentioned above. Repeat until successful. There is also the possibility that the flash is malfunctioning, but that is less likely than a setting issue. Let me know how you make out.
Jan 02, 2010 | General Electric A835 Digital Camera
The flash will not work on my Samsung S860 Digital Camera. It used to work and now it doesn't... I tried to go through the menu to fix it and it seems to say it is on? But, when you take a picture it does...
the S860 has three flash modes in which the flash only fires under certain conditions.
- in Auto Flash mode and Auto & Red Eye Reduction mode, the flash will only fire if the subject or background is dark; otherwise it won't flash.
- in Slow Synchro mode, the flash only fires when the camera's using a slow shutter speed.
if you have your flash mode set to any of these, the flash will only fire when the camera determines that flash is needed; otherwise it won't fire. to have the flash fire all the time and automatically vary its intensity according to how much light is needed, set the flash mode to Fill flash; to turn the flash off altogether (so that it won't fire no matter what), set the flash mode to Flash Off.
for all the details on the S860's flash modes, you can download the user manual here and refer to pages 28 and 29.
hope this helps...
Mar 08, 2009 | Samsung S860 Digital Camera
Flash doesn't work
check the flash settings.. it just might be on 'Slow or Rear' flash mode. good luck!
Nov 08, 2008 | Nikon D40x Digital Camera
Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Sep 25, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Canon SD 550 does not work when flash setting is ON
I have the same problem. Cannon customer support says it will fix this for $119 + 8 for shipping... or you can get a refurbished SD 800is for $140+10 for shipping with w/ a 6 month warranty... what a deal ;~)
Sep 04, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Flash
Did you try to reinitialize? Setup menu go down to the third Setup#1 menu and make sure you click OK to reinitialize. That's what the manual said.
Apr 28, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Random Pictures?!??!
look for a small opening to insert a pin. many companies offer this hole as a way to reset the micro-controller. insert the pin during power up
May 07, 2007 | Sanyo VPC- C6 Digital Camera
Flash doesn't work as it should
Hello, in order to repair your camera the IC851 is to be replaced. This integrated circuit is used for flash control. Please do not try to fix it yourself. Contact your nearest Authorized Sony Service. If you need more info please advice.
Aug 24, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Kodak EasyShare P850 Digital Camera Logo
63 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
