Question about Bosch DKE9305UC Stainless Steel Kitchen Hood
My Bosch hood over my oven blows air instead of sucking or pulling it up and out. Bosch model DKE9305UAC
GE Microwave exhaust fan reversed after replacing filter. Now it blows air instead of sucking air.
Try a hard reset - unplug it for 2 minutes, then try it again.
If you need more help, feel free to contact me through my site and remind me of your full model number from the tag on your oven as well as detailed symptom information.
Oct 22, 2016 | GE Microwave Ovens
Kenmore Elite Microwave Hood Combination fan blows air out of the top but is not sucking in the heat from anything on the stove...for example boiling water.
does th fan exhaust to the outside --filter clean --directional duct to out side --also small unit so will not suck air like a standard stand alone exhaust fan which are over 3 to 4x the size
Jul 31, 2016 | Kenmore Microwave Ovens
Just installed the hood range and it is blowing not sucking
The blower is either installed wrong or the motor is running the wrong way...
heatman101
Feb 08, 2011 | Broan-NuTone Kitchen Ranges
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
A local small contractor installed our Kobe RA3830SQ Range Hood a few days ago. We have not been too impressed with the efficiency of the fan. Today I noticed that it seems to blow out instead of sucking...
Hoods should blow out from the chimney, its defianately not a wiring problem. If it is blowing down towards your cooker instead of sucking up then you should contact Range as it could be a manufacturing fault.
Dec 06, 2009 | Kobe RA3836SQ Under Cabinet Range Hood
Brand new Kenmore microwave fan does not **** up air
It's easier to notice air blowing out of something than it is to notice air being sucked into something. Put a pot of boiling water on the stove and see if the oven sucks up the steam from it. If it does, it's working fine.
Sep 17, 2009 | Kenmore Kitchen Ranges
Pilot light still going out
If this oven has a "stack" (where the hot gases & heat vent to your hood) air could be blowing down the stack affecting the pilot. Simple test, Bic lighter lit at the top of the stack in the middle of the opening. If the flame is being sucked down the stack, then you have air blowing the pilot out. How old is the thermocouple on this unit ? Pilot flame heats this up to send a signal to your main gas valve to open up so the burners light. A weak t-couple could be your problem. Hope this helps
Jul 23, 2009 | Bakers Pride FC-616 Gas Single Oven
Blow back istead of suck out
This installation guide on the Jenn-Air web site does not provide electrical details, but there are two possible problems here.
1. - The fan could be installed backwards...or upside-down...so it moves air the wrong way
2. - The power wires might be connected incorrectly.
My best guess is that the fan uses a standard ac-powered motor, so the polarity of the wiring would not affect the direction it turns. If that is true, then the most likely problem is that the fan is installed incorrectly.
Good luck...and I hope this is helpful!!
Jan 17, 2008 | Jenn-Air JXT8030ADS Kitchen Hood
Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Jan 07, 2008 | Vacuums
Dysons aren't supposed to clog up, but they do. There a number of ports you can open to see if there are clogs in any of them. Usually a clog is why it will blow air and debris out instead of sucking. You just need to find it.
Jan 05, 2008 | Vacuums
Bosch DKE9305UC Stainless Steel Kitchen Hood Logo
26 people viewed this question
Top Bosch Kitchen Ranges Experts
William Miller
William Miller
ashburton
Are you a Bosch Kitchen Range Expert? Answer questions, earn points and help others
