Question about Nakajima AE-740 Typewriter
How can I set the spacing (width) for the characters? Thank you.
  • Nakajima Master
  • 3,594 Answers
There is a slide switch on the L. side labeled 15, 12, 10 and PS move it to 10 (spaces per inch) this will make the letters farther apart. To make the type larger you must put in a printwheel with a larger type face.
DickyO
Posted on May 12, 2010
What is the largest size of lettering and how do we space between words
The built-in character size is usually restricted to the same width as the widest zig-zag your machine will make--most machines are 5mm or 9mm.
Spaces are usually made by programming some straight stitches between words (begins around page 73 of the manual).
ELNA 7200 Manual
Apr 09, 2016 | Elna 7200 Computerized Sewing Machine
How do I change the font size
Hello,To change the font size, do the following: 1. Press the “Function” key 2. Press the “Left Arrow” or the “Right Arrow” key until the display shows “SIZE”. 3. Press the “Function” or the “Return” key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display. 4. Press the “Left Arrow” or the “Right Arrow” key until the desired Size is displayed. * SIZE1 equals Standard Size. * SIZE2 equals Double Width. * SIZE3 equals Double Height. * SIZE4 equals Double Width & Double Height. * SIZE5 equals 4 x Width & Double Height. * AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine. Press the “Function” key or the “Return” key to select the characters size. I hope this helps.
Jan 04, 2016 | Brother P-Touch Brother Pt90 Label Maker...
How to change Tally T2240/24 Matrix Printer character and line spacing
This sounds like an Microsoft Excel issue. The Windows printer driver controls how printing is done regardless of your printer settings.
Excel controls the format of your page with column widths and line height. Depending on your version of Excel, after selecting your print range and your margins, you will need to go to Page Setup and select "Fit to" -- select 1 page wide and a larger number of pages tall.
Jul 25, 2014 | Tally T2240/24 Matrix Printer
614 invalid data
614 definition is Portion of the field is off the tag. A way to explain this is that you've created a field that supports up to 25 characters, and the width of that label is only 2 inches. If you typically print using 22 or less characters in that field, you never see the problem, but when you use 23 or more characters, you get a 614. Meaning that characters 23 and higher don't fit in the designated space.
You could move your field closer to the edge of the label to see if you can get additional room for the additional characters. You could choose to use a smaller font, or reduce the width of the current one being used so as to fit more in the same space, or you could consider using a feature in the printer to ignore imaging errors.
Note that using that feature can give you the net result of not all of the needed data fitting on the label that you designed. That could cause pricing errors, incorrect or unwanted descriptions, various other codes, etc.
Reply back if you think that you'd like to use the feature of ignoring the imaging errors and I can see if your printer supports the feature, as well as provide the step by step you need to enable and disable the feature for versions that support the function.
Oct 09, 2013 | Monarch 9855 Thermal Printer
Can you replace the printer ribbon on the Seiko DPU414 Printer?
ANSWER: Since it is a thermal printer it does not have a ribbon to replace.
Description:
The Seiko SII DPU 414 thermal Printer. For a compact desktop or portable thermal printer, the DPU-414 is an excellent selection. It incorporates the STP printer mechanism to ensure silent and high-quality printing of characters and high-density graphics. And in quadruple-density bit image mode, 640-dot (maximum) CRT display hardcopy is possible (with horizontal vs. vertical radio of 1:1).
Product Specifications
  • Model DPU-414-30B
  • Printing Method Thermal serial dot printing
  • Number of dots/line 9 x 320
  • Paper width (mm) 112
  • Printing width (mm) 89.6
  • Max Speed (character/sec) 52.5
  • Paper path Curved
  • Character matrix (H x W dots) 9 x 7
  • Character size(H x W mm) 2.5 x 1.9, 2.5 x 0.9 (Condensed)
  • Number of columns 40, 80(Condensed)
  • Character type Extend Graphics Character set, Alphanumeric, International Characters, Katakana Character set
  • Interface Parallel (36pins Amphenol), Serial (9pins D-SUB)
  • Input buffer 28Kbytes
  • Command ESC/P * conformity
  • Cutting Tear bar
  • Operating Temperature (°C) 0 to 40
  • Humidity (%RH) 30 to 80(Non condensing)
  • Service life (line) 500,000 **
  • Dimensions (W x D x H mm) 160.0 x 170.0 x 66.5 (printer unit only) ***
  • Mass (g) Approx.580(without Battery)
  • Compliance FCC, CE, VCCI
Manual:
http://sii-thermalprinters.com/pdf/manuals/DPU414/DPU-414_User_Guide.pdf
Feb 13, 2011 | Seiko Office Equipment & Supplies
Brother p-touch model 1880 label maker- how do you change the font size
1. Press the "Function" key
2. Press the "Left Arrow" or the "Right Arrow" key until the display shows "SIZE".
3. Press the "Function" or the "Return" key. The current selected size setting is displayed and a triangle indicator pointing a sample of the character size above the display.
4. Press the "Left Arrow" or the "Right Arrow" key until the desired Size is displayed.
Press the "Function" key or the "Return" key to select the characters size.
I hope this helps.
Aug 09, 2010 | Brother P-Touch 1180 Label Printer
I can't figure out how to make the font size larger
Try this solution to change the font size:
1. SIZE1 equals Standard Size.
2. SIZE2 equals Double Width.
3. SIZE3 equals Double Height.
4. SIZE4 equals Double Width & Double Height.
5. SIZE5 equals 4 x Width & Double Height.
6. AUTO, the machine will automatically adjust the characters to the largest possible size according to the width of the tape installed in the machine.
Hope this helps.
Aug 04, 2010 | Brother P-Touch 1180 Label Printer
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Tv lack of horiz. width
hi there, lack of horiz. width means horizontal section problem, test some electrolytic capacitor at horizontal section and try video section. ty
Jan 27, 2008 | Televison & Video
Nakajima AE-740 Typewriter Logo
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
