Adding a second oomputer to network, have router on one, have USB wireless product for second?
    Sergeant:
  • 349 Answers
Well if your router is wireless it should be straight forwards,make sure the router wireless function is turned on in the router, the software that came with your usb wireless product will have a function to find all wireless broadcasts in your immediate area, select your one ,make sure,that if you have used a security key(such as WEP), that you use it also in the software of the usb product.
good luck
Terry
Posted on Mar 27, 2008
How do I connect my Macbook to my Kodak wireless printer with my Belkin G+MIMO router?
When you added the WPS encryption ket to your wireless router, this secures your wireless network from unauthorized access to you wireless network.
To allow your wireless computers and wireless printer to communicate with your wireless network the wireless cards in the computers and printer needs to be configured with the WPA encryption settings that you configured in the wireless router.
May 26, 2012 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I am trying to connect my Dlink DKT-401 router to my Linksys cable gateway router. I am not getting internet access when connecting to the Dlink network
I DON'T THINK YOU CAN RUN 2 ROUTERS ON THE SAME NETWORK UNLESS ONE IS USED AS AN ACCESS POINT.
1. Connect as local device or bridge - If connecting the second router via Ethernet cable, plug it into one of the LAN ports on the first router. If connecting the second router wirelessly, ensure the second router is set for client mode. Note that some home wireless routers do not support client mode; these must be connected by cable. Check your router documentation for details on its client mode configuration support.
2. Check / change IP address - Most home network routers use a default IP address setting. Often, these default IP addresses will not work in a two router environment. Check the second router's IP address value and reset it if necessary to work within the valid address range of the first router (and to not conflict with any other device on the network).
3. Disable DHCP - To avoid IP address conflicts between all of the devices on the home network, only one of your two routers should assign addresses via DHCP. All mainstream routers provide an option to disable DHCP as part of the router's configuration screens.
Instead of adding a second wired router to an existing network, consider adding a network switch instead. A switch accomplishes the same goal of extending the size of a network, but it does not require any IP address or DHCP configuration, greatly simplifying configuration.
Readers Respond:
Dec 11, 2010 | D-Link Computers & Internet
I have a dynex enhanced wireless g network adapter. The computer that uses it is a windows xp. The computer will recognize it and it will show up but I can't connect it to any wireless networks. There is a...
Does the stick see any other wireless networks? Can you try creating an Ad-Hoc network from your other laptop to this one through the USB stick? If the answer to either of these two questions then the stick is working fine.
I would check to make sure your router is not using solely a N network type because the USB stick will not support it.
If you are using a duel band router and you are currently using the 5ghz network then the USB stick will not detect this either.
Lastly if your network is not being broadcast, your laptop may connect to the network but your USB stick will not be able to locate the network.
You can also try power cycling the router (unplug for 30 seconds) and then search for networks again.
Thanks,
Pat
Nov 07, 2010 | Dynex Wireless-G USB 2.0 Network Adapter
Need download for other computer to be added on
To add a second computer, take an Ethernet cable, and connect it to one of the LAN ports on the router, and to the network-port on the second computer;
there's no need for any "download" to make this work.
If the second computer has a wireless adapter, then click 'View Available Wireless Networks', and click to connect to the network.
Jun 15, 2010 | Linksys Wireless-G WRT54G Router
Adding second laptop onto wireless internet problem
What is the problem?
What error-message(s) do you see?
What happens?
What does not happen?
Click "View Available Networks", and click to connect to the network-name ('SSID') that you defined when you did the "setup" on your wireless router.
Apr 10, 2010 | AT&T High Speed DSL Modem
Can't scan
To test the hardware, use the product to copy a document.
1.open the scanner lid.
2.put a document face down on the glass.
3.close the scanner lid.
4.press the copy button.
make sure that the product connects to the network
ethernet connection
1.Disconnect the network cable from the back of the product, and then wait a few seconds.
2.Reconnect the network cable to the back of the product.
3.Make sure the other end of the network cable connects securely to the router or switch
4.Make sure that the lights on the router or switch are on.
5.Continue to "Step three: Print a network configuration page and find the IP address."
wireless network
  1. Make sure that the router or access point is on.
  2. Position the router or access point closer to the product.
  3. On the product, press the setup button , and then select the network option.
  4. Select the wireless setup wizard option. The product searches for the router or access point.
  5. Select the 'enter the new network name'(SSID) option.
  6. Type the service set identifier (SSID) or the name for the wireless network, and then select 'done' . The product searches for the network.
  7. Select the relevant authentication protocol, also called the security mode. Supported protocols include WEP (64 bit and 128 bit) and WPA-PSK (WPA1 or WPA2, AES or TKIP). Networks that do not use an access point or a router, known as ad hoc networks, support WEP encryption only.
  8. If the network uses media access control (MAC) address filtering, make sure that you have the router or access point set to allow the MAC address for the HP product.
  9. Follow the instructions to configure the product for your method of network security:
  10. WPE: Log on to the router or access point from the computer, and then find the wired equivalent policy (WEP) key set within the router or access point. If you specify the WEP by using 10 or 26 hexadecimal characters, make sure that the characters are 0-9 and A-F. Use the on-screen keyboard on the control panel display to type the WEP key on the product.
  11. WPA: Log on to the router or access point from the computer, and then find the Wi-Fi Protected Access (WPA) passphrase set within the router or access point. Use the on-screen keyboard on the control panel display to type the correct WPA passphrase.
make sure that the product is connecting to the network, print a network configuration page from the product and find the IP address on the page.
1.On the product control panel, press the Setup button
2.Select Network , select Network Settings , and then select either Print Network Settings or Print Network Configuration Page . The network configuration page prints
3.Make a note of the IP address for the wired or wireless connection. The IP address should resemble the example: http://192.168.1.1
4.If the computer connects to the Internet using a wired connection, the IP address displays in the Wired section.
5.If the computer connects to the Internet using a wireless connection, the IP address displays in the Wireless section
Jul 21, 2009 | HP Officejet 4315 All-in-One Printer
Can i connect my f4180 printer to a router and access it wirelessly
Your printer uses a USB interface and can be connected to a wireless network using a print server simular to the Linksys WPSM54G.
I have also found on the web several wireless routers that incorporate a USB print server function, that is they have a USB port that connects to your printer and allows it to be shared on the network.
Be careful not all routers with USB ports are for printers, these newer routers have USB ports for adding network shared disk storeage boxes and do not support printers.
They all incorporate a user friendly WEB based configuration program to help you do this so don't think you need a degree in computer science.
Jun 10, 2009 | HP DeskJet F4180 Inkjet Color All-In-One...
Remote pc cannot access wireless
You can do a reset on your router. All computers must be must be getting its connection from your router. Your wired computer must be getting an ip address from the router(example is 192.168.1.x). You can then access the router page using your browser by typing the default gateway(example 192.168.x.1). This will take you to the router configuration page. You can set up the wireless network and your wireless network can now support more than 2 wireless computers.
Mar 14, 2008 | Computers & Internet
Home wireless network
Most wireless1.gif networks are setup as infrastructure networks, meaning all communication is to/from a wireless access1.gif point/router that serves the same function as a switch/hub in a wired network as a central point to transfer communications from machine to machine. One works over the air the other through a wire.
There is an alternate form of wireless networking1.gif refered to as ad hoc -- in this version of wireless networking every wireless adapter1.gif can "talk" to any other wireless adapter configured with the same SSID (name) and security encryption (none, WEP, WPA). This is how somewhat less impromptu wireless networks are created similar to impromptu infrared networks some of us have used. One limitation of the ad hoc networks I have seen configured to date is access to the internet. I have posted an article where a stationary PC (required to be running for any other wireless machine to access the internet) with a wireless card in ad hoc mode could act as the router for wireless network but it required a cabled connection the internet. I suppose it could be a second wireless connection on a separate channel with a second wireless adapter in an infrastructure network but why? These types of networks are only recommended in another article for a limited (small) number of machines.
Based on this are you asking to create an ad hoc network to connect 2 PC's1.gif wirelessly without a wireless router1.gif or access to the internet from the wireless network (without a dedicated machine)?
Dec 19, 2007 | Linksys Wireless-G Broadband Router
Compaq n6120 - can't connect wireless
Most wireless networks are setup as infrastructure networks, meaning all communication is to/from a wireless access point/router that serves the same function as a switch/hub in a wired network as a central point to transfer communications from machine to machine. One works over the air the other through a wire.
There is an alternate form of wireless networking refered to as ad hoc -- in this version of wireless networking every wireless adapter can "talk" to any other wireless adapter configured with the same SSID (name) and security encryption (none, WEP, WPA). This is how somewhat less impromptu wireless networks are created similar to impromptu infrared networks some of us have used. One limitation of the ad hoc networks I have seen configured to date is access to the internet. I have posted an article where a stationary PC (required to be running for any other wireless machine to access the internet) with a wireless card in ad hoc mode could act as the router for wireless network but it required a cabled connection the internet. I suppose it could be a second wireless connection on a separate channel with a second wireless adapter in an infrastructure network but why? These types of networks are only recommended in another article for a limited (small) number of machines.
Based on this are you asking to create an ad hoc network to connect 2 PC's wirelessly without a wireless router or access to the internet from the wireless network (without a dedicated machine)?
Dec 19, 2007 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
