Question about Emerson EWC1304 13 in. TV/VCR Combo
I need to connect a digital bos to my emerson 1304 tv.i can not find any place to connect the coax
  • Emerson Master
  • 8,457 Answers
The antena hole input in the Converter box that where said the input source said Ant.,use a antena like a digital antena,roof antena or a rabit ear antena.Hook up ur source of the antena go in that hole.The hole input said out to tv in the Converter box,use a cable that was supply to u,came with the Converter box.Use that cable plug in the Conveter box tv hole said out to tv.The other end of that cable go to ur tv Ant. hole.Now u got it all hook up.Turn ur tv to channel 3 or 4 now u got a menu from the Converter box,go down to the highlight word said scan channels,push that highlight word.Ater the scan are finish,u will now get all the free DTV channels.
Posted on May 05, 2010
How to connect my wii to a cable box with my Emerson TV?
You cannot connect wii to a cable box. You have to connect your wii straight to the TV using the red, white and yellow connection cables that came with wii. If your TV is older and only has a coax cable connection then you need a rf modulator
Feb 09, 2015 | Emerson Televison & Video
Cant connect a rca soundbar to my emerson tv
If your Emerson TV has a digital coax output connector identified as such and your RCA soundbar has a digital coax input connector, you will have to purchase an appropriate cable and connect it. Some soundbars, such as Vizio, have left and right RCA audio inputs to match similar outputs on a TV set.
Jan 09, 2014 | Televison & Video
I cannot connect my emerson tv to dish network
How or what point on the set are you connected? Coax feed or what? Using a box or not?
Dec 14, 2012 | Emerson EWF2704 TV
I need to connect my vcr/dvd combo unit to an Emerson HD TV so that I can record shows. Can you help me?
Most TVs only have audio out and several audio/video in connections. Unless you have an unusual tv, there is no option for a coax connection from the TV to a recorder.
Since this DVD recorder only has an analog tuner, you need to connect it to a set top box to record signals unless you are looking only at analog channel sources. If you are getting OTA, then a OTA digital-to-analog tuner is needed for most channels. (Only low power stations are still broadcasting in analog.) The cheaper ones that were available with the government coupon were SD tuners. HD content will need a separate tuner. If you have cable or satellite, check the signal (QAM is digital cable).
Next connect the coax from your analog source to the DVD recorder coax in and another coax cable to the coax out and the TVs coax in (if you want to - the pass through doesn't work with a set-top box for non-analog signals). Set the channel to the appropriate one (3 or 4 for the OTA d-t-a boxes; desired channel to watch for analog OTA or cable). Set the TV to channel 2, 3 or 4. Alternatively, use composite A/V cables from the set top box to the A/V Input of the DVD recorder and set the recording channel to Input 1.
Next connect A/V cables (composite or S-video) to the recorder's matching out to the TV A/V or S-video In. Set the TV to A/V 1 or Video 1 depending on the Emerson TV. You can watch tapes or DVDs. For better video quality on DVD playback, also connect component video cables from the DVD recorder Out to the TV's component in (if it is available). Then set the TV to the appropriate component video input when watching DVDs.
I hope this helps.
Dec 05, 2010 | RCA DRC8300N DVD Recorder/VCR
How do connect a digital cable box to Home Theater system so you can get the audio from cable through the Home Theater?
Audio out from the cable bos to audio in to the home theater using rca cables. You may choose video, aux input etc on the home theater. Just select the one that the cable box is connected to.
Nov 23, 2009 | Radio Communications
I got a used tv with no remote, How do I know if my tv is remote capable? i have an Emerson EWC 1304 13in tv/vcr combo
Every television for the past 20 years has remote capability, with no exceptions. Purchase a universal remote, then there will be a piece of paper with the remote telling you how to program it for your brand of television.
Oct 07, 2009 | Emerson EWC1304 13 in. TV/VCR Combo
Will an RCA Digital Convertor work on Durabrands model #1304.?.
Hello chlpepr2,
Yes it should work, connect the RCA video out (yellow connector DTV Converter) to the RCA video in (yellow connector TV set). Then connect the RCA Audio out (Red-Right White-Left DTV converter) to the RCA audio in (Red-Right White-Left TV set).
Then setup your converter box according to the manufacture's instructions.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jan 20, 2009 | Televison & Video
EWF TV ANT IN BOKEN
ANGLS186-YES YOU CAN RESOLDER THE ANT. IN COAX CONECTION BUT KNOW YOU MUST FIRST SOLDER THE CENTER WIRE OF COAX TO TUNER BD. THEN CAREFULLY INSERT COAX BACK INTO ORIGINAL POSITION.THE EASIER SOLUTION IS TO USE A VCR OR CABLE BOX HOOKED TO YOUR SETS' VIDEO IN PORT AND CHANGE CANNELS W.THAT COMPONENT.JOE TV
Nov 19, 2007 | Emerson EWF2004 20" TV
Emerson EWC1304 13 in. TV/VCR Combo Logo
118 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
